High sleep current - pca10059 - Thread - without softdevice
I am trying to send some sensor information via thread / mqttsn every 5 min. Therefore. The dongle has to wake up (5 sec.), send the information and return to sleep again.
Since the sensor/dongle is powered by a 3.4 V battery, they should draw as less power as possible during sleep periods. Unfortunately, I cant get the dongle into a "full" sleep mode. For me they should draw just a few µA in sleep mode, but I measure 11 mA. During the sensing I measure 20 mA. So the sleep mode is kind of triggered, but some part stays awake to draw 11 mA.
I started to test the program with different parts disabled. Like without thread or twi. So I was able to nail it down a bit. Without thread activated, I could reach around 15 µA. So I guess the problem might lie with thread. I even changed the end device from FED to SED, but it didn't help. I tested thread_sleep() and __WFE(), __SEV(), __WFE(), but there was no difference.
Further online investigation resulted in this ticket. My measurement result in a very similar way. But the solution of that ticket didn't work for me. Maybe because I don't use a softdevice.
#include <stdio.h>
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
//sensor
#include "boards.h"
#include "pca10056.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf.h"
//thread
#include "app_scheduler.h"
#include "app_timer.h"
#include "bsp_thread.h"
#include "nrf_log_ctrl.h"
#include "nrf_log.h"
#include "nrf_drv_gpiote.h"
#include "mqttsn_client.h"
#include "thread_utils.h"
#include "nrf_drv_clock.h"
#include <openthread/ip6.h>
#include <openthread/thread.h>
// Thread
#define DEFAULT_CHILD_TIMEOUT    40                                         /**< Thread child timeout [s]. */
#define DEFAULT_POLL_PERIOD      1000                                       /**< Thread Sleepy End Device polling period when MQTT-SN Asleep. [ms] */
#define SHORT_POLL_PERIOD        100                                        /**< Thread Sleepy End Device polling period when MQTT-SN Awake. [ms] */
#define SEARCH_GATEWAY_TIMEOUT 5
#define SCHED_QUEUE_SIZE      32                              /**< Maximum number of events in the scheduler queue. */
#define SCHED_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE /**< Maximum app_scheduler event size. */
APP_TIMER_DEF(m_repeated_timer_id);     /**< Handler for repeated timer used to blink LED 1. */
#define WAKEUP_TIME     10000    //wakeup every 10 sec
bool poweSaveMode = false;
static mqttsn_client_t      m_client;                                       /**< An MQTT-SN client instance. */
static mqttsn_remote_t      m_gateway_addr;                                 /**< A gateway address. */
static uint8_t              m_gateway_id;                                   /**< A gateway ID. */
static mqttsn_connect_opt_t m_connect_opt;                                  /**< Connect options for the MQTT-SN client. */
static uint8_t              m_led_state        = 0;                         /**< Previously sent BSP_LED_2 command. */
static uint16_t             m_msg_id           = 0;                         /**< Message ID thrown with MQTTSN_EVENT_TIMEOUT. */
static char                 m_client_id[]      = "nRF52840_publisher";      /**< The MQTT-SN Client's ID. */
static char                 m_topic_name[]     = "check"; /**< Name of the topic corresponding to subscriber's BSP_LED_2. */
static mqttsn_topic_t       m_topic            =                            /**< Topic corresponding to subscriber's BSP_LED_2. */
    .p_topic_name = (unsigned char *)m_topic_name,
    .topic_id     = 0,
int buttonNumber = 0;
 * @section MQTT-SN
/**@brief Puts MQTT-SN client in sleep mode.
 * @details This function changes Thread Sleepy End Device polling period to default.
static void sleep(void)
    otError error;
    error = otLinkSetPollPeriod(thread_ot_instance_get(), DEFAULT_POLL_PERIOD);
    ASSERT(error == OT_ERROR_NONE);
/**@brief Puts MQTT-SN client in active mode.
 * @details This function changes Thread Sleepy End Device polling period to short.
static void wake_up(void)
    otError error;
    error = otLinkSetPollPeriod(thread_ot_instance_get(), SHORT_POLL_PERIOD);
/**@brief Initializes MQTT-SN client's connection options.
static void connect_opt_init(void)
    m_connect_opt.alive_duration = MQTTSN_DEFAULT_ALIVE_DURATION,
    m_connect_opt.clean_session  = MQTTSN_DEFAULT_CLEAN_SESSION_FLAG,
    m_connect_opt.will_flag      = MQTTSN_DEFAULT_WILL_FLAG,
    m_connect_opt.client_id_len  = strlen(m_client_id),
    memcpy(m_connect_opt.p_client_id, (unsigned char *)m_client_id, m_connect_opt.client_id_len);
/**@brief Processes GWINFO message from a gateway.
 * @details This function updates MQTT-SN Gateway information.
 * @param[in]    p_event  Pointer to MQTT-SN event.
static void gateway_info_callback(mqttsn_event_t * p_event)
    m_gateway_addr = *(p_event->event_data.connected.p_gateway_addr);
    m_gateway_id   = p_event->event_data.connected.gateway_id;
/**@brief Processes CONNACK message from a gateway.
 * @details This function launches the topic registration procedure if necessary.
static void connected_callback(void)
    uint32_t err_code = mqttsn_client_topic_register(&m_client,
                                                     m_topic.p_topic_name,
                                                     strlen(m_topic_name),
                                                     &m_msg_id);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_ERROR("REGISTER message could not be sent. Error code: 0x%x\r\n", err_code);
/**@brief Processes DISCONNECT message from a gateway. */
static void disconnected_callback(void)
    sleep();
/**@brief Processes REGACK message from a gateway.
static void regack_callback(mqttsn_event_t * p_event)
    m_topic.topic_id = p_event->event_data.registered.packet.topic.topic_id;
    NRF_LOG_INFO("MQTT-SN event: Topic has been registered with ID: %d.\r\n",
                 p_event->event_data.registered.packet.topic.topic_id);
    sleep();
/**@brief Processes PUBACK message from a gateway.
 * @details This function puts the client in sleep mode.
static void puback_callback(void)
    sleep();
/**@brief Processes DISCONNECT message being a response to sleep request.
static void sleep_callback(void)
    sleep();
/**@brief Processes callback from keep-alive timer timeout.
 * @details This function puts the client in active mode.
static void wakeup_callback(void)
    wake_up();
/**@brief Processes retransmission limit reached event. */
static void timeout_callback(mqttsn_event_t * p_event)
    NRF_LOG_INFO("MQTT-SN event: Timed-out message: %d. Message ID: %d.\r\n",
                  p_event->event_data.error.msg_type,
                  p_event->event_data.error.msg_id);
/**@brief Processes results of gateway discovery procedure. */
static void searchgw_timeout_callback(mqttsn_event_t * p_event)
    NRF_LOG_INFO("MQTT-SN event: Gateway discovery result: 0x%x.\r\n", p_event->event_data.discovery);
    sleep();
/**@brief Function for handling MQTT-SN events. */
void mqttsn_evt_handler(mqttsn_client_t * p_client, mqttsn_event_t * p_event)
    switch(p_event->event_id)
        case MQTTSN_EVENT_GATEWAY_FOUND:
            NRF_LOG_INFO("MQTT-SN event: Client has found an active gateway.\r\n");
            nrf_drv_gpiote_out_toggle(BSP_LED_2);
            gateway_info_callback(p_event);
        case MQTTSN_EVENT_CONNECTED:
            NRF_LOG_INFO("MQTT-SN event: Client connected.\r\n");
            nrf_drv_gpiote_out_toggle(BSP_LED_3);
            connected_callback();
        case MQTTSN_EVENT_DISCONNECTED:
            NRF_LOG_INFO("MQTT-SN event: Client disconnected.\r\n");
            nrf_drv_gpiote_out_toggle(BSP_LED_1);
            disconnected_callback();
        case MQTTSN_EVENT_REGISTERED:
            NRF_LOG_INFO("MQTT-SN event: Client registered topic.\r\n");
            regack_callback(p_event);
        case MQTTSN_EVENT_PUBLISHED:
            NRF_LOG_INFO("MQTT-SN event: Client has successfully published content.\r\n");
        case MQTTSN_EVENT_SLEEP_PERMIT:
            NRF_LOG_INFO("MQTT-SN event: Client permitted to sleep.\r\n");
            sleep_callback();
        case MQTTSN_EVENT_SLEEP_STOP:
            NRF_LOG_INFO("MQTT-SN event: Client wakes up.\r\n");
            wakeup_callback();
        case MQTTSN_EVENT_TIMEOUT:
            NRF_LOG_INFO("MQTT-SN event: Retransmission retries limit has been reached.\r\n");
            timeout_callback(p_event);
        case MQTTSN_EVENT_SEARCHGW_TIMEOUT:
            NRF_LOG_INFO("MQTT-SN event: Gateway discovery procedure has finished.\r\n");
            searchgw_timeout_callback(p_event);
 * @section State
static void thread_state_changed_callback(uint32_t flags, void * p_context)
    NRF_LOG_INFO("State changed! Flags: 0x%08x Current role: %d\r\n",
                 flags, otThreadGetDeviceRole(p_context));
 * @section Buttons
static void publish(void)
    uint32_t err_code = mqttsn_client_publish(&m_client, m_topic.topic_id, "open!", 12, &m_msg_id);
        NRF_LOG_ERROR("PUBLISH message could not be sent. Error code: 0x%x\r\n", err_code)
static void bsp_event_handler(bsp_event_t event)
    if (otThreadGetDeviceRole(thread_ot_instance_get()) < OT_DEVICE_ROLE_CHILD )
        (void)event;
        return;
    switch (event)
        case BSP_EVENT_KEY_0:
            // search mqttsn gateway
            if (buttonNumber == 0){
                wake_up();
                buttonNumber++;
                uint32_t err_code = mqttsn_client_search_gateway(&m_client, SEARCH_GATEWAY_TIMEOUT);
                    NRF_LOG_ERROR("SEARCH GATEWAY message could not be sent. Error: 0x%x\r\n", err_code);
            //connect to mqttsn gateway
            if (buttonNumber == 1){
                wake_up();
                uint32_t err_code;
                buttonNumber++;
                if (mqttsn_client_state_get(&m_client) == MQTTSN_CLIENT_CONNECTED)
                    err_code = mqttsn_client_disconnect(&m_client);
                        NRF_LOG_ERROR("DISCONNECT message could not be sent. Error: 0x%x\r\n", err_code);
                    err_code = mqttsn_client_connect(&m_client, &m_gateway_addr, m_gateway_id, &m_connect_opt);
                        NRF_LOG_ERROR("CONNECT message could not be sent. Error: 0x%x\r\n", err_code);
            //- start timer
            if (buttonNumber == 2){
                wake_up();
                buttonNumber++;
                app_timer_start(m_repeated_timer_id, APP_TIMER_TICKS(WAKEUP_TIME), NULL);
                poweSaveMode = true;
 * @section Initialization
/**@brief Function for initializing the Application Timer Module.
static void timer_init(void)
    uint32_t err_code = app_timer_init();
static void log_init(void)
/**@brief Function for initializing the Thread Stack.
static void thread_instance_init(void)
    thread_configuration_t thread_configuration =
        .radio_mode             = THREAD_RADIO_MODE_RX_ON_WHEN_IDLE,
        .autocommissioning      = false,
        .poll_period            = DEFAULT_POLL_PERIOD,
        .default_child_timeout  = DEFAULT_CHILD_TIMEOUT,
        //.autostart_disable = true,
    thread_init(&thread_configuration);
    thread_cli_init();
    thread_state_changed_callback_set(thread_state_changed_callback);
    //button init
    uint32_t err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler);
    err_code = bsp_thread_init(thread_ot_instance_get());
/**@brief Function for initializing the MQTTSN client.
static void mqttsn_init(void)
    uint32_t err_code = mqttsn_client_init(&m_client,
                                           MQTTSN_DEFAULT_CLIENT_PORT,
                                           mqttsn_evt_handler,
    connect_opt_init();
/**@brief Function for initializing scheduler module.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
static void gpio_init(void)
    nrf_drv_gpiote_init();
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(true);
    nrf_drv_gpiote_out_init(BSP_LED_0, &out_config); //G alone
    nrf_drv_gpiote_out_init(BSP_LED_1, &out_config); //R
    nrf_drv_gpiote_out_init(BSP_LED_2, &out_config); //G
    nrf_drv_gpiote_out_init(BSP_LED_3, &out_config); //B
    nrf_drv_gpiote_out_init(VL53L1X_POWER, &out_config);
/**@brief Function starting the internal LFCLK oscillator.
 * @details This is needed by RTC1 which is used by the Application Timer
 *          (When SoftDevice is enabled the LFCLK is always running and this is not needed).
static void lfclk_request(void)
    nrf_drv_clock_init();
/**@brief Timeout handler for the repeated timer.
static void repeated_timer_handler(void * p_context)
    nrf_drv_gpiote_out_toggle(BSP_LED_0);
    nrf_delay_ms(5000);
/**@brief Create timers.
static void create_timers()
    // Create timers
    app_timer_create(&m_repeated_timer_id,
                        APP_TIMER_MODE_REPEATED,
                        repeated_timer_handler);
 * @section Main
int main(int argc, char *argv[])
    lfclk_request();
    log_init();
    scheduler_init();
    timer_init();
    gpio_init();
    create_timers();
    thread_instance_init();
    mqttsn_init();
    while (true)
        thread_process();
        app_sched_execute();
         if(poweSaveMode){
            thread_sleep();
        //if(poweSaveMode){
        //    //Wait for an event.
        //    __WFE();
        //    // Clear the internal event register.
        //    __SEV();
        //    __WFE();
For better understanding, I skipped the sensor/twi inside the code. Now I just connect mqttsn via button pressing and every 10 sec. the app_timer interrupt is called and a LED lights up for 5 sec. (sensor has almost no impact on the drawn power) The power results are the same. Does anyone have an idea, which part of the chip is still active?
Ps: I use Linux, SDK17, VS-Code, pca10059
