nrf sniffer on linux a window.
python example_linux.py
Opening serial port /dev/ttyACM0
args: ()
kwargs: {'callbacks': [('*', <bound method Notifier.passOnNotification of <Sniffer(Thread-2, initial)>>)]}
board ID (random): 195
Unable to read UART: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
root@Lenovo:/home/novello/zephyr-rtos/AoA/sniffer-3.1/extcap# ls -l /dev/ttyACM0
crw-rw-rw-+ 1 root dialout 166, 0 mag 20 12:33 /dev/ttyACM0
I Have installed nrf sniffer on nrf52840dk
with wireshark I see the interface but .... No data.
If  Use the above commad I see nothink the ttyACM0 is  ON
If I use a monitor (minicom I can see data)
There are some idea? What I have to check ?
Thanks.
  •  Hi giampiero novello,
    The problem is weird. I did not find any clue from your current sharing.
    I assume that you are following guidance from this page. Did anything wrong happen during your installation process?
    The issues could be either the nRF52840 Dongle running a wrong firmware or you did not set up Wireshark properly.
    Have you tried to run the sniffer before? How about trying it on a Win10?
    Charlie
