NRF52840 NRF Connect desktop pairing / bonding issue
Good day
I use NRF52840 + SDK v17.0.2. My application relies on _gls example and mainly copies its security settings ( also uses peer manager ) except I use MITM protection for my characteristics and static pin code approach.
The root cause of issue is that behavior of NRF Connect for mobile (Android ) and for desktop differs. Our test app behaves correctly - I would say in the same way as NRF Connect for Android.
If shortly for Android ( NRF Connect app ) and iOS ( our test app ) during connection and bonding everything goes smoothly and I get expected result - I see pairing requests and system textbox for pin code input on both devices, after bonding is done I am able to connect without pin input.
The situation with NRF connect is different. It runs with 52840 usb dongle on Ubuntu, the version is 3.6.1 ( also tried 3.6.0 ). I tried both options: with automatic security response and manual - the result is the same - I can not get pin request on the screen thus device can not bond
Despite of MITM flag set in NRF Connect - anyway I get: Collector did not use MITM, disconnecting
Please advise what did I miss or what am I doing wrong. 2 log files are attached ( RTT output )
Thank you
Android /iOS - OK flow
<info> app: Reset reason: 1
<info> app: Setting vector table to bootloader: 0x000F1000
<info> app: Setting vector table to main app: 0x00027000
<info> app: battery_service_init() completed: 0
<info> app: Device id: 4fd1919f9a9b83a6
<info> app: MAC address: f0:7f:1e:fa:9a:08, type: -1
<info> app: dis_service_init() completed: 0
<error> app_serial: uart_event_handle(): APP_UART_COMMUNICATION_ERROR -> 4
<debug> nrf_ble_lesc: Initialized nrf_crypto.
<debug> nrf_ble_lesc: Initialized nrf_ble_lesc.
<debug> nrf_ble_lesc: Generating ECC key pair
<info> app_timer: RTC: initialized.
<info> app_adc: adc_init()
<info> app_indic: indicate INDICATE_IDLE = 0
<info> app_btn: button_configure: STATE_STARTUP
<info> app_twi_manager: twi_manager_init()
<info> app_pmic: global status 0x40
<info> app_pmic: ercflag 0x00
<info> app_state: set_ext_powered: FALSE, current state: STATE_ADVERTISING
<info> app_indic: indicate INDICATE_CHARGE_UNPLUGGED
<info> app_state: set_charging: FALSE
<info> app_pmic: charge status 0x00 0x00
<debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
<debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0.
<info> app_serial_srv: on_ble_event: BLE_GAP_EVT_CONNECTED
<info> peer_manager_handler: pm_handler_secure_on_connection: BLE_GAP_EVT_CONNECTED
<info> peer_manager_handler: Connected, securing connection. conn_handle: 0
<info> app: ble_evt_handler: BLE_GAP_EVT_CONNECTED
<info> app_state: state_set: STATE_CONNECTED
<info> app_indic: indicate INDICATE_CONNECTED
<info> app_btn: button_configure: STATE_CONNECTED
<info> app_pmic: pmic_ir_enable( TRUE )
<info> app_pmic: pmic_ir_enable(): err_code 0
<info> app: pmic_ir_enable_callback
<info> app: Data len is set to 0xF4(244)
<debug> app: ATT MTU exchange completed. central 0xF7 peripheral 0xF7
<info> app_serial_srv: on_ble_event: 58
<info> peer_manager_handler: pm_handler_secure_on_connection: event 58
<info> app: ble_evt_handler: 58
<debug> nrf_ble_gatt: Data length updated to 251 on connection 0x0.
<debug> nrf_ble_gatt: max_rx_octets: 27
<debug> nrf_ble_gatt: max_tx_octets: 251
<debug> nrf_ble_gatt: max_rx_time: 328
<debug> nrf_ble_gatt: max_tx_time: 2120
<info> app_serial_srv: on_ble_event: 36
<info> app: ble_evt_handler: 36
<info> app: pm_evt_handler(): 5
<info> app_serial_srv: on_ble_event: 18
<info> peer_manager_handler: pm_handler_secure_on_connection: event 18
<info> app: ble_evt_handler: BLE_GAP_EVT_CONN_PARAM_UPDATE
<info> app: pm_evt_handler(): 1
<info> app_serial_srv: on_ble_event: 19
<info> peer_manager_handler: pm_handler_secure_on_connection: event 19
<info> app: ble_evt_handler: BLE_GAP_EVT_SEC_PARAMS_REQUEST
<info> app_serial_srv: on_ble_event: 21
<info> peer_manager_handler: pm_handler_secure_on_connection: event 21
<info> app: ble_evt_handler: BLE_GAP_EVT_PASSKEY_DISPLAY
<info> app: Passkey: 123456
<info> app_serial_srv: on_ble_event: 26
<info> peer_manager_handler: pm_handler_secure_on_connection: event 26
<info> app: ble_evt_handler: 26
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
<info> app: pm_evt_handler(): PM_EVT_CONN_SEC_SUCCEEDED
<info> app: Link secured. Role: 1. conn_handle: 0, Procedure: 1
<info> app_serial_srv: on_ble_event: 25
<info> peer_manager_handler: pm_handler_secure_on_connection: event 25
<info> app: ble_evt_handler: BLE_GAP_EVT_AUTH_STATUS
<info> app:     status=0x0 bond=0x1 lv4: 0 kdist_own:0x3 kdist_peer:0x3
<info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
<info> app_serial_srv: on_ble_event: 53
<info> peer_manager_handler: pm_handler_secure_on_connection: event 53
<info> app: ble_evt_handler: 53
<info> app_serial_srv: on_ble_event: 54
<info> peer_manager_handler: pm_handler_secure_on_connection: event 54
<info> app: ble_evt_handler: 54
<info> app_serial_srv: on_ble_event: BLE_GATTS_EVT_WRITE
<info> peer_manager_handler: pm_handler_secure_on_connection: event 80
<info> app: ble_evt_handler: 80
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
<info> app: pm_evt_handler(): 14
<info> app_serial_srv: on_ble_event: 82
<info> peer_manager_handler: pm_handler_secure_on_connection: event 82
<info> app: ble_evt_handler: BLE_GATTS_EVT_SYS_ATTR_MISSING
NRF connect for desktop - FAIL flow
<debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response).
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Pairing
<info> app: Collector did not use MITM, disconnecting
<info> app:     m_peer_to_be_deleted: 65535
<debug> app: Disconnected connection handle 0
<info> app:     status=0x0 bond=0x0 lv4: 0 kdist_own:0x0 kdist_peer:0x0
<info> app: pm_whitelist_get returns 0 addr in whitelist and 0 irk whitelist
<info> app: on_adv_evt: BLE_ADV_EVT_FAST
<info> app_state: state_set: STATE_ADVERTISING
<info> app_indic: indicate INDICATE_ADVERTISING
<info> app_btn: button_configure: STATE_ADVERTISING
<info> app_serial_srv: on_ble_event: BLE_GAP_EVT_DISCONNECTED
<info> app: pmic_ir_disable_callback
