Firmware Crash on ble_stack_init()
The firmware crashes when passing the ble_stack_init() when the firmware is download but in debug mode it works fine. The screen shots below shows this event.
We are using S132 and nRF5_SDK_17.0.2_d674dde
Code Snippet
On this scope shots we can see that on debug mode the test point would go low after around 2 seconds but on downloaded it didn't go low even after 3 seconds and more.
Debug Mode
Downloaded
Any thoughts on what is causing this issue?
  • Hello Simon, as of now the the preprocessor definitions in the Segger Embedded Studio includes the following :
    APP_TIMER_V2
    APP_TIMER_V2_RTC1_ENABLED
    BOARD_CUSTOM
    CONFIG_GPIO_AS_PINRESET
    CONFIG_NFCT_PINS_AS_GPIOS
    FLOAT_ABI_HARD
    INITIALIZE_USER_SECTIONS
    NO_VTOR_CONFIG
    NRF52
    NRF52832_XXAA
    NRF52_PAN_74
    NRF_SD_BLE_API_VERSION=7
    S132
    SOFTDEVICE_PRESENT
    We did not specify the DEBUG keyword.
    I am not sure why I cannot upload our ble_module.c file here. I am trying to embed it here as code.
    #include "ble_module.h"
    BLE_CUS_DEF(m_cus);
    BLE_SERVICE_1_DEF(m_service_1);
    BLE_SERVICE_2_DEF(m_service_2);
    BLE_SERVICE_3_DEF(m_service_3);
    BLE_SERVICE_4_DEF(m_service_4);
    /**< Context for the Queued Write module.*/
    NRF_BLE_QWR_DEF(m_qwr);
    /**< GATT module instance. */
    NRF_BLE_GATT_DEF(m_gatt);
    /**< Advertising module instance. */
    BLE_ADVERTISING_DEF(m_advertising);
    APP_TIMER_DEF(m_service_4_char_1_notification_timer_id);
    APP_TIMER_DEF(m_service_4_char_2_notification_timer_id);
    APP_TIMER_DEF(m_service_4_char_3_notification_timer_id);
    static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
        {SERVICE_3_UUID, BLE_UUID_TYPE_VENDOR_BEGIN}
     * @note: Controller board doesn't have XTAL see NRF_SDH_CLOCK_LF_SRC of
     *        sdk_config.h
    void ble_stack_init(void)
        uint32_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
        uint32_t err_code = NRF_SUCCESS;
                printf("Disconnected.");
            case BLE_GAP_EVT_CONNECTED:
                printf("Connected.");
                //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
                //APP_ERROR_CHECK(err_code);
                printf("PHY update request.");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
                printf("GATT Client Timeout.");
            case BLE_GATTS_EVT_TIMEOUT:
                printf("GATT Server Timeout.");
                // No implementation needed.
    /**@brief Function for initializing the GATT module.
    void gatt_init(void)
        uint32_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
    void gap_params_init(void)
        uint32_t              err_code;
        // Note : ble_gap_conn_params_t and ble_gap_conn_sec_mode_t are structs based from the BLE 5.0 standard.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    void nrf_qwr_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    static void on_cus_evt(ble_cus_t     * p_cus_service,
                           ble_cus_evt_t * p_evt)
        ret_code_t err_code;
        switch(p_evt->evt_type)
            case BLE_CUS_EVT_NOTIFICATION_ENABLED:
                 //err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
            case BLE_CUS_EVT_NOTIFICATION_DISABLED:
                //err_code = app_timer_stop(m_notification_timer_id);
            case BLE_CUS_EVT_CONNECTED:
            case BLE_CUS_EVT_DISCONNECTED:
    static void on_service_4_evt(ble_service_4_t * p_service_4_service, ble_service_4_evt_t * p_evt)
        uint32_t err_code;
            case BLE_SERVICE_4_EVT_NOTIFICATION_ENABLED:
                 err_code = app_timer_start(m_service_4_char_1_notification_timer_id, SERVICE_4_CHAR_1_MESSAGE_QUEUE_INTERVAL, NULL);
                 err_code = app_timer_start(m_service_4_char_2_notification_timer_id, SERVICE_4_CHAR_2_MESSAGE_QUEUE_INTERVAL, NULL);
                 err_code = app_timer_start(m_service_4_char_3_notification_timer_id, SERVICE_4_CHAR_3_MESSAGE_QUEUE_INTERVAL, NULL);
            case BLE_SERVICE_4_EVT_NOTIFICATION_DISABLED:
                err_code = app_timer_stop(m_service_4_char_1_notification_timer_id);
                err_code = app_timer_stop(m_service_4_char_2_notification_timer_id);
                err_code = app_timer_stop(m_service_4_char_3_notification_timer_id);
            case BLE_SERVICE_4_EVT_CONNECTED:
            case BLE_SERVICE_4_EVT_DISCONNECTED:
    static void on_service_2_evt(ble_service_2_t * p_service_2_service, ble_service_2_evt_t * p_evt)
            case BLE_SERVICE_2_EVT_NOTIFICATION_ENABLED:
            case BLE_SERVICE_2_NOTIFICATION_DISABLED:
            case BLE_SERVICE_2_EVT_CONNECTED:
            case BLE_SERVICE_2_EVT_DISCONNECTED:
    static void on_service_3_evt(ble_service_3_t * p_service_3_service, ble_service_3_evt_t * p_evt)
            case BLE_SERVICE_3_EVT_NOTIFICATION_ENABLED:
            case BLE_SERVICE_3_EVT_NOTIFICATION_DISABLED:
            case BLE_SERVICE_3_EVT_CONNECTED:
            case BLE_SERVICE_3_EVT_DISCONNECTED:
    static void on_service_1_evt(ble_service_1_t * p_service_1_service, ble_service_1_evt_t * p_evt)
            case BLE_SERVICE_1_EVT_NOTIFICATION_ENABLED:
            case BLE_SERVICE_1_EVT_NOTIFICATION_DISABLED:
            case BLE_SERVICE_1_EVT_CONNECTED:
            case BLE_SERVICE_1_EVT_DISCONNECTED:
    void services_init(void)
            nrf_ble_qwr_init_t  qwr_init = {0};
            ble_cus_init_t      cus_init = {0};
            ble_service_1_init_t    service_1_init = {0};
            ble_service_2_init_t      service_2_init = {0};
            ble_service_3_init_t       service_3_init = {0};
            ble_service_4_init_t       service_4_init = {0};
             // Initialize CUS Service init structure to zero.
            memset(&cus_init, 0, sizeof(cus_init));
            cus_init.evt_handler                = on_cus_evt;
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.cccd_write_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
            err_code = ble_cus_init(&m_cus, &cus_init);
            // Initialize Service 1 init structure to zero.
            memset(&service_1_init, 0, sizeof(service_1_init));
            service_1_init.evt_handler = on_service_1_evt;
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_1_init.service_1_value_char_attr_md.cccd_write_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_1_init.service_1_value_char_attr_md.read_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_1_init.service_1_value_char_attr_md.write_perm);
            err_code = ble_service_1_init(&m_service_1, &service_1_init);
            memset(&service_2_init, 0, sizeof(service_2_init));
            service_2_init.evt_handler = on_service_2_evt;
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_2_init.service_2_value_char_attr_md.cccd_write_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_2_init.service_2_value_char_attr_md.read_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_2_init.service_2_value_char_attr_md.write_perm);
            err_code = ble_service_2_init(&m_service_2, &service_2_init);
            memset(&service_3_init, 0, sizeof(service_3_init));
            service_3_init.evt_handler = on_service_3_evt;
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_3_init.service_3_value_char_attr_md.cccd_write_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_3_init.service_3_value_char_attr_md.read_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_3_init.service_3_value_char_attr_md.write_perm);
            err_code = ble_service_3_init(&m_service_3, &service_3_init);
            memset(&service_4_init, 0, sizeof(service_4_init));
            service_4_init.evt_handler = on_service_4_evt;
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_4_init.service_4_value_char_attr_md.cccd_write_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_4_init.service_4_value_char_attr_md.read_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&service_4_init.service_4_value_char_attr_md.write_perm);
            err_code = ble_service_4_init(&m_service_4, &service_4_init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    void on_conn_params_evt(ble_conn_params_evt_t * p_evt)
    /**@brief Function for handling a Connection Parameters error.
    void conn_params_error_handler(uint32_t nrf_error)
    void conn_params_init(void)
    /**@brief Function for the Peer Manager initialization.
    void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    void pm_evt_handler(pm_evt_t const * p_evt)
        switch (p_evt->evt_id)
            case PM_EVT_BONDED_PEER_CONNECTED:
                NRF_LOG_INFO("Connected to a previously bonded device.");
            } break;
            case PM_EVT_CONN_SEC_SUCCEEDED:
                NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                /* Often, when securing fails, it shouldn't be restarted, for security reasons.
                 * Other times, it can be restarted directly.
                 * Sometimes it can be restarted, but only after changing some Security Parameters.
                 * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
                 * Sometimes it is impossible, to secure the link, or the peer device does not support it.
                 * How to handle this error is highly application dependent. */
            } break;
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
            } break;
            case PM_EVT_STORAGE_FULL:
                // Run garbage collection on the flash.
                err_code = fds_gc();
                if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                    // Retry.
            } break;
                advertising_start(false);
            } break;
            case PM_EVT_PEER_DATA_UPDATE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
            } break;
            case PM_EVT_PEER_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
            } break;
            case PM_EVT_PEERS_DELETE_FAILED:
                // Log error occurrence for PM_EVT_PEERS_DELETE_FAILED
                NRF_LOG_INFO("PM_EVT_PEERS_DELETE_FAILED occurred. Connection handle = %d\n", p_evt->conn_handle);
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
            } break;
            case PM_EVT_ERROR_UNEXPECTED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
            } break;
            case PM_EVT_CONN_SEC_START:
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            case PM_EVT_PEER_DELETE_SUCCEEDED:
            case PM_EVT_LOCAL_DB_CACHE_APPLIED:
            case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
                // This can happen when the local DB has changed.
            case PM_EVT_SERVICE_CHANGED_IND_SENT:
            case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
    /**@brief Clear bond information from persistent storage.
    void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
    void advertising_start(bool erase_bonds)
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
            //ret_code_t err_code = ble_advertising_restart_without_whitelist(&m_advertising);
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
            printf("advertising_start error code = %d\n", err_code);
    void advertising_init(void)
        uint32_t             err_code;
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        // Try disabling timeout
    void on_adv_evt(ble_adv_evt_t ble_adv_evt)
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_IDLE:
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
        err_code = app_timer_create(&m_service_4_char_1_notification_timer_id, APP_TIMER_MODE_REPEATED, service_4_char_1_notification_timeout_handler);
        err_code = app_timer_create(&m_service_4_char_2_notification_timer_id, APP_TIMER_MODE_REPEATED, service_4_char_2_notification_timeout_handler);
        err_code = app_timer_create(&m_service_4_char_3_notification_timer_id, APP_TIMER_MODE_REPEATED, service_4_char_3_notification_timeout_handler);
        /* YOUR_JOB: Create any timers to be used by the application.
                     Below is an example of how to create a timer.
                     For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                     one.
           err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
           APP_ERROR_CHECK(err_code); */
    void service_4_char_1_notification_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        service_4_notification_timer_update_elapsed(&m_service_4, SERVICE_4_CHAR_1_UUID);
    void service_4_char_2_notification_timeout_handler(void * p_context)
        service_4_notification_timer_update_elapsed(&m_service_4, SERVICE_4_CHAR_2_UUID);
    void service_4_char_3_notification_timeout_handler(void * p_context)
        service_4_notification_timer_update_elapsed(&m_service_4, SERVICE_4_CHAR_3_UUID);
    void ble_process(void)
        bool erase_bonds = false;
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        peer_manager_init();
        // Start advertising for ble module. Erase_bonds is set to false to distinguish 1st advertising packet.
        // If erase_bonds is set to true, advertising will start again but it will come from
        // PM_EVT_PEERS_DELETED_SUCEEDED
        advertising_start(erase_bonds);
        //// Enter main loop.
        //for (;;)
        //    idle_state_handle();
    The ble_process function is called in our main loop when other peripherals have been initialized. Also, do we have hardware restrictions when running the NRF52832 with a S132 soft device?
  • Hello Simon,
    Do you have any other suggestions or ideas we may try? This issue has really blocked the development of our project.
    Sincerely,
    Marvin Neil
  • Hi there
    First off, there shouldn't be any HW restrictions as long as you have followed our reference circuitry. We could do a HW review for you if you have the gerber files and schematics available. But I would suggest creating a private case for that.
    I'm afraid I got no specific things to check out based on your main file (which looks okay), but I have a few suggestions based on similar issues in the past.
    • What kind of debugger are you using? A DK or a J-Link device from SEGGER?
    • What backend are you using for logging if you're using logging at all? You can try disabling that altogether by setting NRF_LOG_ENABLED to 0 in your sdk_config.h file, and you can try inverting the NRF_LOG_BACKEND_RTT_ENABLED and NRF_LOG_BACKEND_UART_ENABLED defines (one of them is usually set to 0 while the other is 1).
    • It's also possible that your board is latched into SWD/debug mode when you power it up. If so, you might need a pulldown on the SWCLK pin, or try to power cycle the board entirely after flashing your application onto it.
    Simon
  • Hi Simon,
    Replying here to refer to the code snippet. We have finally resolved this concern by removing several printf and one of which is in line 577 of the code snippet above. Thanks for the quick responses.
    One question though. Is it safe to assume that printf function doesn't work with soft device or did we miss anything in the sdk_config.h?
  • Hi
    Glad you were able to find the source of the error. Normally,  if the printf doesn't work, it's caused by a missing retarget file. If you check out I.E. the ble_app_uart project you'll see that retarget.c is included and that the RETARGET_ENABLED define is set in sdk_config.h.
    // <q> RETARGET_ENABLED  - retarget - Retargeting stdio functions
    #ifndef RETARGET_ENABLED
    #define RETARGET_ENABLED 1
    Without these the  calls to printf will do nothing at all.
    Simon
