[Zigbee-mesh] How to initiate the route discovery manually?
Hi everyone,
I am making a zigbee mesh with just coordinator and routers only. I intended to have the mesh to cover a very large areas with nodes that can be moved (not frequently). I am using SDK4.1.0, for coordiantor , i uploaded the CLI example inside and for the router  i used the exact same example of lilght bulb with the only change is that i exclude every parts relating to notification led or button.
Tell my if i am wrong but from what i learn, when the nodes send a message to another node, without having the address in the routing table it will initalise the route discovery by (1) sending route request or (2) after some time out when it did not received a MAC ACK from the node it try to send to. My expectation is that i will work like a charm since it is almost the same as the example but it did not. It has a really annoying that even with the router is very far from the coordinator, even with very low LQI and miss a lot of MAC ACKs, it still persistently try to send to the coordinator and not every try to broadcast route requeset. And for the first condition to start a route discovery, when the router send route requests, the coordinator can definitely hear it (i have a sniffer just right by coorfinator side).
So my question is that i want to start the route discovery manually to have better control over the mesh. is there any way i can do that. If not, is there any solution for the route discovery.
Thank you in advances,
Tu
  • Hi Tu,
    I do not know of any functions to manually initiate route discovery that are visible to the application in our SDK. A lot of the NWK management and functions are internal parts of the ZBOSS stack, and thus not available to use. I have asked our developers if they know of any way to do this.
    I also have some questions to help me better understand your set up. Was the router originally in range of the coordinator, had it in it's neighbor table, and were able to communicate with it, before you moved it out of range? What kind of messages are the router trying to send to the coordinator?
     Could you clarify this for me? Is the router sending route request commands to the coordinator, but the command is not received on the coordinator's side? From further up in your description it seemed like the problem is that the router does not try to initiate route discovery, even though the router is out of range and does not receive the packets, but now you are saying the router is sending a route request command and the coordinator is in range to receive this (but does not for some reason)?
    Marte
  • Hi Marte,
    Here are some more elaborate infomation about my set up
    "Was the router originally in range of the coordinator, had it in it's neighbor table, and were able to communicate with it, before you moved it out of range? "
    -Yes, they can communicate with the coordinator before they get out of range. For the neigbor table, i investigate the link status message of each and every one of the node, all of them have link to every other nodes. but the incomming cost and outgoing cost  of some links are very bad like 6 or 7.
    "What kind of messages are the router trying to send to the coordinator?"
    -i try to send a report attribute message made with  the function zb_aps_send_user_payload(). I just made up some data (data send, cluster, atrribute, etc) to do it.
    "Is the router sending route request commands to the coordinator, but the command is not received on the coordinator's side? "  " Could you clarify this for me?"
    - Sorry for confusing you with my bad writing. So as I said i'd learnt that there are 2 cases for the router to start a route discovery, so i try to test them one by one. So, so for the first case, when the link status of the router is not having the link to coordinator(addr 0x0000), it did send route request. that is what i mean by "And for the first condition to start a route discovery, when the router send route requests, the coordinator can definitely hear it"
    But with the second case when i try to move the router out of range so that the message it sent does not have any MAC ACK return and the LQI very low (<20). I wait for about 2 mins and then i reset the device but notthing happen, no route request send.
    So for some more information, i only used the board as pca10059, pca10100, pca10056 with Zigbee SDK 4.1.0 The code for coordinator i used is the zigbee cli and the code for the router and the sdk_config is attach below
     * Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup zigbee_examples_light_bulb main.c
     * @ingroup zigbee_examples
     * @brief Dimmable light sample (HA profile)
    #include "sdk_config.h"
    #include "zboss_api.h"
    #include "zboss_api_addons.h"
    #include "zb_mem_config_med.h"
    #include "zb_ha_dimmable_light.h"
    #include "zb_error_handler.h"
    #include "zb_nrf52_internal.h"
    #include "zigbee_helpers.h"
    #include "nrf_timer.h"
    #include "bsp.h"
    #include "boards.h"
    #include "app_pwm.h"
    #include "app_timer.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_802154.h"
    #undef ZB_NWK_LINK_STATUS_PERIOD
    #define ZB_NWK_LINK_STATUS_PERIOD 0xa
    #undef ZB_NWK_ROUTER_AGE_LIMIT
    #define ZB_NWK_ROUTER_AGE_LIMIT 1
    #define MAX_CHILDREN                      10                                    /**< The maximum amount of connected devices. Setting this value to 0 disables association to this device.  */
    #define IEEE_CHANNEL_MASK                 (1l << ZIGBEE_CHANNEL)                /**< Scan only one, predefined channel to find the coordinator. */
    #define HA_DIMMABLE_LIGHT_ENDPOINT        10                                    /**< Device endpoint, used to receive light controlling commands. */
    #define ERASE_PERSISTENT_CONFIG           ZB_FALSE                              /**< Do not erase NVRAM to save the network parameters after device reboot or power-off. */
    #define BULB_PWM_NAME                     PWM1                                  /**< PWM instance used to drive dimmable light bulb. */
    #define BULB_PWM_TIMER                    2                                     /**< Timer number used by PWM. */
    /* Basic cluster attributes initial values. */
    #define BULB_INIT_BASIC_APP_VERSION       01                                    /**< Version of the application software (1 byte). */
    #define BULB_INIT_BASIC_STACK_VERSION     10                                    /**< Version of the implementation of the Zigbee stack (1 byte). */
    #define BULB_INIT_BASIC_HW_VERSION        11                                    /**< Version of the hardware of the device (1 byte). */
    #define BULB_INIT_BASIC_MANUF_NAME        "Nordic"                              /**< Manufacturer name (32 bytes). */
    #define BULB_INIT_BASIC_MODEL_ID          "Dimable_Light_v0.1"                  /**< Model number assigned by manufacturer (32-bytes long string). */
    #define BULB_INIT_BASIC_DATE_CODE         "20180416"                            /**< First 8 bytes specify the date of manufacturer of the device in ISO 8601 format (YYYYMMDD). The rest (8 bytes) are manufacturer specific. */
    #define BULB_INIT_BASIC_POWER_SOURCE      ZB_ZCL_BASIC_POWER_SOURCE_DC_SOURCE   /**< Type of power sources available for the device. For possible values see section 3.2.2.2.8 of ZCL specification. */
    #define BULB_INIT_BASIC_LOCATION_DESC     "Office desk"                         /**< Describes the physical location of the device (16 bytes). May be modified during commisioning process. */
    #define BULB_INIT_BASIC_PH_ENV            ZB_ZCL_BASIC_ENV_UNSPECIFIED          /**< Describes the type of physical environment. For possible values see section 3.2.2.2.10 of ZCL specification. */
    #ifdef  BOARD_PCA10059                                                          /**< If it is Dongle */
    #define IDENTIFY_MODE_BSP_EVT             BSP_EVENT_KEY_0                       /**< Button event used to enter the Bulb into the Identify mode. */
    #define ZIGBEE_NETWORK_STATE_LED          BSP_BOARD_LED_0                       /**< LED indicating that light switch successfully joind Zigbee network. */
    #else
    #define IDENTIFY_MODE_BSP_EVT             BSP_EVENT_KEY_3                       /**< Button event used to enter the Bulb into the Identify mode. */
    #define ZIGBEE_NETWORK_STATE_LED          BSP_BOARD_LED_2                       /**< LED indicating that light switch successfully joind Zigbee network. */
    #define BULB_LED                          BSP_BOARD_LED_3                       /**< LED immitaing dimmable light bulb. */
    #if (APP_BULB_USE_WS2812_LED_CHAIN)
    #define LED_CHAIN_DOUT_PIN                NRF_GPIO_PIN_MAP(1,7)                 /**< GPIO pin used as DOUT (to be connected to DIN pin of the first ws2812 led in chain) */
    /* Declare endpoint for Dimmable Light device with scenes. */
    #define ZB_HA_DECLARE_LIGHT_EP(ep_name, ep_id, cluster_list)                         \
    ZB_ZCL_DECLARE_HA_DIMMABLE_LIGHT_SIMPLE_DESC(ep_name, ep_id,                       \
      ZB_HA_DIMMABLE_LIGHT_IN_CLUSTER_NUM, ZB_HA_DIMMABLE_LIGHT_OUT_CLUSTER_NUM);      \
    ZBOSS_DEVICE_DECLARE_REPORTING_CTX(reporting_info## device_ctx_name,               \
     ZB_HA_DIMMABLE_LIGHT_REPORT_ATTR_COUNT);        \
    ZBOSS_DEVICE_DECLARE_LEVEL_CONTROL_CTX(cvc_alarm_info## device_ctx_name,           \
     ZB_HA_DIMMABLE_LIGHT_CVC_ATTR_COUNT);       \
    ZB_AF_DECLARE_ENDPOINT_DESC(ep_name, ep_id, ZB_AF_HA_PROFILE_ID,                   \
      0,     \
      NULL,                 \
      ZB_ZCL_ARRAY_SIZE(cluster_list, zb_zcl_cluster_desc_t),\
      cluster_list,                                          \
      (zb_af_simple_desc_1_1_t*)&simple_desc_##ep_name,      \
      ZB_HA_DIMMABLE_LIGHT_REPORT_ATTR_COUNT,                \
      ZB_HA_DIMMABLE_LIGHT_CVC_ATTR_COUNT,                   \
      cvc_alarm_info## device_ctx_name)
    #if !defined ZB_ROUTER_ROLE
    #error Define ZB_ROUTER_ROLE to compile light bulb (Router) source code.
    APP_TIMER_DEF(timer);
    /* Main application customizable context. Stores all settings and static values. */
    typedef struct
      zb_zcl_basic_attrs_ext_t         basic_attr;
      zb_zcl_identify_attrs_t          identify_attr;
      zb_zcl_scenes_attrs_t            scenes_attr;
      zb_zcl_groups_attrs_t            groups_attr;
      zb_zcl_on_off_attrs_ext_t        on_off_attr;
      zb_zcl_level_control_attrs_t     level_control_attr;
    } bulb_device_ctx_t;
    typedef struct
        zb_uint16_t     attr_id;  /**< Attribute ID specific to cluster */
        zb_uint8_t      attr_type; /**< Attribute type (see @ref zb_zcl_attr_type_t) */
        zb_uint8_t      *data_p;   /**< Attribute data */
        zb_uint16_t     *data_p_16;   /**< Attribute data */
        zb_uint32_t     *data_p_32;   /**< Attribute data */
    } attr_info_t;
    typedef struct {
        zb_uint8_t      src_endpoint;  /*!< Source endpoint */
        zb_uint8_t      dst_addr_mode; /*!< Destinition address mode*/
        zb_addr_u       dst_addr;       /*!< Destinition address */
        zb_uint8_t      dst_endpoint;  /*!< Destinition endpoint */
        zb_uint16_t     profile_id;   /*!< Profile ID for reporting */
        zb_uint16_t     cluster_id;   /*!< Cluster ID for reporting */
        attr_info_t     attr_info[10];
    } reporting_info_t;
    static bulb_device_ctx_t m_dev_ctx;
    ZB_ZCL_DECLARE_IDENTIFY_ATTRIB_LIST(identify_attr_list, &m_dev_ctx.identify_attr.identify_time);
    ZB_ZCL_DECLARE_GROUPS_ATTRIB_LIST(groups_attr_list, &m_dev_ctx.groups_attr.name_support);
    ZB_ZCL_DECLARE_SCENES_ATTRIB_LIST(scenes_attr_list,
      &m_dev_ctx.scenes_attr.scene_count,
      &m_dev_ctx.scenes_attr.current_scene,
      &m_dev_ctx.scenes_attr.current_group,
      &m_dev_ctx.scenes_attr.scene_valid,
      &m_dev_ctx.scenes_attr.name_support);
    ZB_ZCL_DECLARE_BASIC_ATTRIB_LIST_EXT(basic_attr_list,
     &m_dev_ctx.basic_attr.zcl_version,
     &m_dev_ctx.basic_attr.app_version,
     &m_dev_ctx.basic_attr.stack_version,
     &m_dev_ctx.basic_attr.hw_version,
     m_dev_ctx.basic_attr.mf_name,
     m_dev_ctx.basic_attr.model_id,
     m_dev_ctx.basic_attr.date_code,
     &m_dev_ctx.basic_attr.power_source,
     m_dev_ctx.basic_attr.location_id,
     &m_dev_ctx.basic_attr.ph_env,
     m_dev_ctx.basic_attr.sw_ver);
    /* On/Off cluster attributes additions data */
    ZB_ZCL_DECLARE_ON_OFF_ATTRIB_LIST_EXT(on_off_attr_list,
      &m_dev_ctx.on_off_attr.on_off,
      &m_dev_ctx.on_off_attr.global_scene_ctrl,
      &m_dev_ctx.on_off_attr.on_time,
      &m_dev_ctx.on_off_attr.off_wait_time);
    ZB_ZCL_DECLARE_LEVEL_CONTROL_ATTRIB_LIST(level_control_attr_list,
     &m_dev_ctx.level_control_attr.current_level,
     &m_dev_ctx.level_control_attr.remaining_time);
    ZB_HA_DECLARE_DIMMABLE_LIGHT_CLUSTER_LIST(dimmable_light_clusters,
      basic_attr_list,
      identify_attr_list,
      groups_attr_list,
      scenes_attr_list,
      on_off_attr_list,
      level_control_attr_list);
    ZB_HA_DECLARE_LIGHT_EP(dimmable_light_ep,
     HA_DIMMABLE_LIGHT_ENDPOINT,
     dimmable_light_clusters);
    ZB_HA_DECLARE_DIMMABLE_LIGHT_CTX(dimmable_light_ctx,
     dimmable_light_ep);
    /**@brief Function for initializing the application timer.
    static void timer_init(void)
      uint32_t error_code = app_timer_init();
      APP_ERROR_CHECK(error_code);
    static void log_init(void)
    void zboss_signal_handler(zb_bufid_t bufid)
        /* Update network status LED */
      zb_zdo_app_signal_hdr_t  * p_sg_p      = NULL;
      zb_zdo_app_signal_type_t   sig         = zb_get_app_signal(bufid, &p_sg_p);
        /* No application-specific behavior is required. Call default signal handler. */
      switch (sig)
        ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
      if (bufid)
        zb_buf_free(bufid);
    void _my_own_handler (void *p_context)
      // static zb_bufid_t last_bufid = 0;
      // if(last_bufid != 0) zb_buf_free(last_bufid);
      zb_bufid_t bufid;
      bufid = zb_buf_get_out_func();
      if(bufid == 0 || bufid == 28) {
        zb_buf_free(bufid);
        return;
      zb_addr_u addr = {
        .addr_short = 0x0000,
      NRF_LOG_INFO("bufid %d", bufid);
      zb_uint8_t payload[8] = {0x08, 0, 0x0a, 0x55, 0x00, 0x21, 0x03, 0x00};
      payload[1] = bufid;
      if(ZB_JOINED() == 1)
        zb_aps_send_user_payload(bufid, addr, 0x0104, 0x55, 1, 1, 2, ZB_FALSE, payload, sizeof(payload));
      app_timer_start(timer, APP_TIMER_TICKS(6000), NULL);
    /**@brief Function for application main entry.
      zb_ret_t       zb_err_code;
      zb_ieee_addr_t ieee_addr;
        /* Initialize timer, logging system and GPIOs. */
      timer_init();
      log_init();
        /* Initialize Zigbee stack. */
      ZB_INIT("led_bulb");
        /* Set Zigbee stack logging level and traffic dump subsystem. */
      ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
      ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
      ZB_SET_TRAF_DUMP_OFF();
        /* Set device address to the value read from FICR registers. */
      zb_osif_get_ieee_eui64(ieee_addr);
      zb_set_long_address(ieee_addr);
        /* Set static long IEEE address. */
      zb_set_network_router_role(IEEE_CHANNEL_MASK);
      //zb_set_max_children(MAX_CHILDREN);
        zb_set_max_children(3);
      zigbee_erase_persistent_storage(ZB_FALSE);
      zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
        /* Initialize application context structure. */
      UNUSED_RETURN_VALUE(ZB_MEMSET(&m_dev_ctx, 0, sizeof(m_dev_ctx)));
        /* Register callback for handling ZCL commands. */
        //ZB_ZCL_REGISTER_DEVICE_CB(zcl_device_cb);
        /* Register dimmer switch device context (endpoints). */
      ZB_AF_REGISTER_DEVICE_CTX(&dimmable_light_ctx);
        /** Start Zigbee Stack. */
      zb_err_code = zboss_start_no_autostart();
      ZB_ERROR_CHECK(zb_err_code);
      app_timer_create(&timer, APP_TIMER_MODE_SINGLE_SHOT, _my_own_handler);
      app_timer_start(timer, APP_TIMER_TICKS(5000), NULL);
      while(1)
        zboss_main_loop_iteration();
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    8510.sdk_config.h
    Thank you for your support
    Tu
  • I also include the make file flag so that you can take a look
    # Optimization flags
    OPT = -Os -ggdb3
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += -DAPP_TIMER_V2
    CFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED
    CFLAGS += -DBOARD_PCA10100
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DENABLE_FEM
    CFLAGS += -DFLOAT_ABI_HARD
    CFLAGS += -DNRF52833_XXAA
    CFLAGS += -DZB_TRACE_LEVEL=0
    CFLAGS += -DZB_TRACE_MASK=0
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS += -Wall -Werror
    CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums -Wno-packed-bitfield-compat
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -ggdb3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    ASMFLAGS += -DAPP_TIMER_V2
    ASMFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED
    ASMFLAGS += -DBOARD_PCA10100
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DENABLE_FEM
    ASMFLAGS += -DFLOAT_ABI_HARD
    ASMFLAGS += -DNRF52833_XXAA
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    nrf52833_xxaa: CFLAGS += -D__HEAP_SIZE=8192
    nrf52833_xxaa: CFLAGS += -D__STACK_SIZE=8192
    nrf52833_xxaa: ASMFLAGS += -D__HEAP_SIZE=8192
    nrf52833_xxaa: ASMFLAGS += -D__STACK_SIZE=8192
  • Hi Tu,
    Thank you for clarifying!
    The Zigbee team confirmed that the function to initiate route discovery is part of the ZBOSS internals and not exported to the SDK, so it is not available to the application.
    From what I understand, the device should discover a new route when the old route is broken, so I do not know why your router does not start route discovery when it cannot reach the coordinator anymore. I do not know if this is expected behavior, a bug, or if there is something you can do in your application to make the router try to fix the broken route. I have asked internally to get a clarification regarding this, so I will come back to you when I know more.
    Marte
  • Hi Marte,
    Thank you very much for your support. Please let me know whenever you have any additional information on this problem.
    Tu
