SEGGER_crtinit_v8m_mainline_little.o missing help
Hello, just updated from previous segger version to 5.34 but compiling an existing project
/ncs/v1.5.1/toolchain/segger_embedded_studio/lib/SEGGER_crtinit_v8m_mainline_little.o for reading
Please Help, before the update all was ok.
emag
    I'm a little confused. Are you using toolchain manager? Can you please elaborate on how you updated previous segger version?
    When building with an existing project, please delete the build folder, or use a new one.
    Øyvind
  • i have launched nrf Connect and it started an update then when finished opening the toolchain manager there is the button Open Ide. But when i try to compile an existing project i have the error.
    Now i downloaded segger 5.44 and copied the lib files and it compiles without errors.
    The only problem is that i can debug CpuApp but i have hardfault on network before the update it was working good the network debug. I receive also always a message that the CPU is secured.
    emag
  • Hi emag,
    nRF Connect for Desktop includes several apps. Were you asked to update the nRF Connect for Desktop application itself, or was it an app in nRF Connect for Desktop, or did you press update SDK/toolchain in the Toolchain Manager app?
     Segger 5.44 does not support the nRF Connect SDK, please use the official Segger Nordic Edition currently at v5.34a. This is the version which is included in NCS v1.5.1 in the Toolchain Manager.
     What sample/application are you trying to build/program? Have you followed the instructions given in our documentation?
    Øyvind
  • hello, problem solved!  I just copied  segger_crtinit_v8m_mainline_little.o in the ncs toolchain folder lib. Then creating a new project for App and Net and importing the old sources it works.
    thank you!
    Emag
