NRF_DRV_SAADC_EVT_LIMIT is not triggered
Hi all
I want to trigger a limit event on a signal, which I receive on AIN0. Since the signal does not always have the same baseline, I set the limits with the first measurement and change if it is exceeded by 5% in any direction. Once this occurred, the operating mode of my device is changed and the new limits are set again from the new measurement. However, I noticed that NRF_DRV_SAADC_EVT_LIMIT never gets triggered. I read that this is always active and usually just ignored or set to the highest or lowest possible value so it does not interfere. But clearly something is wrong with my code. I would expect that once I exceed the limit shown in the log, I would get a message in the log "NRF_DRV_SAADC_EVT_LIMIT" and some additional messages from my operation_state() function. But this never happens.
Can you help me? Thanks!
My saadc_init:
void saadc_init(void)
    ret_code_t err_code;
    nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAADC_SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAADC_SAMPLES_IN_BUFFER);
    err_code = app_timer_start(m_opstate_interval_timer_id, APP_TIMER_TICKS(opstate_interval), NULL);
My saadc_callback:
    float mean_f;
    uint16_t limit_l, limit_h;
    switch (p_event->type)
	case NRF_DRV_SAADC_EVT_DONE:
	    err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
	    for (uint8_t i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
		mean_f += p_event->data.done.p_buffer[i] / (float)SAADC_SAMPLES_IN_BUFFER;
		NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
	    //NRF_LOG_INFO(NRF_LOG_FLOAT_MARKER, NRF_LOG_FLOAT(mean_f));
	    if (saadc_setlimits)
		saadc_setlimits = false;
		limit_l = (uint16_t) (mean_f * OP_STATE_MULTIPLIER_LL);
		limit_h = (uint16_t) (mean_f * OP_STATE_MULTIPLIER_HL);
		nrf_saadc_channel_limits_set(NRF_SAADC_INPUT_AIN0, limit_l, limit_h);
		NRF_LOG_INFO("Limits set initially to: %d, %d", limit_l, limit_h);
	    //m_supply_fb = true;
	case NRF_DRV_SAADC_EVT_LIMIT:
	    NRF_LOG_INFO("NRF_DRV_SAADC_EVT_LIMIT")
	    switch(p_event->data.limit.limit_type)
		case NRF_SAADC_LIMIT_LOW:
		    if (op_state_on)
			operation_state(false);
		case NRF_SAADC_LIMIT_HIGH:
		    if (!op_state_on) {
			operation_state(true);
And finally the output of the log:
<info> app: 369
<info> app: Limits set initially to: 350, 387
<info> app: 368
<info> app: 370
<info> app: 369
<info> app: 370
<info> app: 369
<info> app: 368
<info> app: 368
<info> app: 369
<info> app: 370
<info> app: 369
<info> app: 339
<info> app: 280
<info> app: 280
<info> app: 279
<info> app: 338
<info> app: 427
<info> app: 460
<info> app: 458
<info> app: 457
<info> app: 457
<info> app: 397
<info> app: 398
<info> app: 266
    You are using nrf_saadc_channel_limits_set() from the SAADC HAL, which is too low level. The function you should be using is nrf_drv_saadc_limits_set() which will enable or disable interrupts etc as needed.
  • Thanks, that was it.
    Also, I noted that NRF_DRV_SAADC_EVT_LIMIT does not provide data, so I had to set a flag to do the limit calculations only on NRF_DRV_SAADC_EVT_DONE. My callback now looks like this:
        float mean_f;
    		nrf_drv_saadc_limits_set(0, limit_l, limit_h);
    		NRF_LOG_INFO("Limits set to: %d, %d", limit_l, limit_h);
    		    saadc_setlimits = true;
    		    if (!op_state_on) {
