2021 05 18 west update new source
mkdir -p ncs
west init -m github.com/.../sdk-nrf --mr master ./ncs
cd ~/ncs
west update
west zephyr-export
//// ~/ncs/nrf/west.yml
repo-path: sdk-zephyr
revision: 4d068de3f50f6a2de2be0c0b98670e33d28ff493
1. revision: 4d068de3f50f6a2de2be0c0b98670e33d28ff493 before to void main() CRASH, when set_compiler_property(PROPERTY optimization_debug -O0)
2. revision: a9423cbce69a5df78140a2cf3ba11aa56d395cfc west update, go to void main() good work, when set_compiler_property(PROPERTY optimization_debug -O0)
# follows are my setting
/////~/ncs/zephyr/cmake/compiler/gcc/compiler_flags.cmake
set_compiler_property(PROPERTY no_optimization -O0)
if(CMAKE_C_COMPILER_VERSION VERSION_LESS "4.8.0")
else()
#set_compiler_property(PROPERTY optimization_debug -Og)
endif()
set_compiler_property(PROPERTY optimization_speed -O2)
#set_compiler_property(PROPERTY optimization_size -Os)
set_compiler_property(PROPERTY optimization_size -Og)
////SES create hello_world in non-secure mode
build_nrf9160dk_nrf9160ns
////prj.conf
CONFIG_DEBUG=y
# enable cpp
CONFIG_CPLUSPLUS=y
CONFIG_STD_CPP11=y
CONFIG_LIB_CPLUSPLUS=y
# enable libs
CONFIG_NEWLIB_LIBC=y
CONFIG_FPU=y
# page fault dump
CONFIG_FAULT_DUMP=1
# disable console out
###CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=2048
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=2048
# enable device
CONFIG_I2C=y
# reboot utility
CONFIG_REBOOT=y
# Fatal error reboot
CONFIG_WATCHDOG=y
# Json utility, if u need
###CONFIG_JSON_LIBRARY=y
# flash write
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# enable mcuboot/boot/zephyr project
CONFIG_BOOTLOADER_MCUBOOT=y
//////////////nrf9160dk_nrf9160ns.overlay
chosen {
zephyr,console = &uart0;
zephyr,shell-uart = &uart0;
zephyr,uart-mcumgr = &uart0;
zephyr,bt-mon-uart = &uart0;
&uart0 {
current-speed = <115200>;
status = "okay";
rx-pin = <0>;
tx-pin = <1>;
/delete-property/ cts-pin;
/delete-property/ rts-pin;
&uart1 {
status = "okay";
rx-pin = <0x15>;
tx-pin = <0x16>;
&uart2 {
status = "okay";
rx-pin = <0x1b>;
tx-pin = <0x1c>;
&i2c2 {
status = "disabled";
&i2c3 {
status = "okay";
sda-pin = < 0x1e >;
scl-pin = < 0x1f >;
clock-frequency = <I2C_BITRATE_STANDARD>;
eeprom0: eeprom@54 {
compatible = "atmel,at24";
reg = <0x54>;
label = "EEPROM_0";
size = <1024>;
pagesize = <16>;
address-width = <8>;
timeout = <3>;
eeprom1: eeprom@56 {
reg = <0x56>;
label = "EEPROM_1";
size = <1024>;
pagesize = <16>;
timeout = <3>;
&spi3 {
sck-pin = <0xFFFFFFFF>;
mosi-pin = <0xFFFFFFFF>;
miso-pin = <0xFFFFFFFF>;
