BLE packet loss testing
We are currently in the process of performing radio certification according to the RED directive for our device based on nRF52810.
To finalize a Receiver Blocking radio test we are requested to provide a test set-up on the devices. We need to have software that can count package loss (Package Error Rate or Frame Error Rate). The package loss must not exceed the 10 % ratio of all sent packages to grant the PASS test result (See description below).
Are there any ready tools (software / firmware) that we can use for this test?
Thanks in advance,
Oleksandr
Receiver Blocking
4.3.1.12.2 Definition
Receiver blocking is a measure of the ability of the equipment to receive a wanted signal on its operating channel without exceeding a given degradation due to the presence of an unwanted input signal (blocking signal) on frequencies other than those of the operating band and spurious responses.
4.3.1.12.3 Performance Criteria
For equipment that supports a PER or FER test to be performed, the minimum performance criterion shall be a PER or FER less than or equal to 10 %. For equipment that does not support a PER or a FER test to be performed, the minimum performance criterion shall be no loss of the wireless transmission function needed for the intended use of the equipment.
