Undefined reference to `nrf_queue_write' - nRF52832
When I try basic usage of NRF Queue library I'm getting the following error:
SDK version is 15.3.0.
In sdk_config.h I've enabled the NRF Queue like you can see in the code below:
// <e> NRF_QUEUE_ENABLED - nrf_queue - Queue module
#ifndef NRF_QUEUE_ENABLED
#define NRF_QUEUE_ENABLED 1
// <q> NRF_QUEUE_CLI_CMDS  - Enable CLI commands specific to the module
#ifndef NRF_QUEUE_CLI_CMDS
#define NRF_QUEUE_CLI_CMDS 1
// </e>
My code of library usage is shown below:
#include "nrf_queue.h"
NRF_QUEUE_DEF(uint8_t, m_events_queue, 200, NRF_QUEUE_MODE_OVERFLOW);
NRF_QUEUE_INTERFACE_DEC(uint8_t, events_queue);
NRF_QUEUE_INTERFACE_DEF(uint8_t, events_queue, &m_events_queue)
ret_code_t ring_buffer_put(char *data, size_t len) {
    ret_code_t err_code;
    err_code = events_queue_write(data, len);
    return err_code;
    Have you added the corresponding library source file to your project?
    In your case it is components/libraries/queue/nrf_queue.c components/libraries/queue/nrf_queue.h
  • Hi, thank you for the help. Now I don't have the error above but I got a new one:
    undefined reference to `nrf_cli_fprintf'
    \components\libraries\queue/nrf_queue.c:66: undefined reference to `nrf_cli_help_print'
    \components\libraries\queue/nrf_queue.c:72: undefined reference to `nrf_cli_fprintf'
    I've added the nrf_cli in the project. Below you can see my project configuration file:
    <!DOCTYPE CrossStudio_Project_File>
    <solution Name="project1_pca10056_s140" target="8" version="2">
      <project Name="project1_pca10056_s140">
        <configuration
          Name="Common"
          arm_architecture="v7EM"
          arm_core_type="Cortex-M4"
          arm_endian="Little"
          arm_fp_abi="Hard"
          arm_fpu_type="FPv4-SP-D16"
          arm_linker_heap_size="8192"
          arm_linker_process_stack_size="0"
          arm_linker_stack_size="8192"
          arm_linker_treat_warnings_as_errors="No"
          arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
          arm_target_device_name="nRF52840_xxAA"
          arm_target_interface_type="SWD"
          c_preprocessor_definitions="BOARD_PCA10056;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52840_XXAA;NRF_SD_BLE_API_VERSION=6;S140;SOFTDEVICE_PRESENT;SWI_DISABLE0;"
          c_user_include_directories="../../../config;../../../../components;../../../../components/ble/ble_advertising;../../../../components/ble/ble_dtm;../../../../components/ble/ble_racp;../../../../components/ble/ble_services/ble_ancs_c;../../../../components/ble/ble_services/ble_ans_c;../../../../components/ble/ble_services/ble_bas;../../../../components/ble/ble_services/ble_bas_c;../../../../components/ble/ble_services/ble_cscs;../../../../components/ble/ble_services/ble_cts_c;../../../../components/ble/ble_services/ble_dfu;../../../../components/ble/ble_services/ble_dis;../../../../components/ble/ble_services/ble_gls;../../../../components/ble/ble_services/ble_hids;../../../../components/ble/ble_services/ble_hrs;../../../../components/ble/ble_services/ble_hrs_c;../../../../components/ble/ble_services/ble_hts;../../../../components/ble/ble_services/ble_ias;../../../../components/ble/ble_services/ble_ias_c;../../../../components/ble/ble_services/ble_lbs;../../../../components/ble/ble_services/ble_lbs_c;../../../../components/ble/ble_services/ble_lls;../../../../components/ble/ble_services/ble_nus;../../../../components/ble/ble_services/ble_nus_c;../../../../components/ble/ble_services/ble_rscs;../../../../components/ble/ble_services/ble_rscs_c;../../../../components/ble/ble_services/ble_tps;../../../../components/ble/common;../../../../components/ble/nrf_ble_gatt;../../../../components/ble/nrf_ble_qwr;../../../../components/ble/peer_manager;../../../../components/boards;../../../../components/libraries/atomic;../../../../components/libraries/atomic_fifo;../../../../components/libraries/atomic_flags;../../../../components/libraries/balloc;../../../../components/libraries/bootloader/ble_dfu;../../../../components/libraries/bsp;../../../../components/libraries/button;../../../../components/libraries/cli;../../../../components/libraries/crc16;../../../../components/libraries/crc32;../../../../components/libraries/crypto;../../../../components/libraries/csense;../../../../components/libraries/csense_drv;../../../../components/libraries/delay;../../../../components/libraries/ecc;../../../../components/libraries/experimental_section_vars;../../../../components/libraries/experimental_task_manager;../../../../components/libraries/fds;../../../../components/libraries/fstorage;../../../../components/libraries/gfx;../../../../components/libraries/gpiote;../../../../components/libraries/hardfault;../../../../components/libraries/hci;../../../../components/libraries/led_softblink;../../../../components/libraries/log;../../../../components/libraries/log/src;../../../../components/libraries/low_power_pwm;../../../../components/libraries/mem_manager;../../../../components/libraries/memobj;../../../../components/libraries/mpu;../../../../components/libraries/mutex;../../../../components/libraries/pwm;../../../../components/libraries/pwr_mgmt;../../../../components/libraries/queue;../../../../components/libraries/ringbuf;../../../../components/libraries/scheduler;../../../../components/libraries/sdcard;../../../../components/libraries/sensorsim;../../../../components/libraries/slip;../../../../components/libraries/sortlist;../../../../components/libraries/spi_mngr;../../../../components/libraries/stack_guard;../../../../components/libraries/strerror;../../../../components/libraries/svc;../../../../components/libraries/timer;../../../../components/libraries/twi_mngr;../../../../components/libraries/twi_sensor;../../../../components/libraries/usbd;../../../../components/libraries/usbd/class/audio;../../../../components/libraries/usbd/class/cdc;../../../../components/libraries/usbd/class/cdc/acm;../../../../components/libraries/usbd/class/hid;../../../../components/libraries/usbd/class/hid/generic;../../../../components/libraries/usbd/class/hid/kbd;../../../../components/libraries/usbd/class/hid/mouse;../../../../components/libraries/usbd/class/msc;../../../../components/libraries/util;../../../../components/nfc/ndef/conn_hand_parser;../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser;../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;../../../../components/nfc/ndef/connection_handover/ac_rec;../../../../components/nfc/ndef/connection_handover/ble_oob_advdata;../../../../components/nfc/ndef/connection_handover/ble_pair_lib;../../../../components/nfc/ndef/connection_handover/ble_pair_msg;../../../../components/nfc/ndef/connection_handover/common;../../../../components/nfc/ndef/connection_handover/ep_oob_rec;../../../../components/nfc/ndef/connection_handover/hs_rec;../../../../components/nfc/ndef/connection_handover/le_oob_rec;../../../../components/nfc/ndef/generic/message;../../../../components/nfc/ndef/generic/record;../../../../components/nfc/ndef/launchapp;../../../../components/nfc/ndef/parser/message;../../../../components/nfc/ndef/parser/record;../../../../components/nfc/ndef/text;../../../../components/nfc/ndef/uri;../../../../components/nfc/t2t_lib;../../../../components/nfc/t2t_parser;../../../../components/nfc/t4t_lib;../../../../components/nfc/t4t_parser/apdu;../../../../components/nfc/t4t_parser/cc_file;../../../../components/nfc/t4t_parser/hl_detection_procedure;../../../../components/nfc/t4t_parser/tlv;../../../../components/softdevice/common;../../../../components/softdevice/s140/headers;../../../../components/softdevice/s140/headers/nrf52;../../../../components/toolchain/cmsis/include;../../../../external/fprintf;../../../../external/segger_rtt;../../../../external/utf_converter;../../../../integration/nrfx;../../../../integration/nrfx/legacy;../../../../modules/nrfx;../../../../modules/nrfx/drivers/include;../../../../modules/nrfx/hal;../../../../modules/nrfx/mdk;../config;"
          debug_additional_load_file="../../../../components/softdevice/s140/hex/s140_nrf52_6.1.1_softdevice.hex"
          debug_register_definition_file="../../../../modules/nrfx/mdk/nrf52840.svd"
          debug_start_from_entry_point_symbol="No"
          debug_target_connection="J-Link"
          gcc_debugging_level="Level 3"
          gcc_entry_point="Reset_Handler"
          linker_output_format="hex"
          linker_printf_fmt_level="long"
          linker_printf_width_precision_supported="Yes"
          linker_scanf_fmt_level="long"
          linker_section_placement_file="flash_placement.xml"
          linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x100000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x40000;FLASH_START=0x26000;FLASH_SIZE=0xda000;RAM_START=0x20002260;RAM_SIZE=0x3dda0"
          linker_section_placements_segments="FLASH RX 0x0 0x100000;RAM RWX 0x20000000 0x40000"
          macros="CMSIS_CONFIG_TOOL=../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
          project_directory=""
          project_type="Executable" />
        <folder Name="Segger Startup Files">
          <file file_name="$(StudioDir)/source/thumb_crt0.s" />
        </folder>
        <folder Name="nRF_Log">
          <file file_name="../../../../components/libraries/log/src/nrf_log_backend_rtt.c" />
          <file file_name="../../../../components/libraries/log/src/nrf_log_backend_serial.c" />
          <file file_name="../../../../components/libraries/log/src/nrf_log_backend_uart.c" />
          <file file_name="../../../../components/libraries/log/src/nrf_log_default_backends.c" />
          <file file_name="../../../../components/libraries/log/src/nrf_log_frontend.c" />
          <file file_name="../../../../components/libraries/log/src/nrf_log_str_formatter.c" />
        </folder>
        <folder Name="nRF_Libraries">
          <file file_name="../../../../components/libraries/button/app_button.c" />
          <file file_name="../../../../components/libraries/util/app_error.c" />
          <file file_name="../../../../components/libraries/util/app_error_handler_gcc.c" />
          <file file_name="../../../../components/libraries/util/app_error_weak.c" />
          <file file_name="../../../../components/libraries/scheduler/app_scheduler.c" />
          <file file_name="../../../../components/libraries/timer/app_timer.c" />
          <file file_name="../../../../components/libraries/util/app_util_platform.c" />
          <file file_name="../../../../components/libraries/crc16/crc16.c" />
          <file file_name="../../../../components/libraries/fds/fds.c" />
          <file file_name="../../../../components/libraries/hardfault/hardfault_implementation.c" />
          <file file_name="../../../../components/libraries/util/nrf_assert.c" />
          <file file_name="../../../../components/libraries/atomic_fifo/nrf_atfifo.c" />
          <file file_name="../../../../components/libraries/atomic_flags/nrf_atflags.c" />
          <file file_name="../../../../components/libraries/atomic/nrf_atomic.c" />
          <file file_name="../../../../components/libraries/balloc/nrf_balloc.c" />
          <file file_name="../../../../external/fprintf/nrf_fprintf.c" />
          <file file_name="../../../../external/fprintf/nrf_fprintf_format.c" />
          <file file_name="../../../../components/libraries/fstorage/nrf_fstorage.c" />
          <file file_name="../../../../components/libraries/fstorage/nrf_fstorage_sd.c" />
          <file file_name="../../../../components/libraries/memobj/nrf_memobj.c" />
          <file file_name="../../../../components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
          <file file_name="../../../../components/libraries/ringbuf/nrf_ringbuf.c" />
          <file file_name="../../../../components/libraries/experimental_section_vars/nrf_section_iter.c" />
          <file file_name="../../../../components/libraries/strerror/nrf_strerror.c" />
          <file file_name="../../../../components/libraries/sensorsim/sensorsim.c" />
          <file file_name="../../../../components/libraries/queue/nrf_queue.c" />
          <file file_name="../../../../components/libraries/cli/nrf_cli.c" />
        </folder>
        <folder Name="None">
          <file file_name="../../../../modules/nrfx/mdk/ses_startup_nrf52840.s" />
          <file file_name="../../../../modules/nrfx/mdk/ses_startup_nrf_common.s" />
          <file file_name="../../../../modules/nrfx/mdk/system_nrf52840.c" />
        </folder>
        <folder Name="Board Definition">
          <file file_name="../../../../components/boards/boards.c" />
        </folder>
        <folder Name="nRF_Drivers">
          <file file_name="../../../../integration/nrfx/legacy/nrf_drv_clock.c" />
          <file file_name="../../../../integration/nrfx/legacy/nrf_drv_uart.c" />
          <file file_name="../../../../modules/nrfx/soc/nrfx_atomic.c" />
          <file file_name="../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
          <file file_name="../../../../modules/nrfx/drivers/src/nrfx_gpiote.c" />
          <file file_name="../../../../modules/nrfx/drivers/src/prs/nrfx_prs.c" />
          <file file_name="../../../../modules/nrfx/drivers/src/nrfx_uart.c" />
          <file file_name="../../../../modules/nrfx/drivers/src/nrfx_uarte.c" />
        </folder>
        <folder Name="Board Support">
          <file file_name="../../../../components/libraries/bsp/bsp.c" />
          <file file_name="../../../../components/libraries/bsp/bsp_btn_ble.c" />
        </folder>
        <folder Name="Application">
          <file file_name="../../../main.c" />
          <file file_name="../config/sdk_config.h" />
          <file file_name="../../../ble_tds.c" />
          <file file_name="../../../ble_tds.h" />
          <file file_name="../../../nrf_time.c" />
          <file file_name="../../../nrf_time.h" />
          <file file_name="../../../ring_buffer.c" />
          <file file_name="../../../ring_buffer.h" />
        </folder>
        <folder Name="nRF_Segger_RTT">
          <file file_name="../../../../external/segger_rtt/SEGGER_RTT.c" />
          <file file_name="../../../../external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
          <file file_name="../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
        </folder>
        <folder Name="nRF_BLE">
          <file file_name="../../../../components/ble/peer_manager/auth_status_tracker.c" />
          <file file_name="../../../../components/ble/common/ble_advdata.c" />
          <file file_name="../../../../components/ble/ble_advertising/ble_advertising.c" />
          <file file_name="../../../../components/ble/common/ble_conn_params.c" />
          <file file_name="../../../../components/ble/common/ble_conn_state.c" />
          <file file_name="../../../../components/ble/common/ble_srv_common.c" />
          <file file_name="../../../../components/ble/peer_manager/gatt_cache_manager.c" />
          <file file_name="../../../../components/ble/peer_manager/gatts_cache_manager.c" />
          <file file_name="../../../../components/ble/peer_manager/id_manager.c" />
          <file file_name="../../../../components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
          <file file_name="../../../../components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
          <file file_name="../../../../components/ble/peer_manager/peer_data_storage.c" />
          <file file_name="../../../../components/ble/peer_manager/peer_database.c" />
          <file file_name="../../../../components/ble/peer_manager/peer_id.c" />
          <file file_name="../../../../components/ble/peer_manager/peer_manager.c" />
          <file file_name="../../../../components/ble/peer_manager/peer_manager_handler.c" />
          <file file_name="../../../../components/ble/peer_manager/pm_buffer.c" />
          <file file_name="../../../../components/ble/peer_manager/security_dispatcher.c" />
          <file file_name="../../../../components/ble/peer_manager/security_manager.c" />
        </folder>
        <folder Name="UTF8/UTF16 converter">
          <file file_name="../../../../external/utf_converter/utf.c" />
        </folder>
        <folder Name="nRF_SoftDevice">
          <file file_name="../../../../components/softdevice/common/nrf_sdh.c" />
          <file file_name="../../../../components/softdevice/common/nrf_sdh_ble.c" />
          <file file_name="../../../../components/softdevice/common/nrf_sdh_soc.c" />
        </folder>
      </project>
      <configuration
        Name="Release"
        c_preprocessor_definitions="NDEBUG"
        gcc_optimization_level="Optimize For Size" />
      <configuration
        Name="Debug"
        c_preprocessor_definitions="DEBUG; DEBUG_NRF"
        gcc_optimization_level="None" />
    </solution>
  • What about this portion in sdk_config.h
    // <q> NRF_CLI_ENABLED  - Enable/disable the CLI module.
    #ifndef NRF_CLI_ENABLED
    #define NRF_CLI_ENABLED 0
  • I think in my case it is set to 0, will double check that as soon as I get to the code.
    What value is correct?
  • in sdk_config.h by default it is disabled. In your case, you have to use the API's inside nrf_cli.c, so you have to enable the corresponding configuration in config.h file as like following
    #define NRF_CLI_ENABLED 1
  • Thank you. That solved my issue, it would be nice if that can be added in the documentation like the two configuration on: infocenter.nordicsemi.com/index.jsp
