Unwanted bonding (BLE)
Hello
I have developed an application on my nRF52840 which allows a smartphone to be able to connect in secure BLE.
Everything works fine but I notice that every time I do a "pairing" via an Android smartphone, that the smartphone "bonds" the device even though I specified in the request that I did not want bondage.. I don't have this problem on IOS.
I have tested with your examples and nRF Connect and have the same behavior.
Here is how I defined my peer_manager:
void peer_manager_init(bool erase_bonds)
    ret_code_t err_code;
    err_code = pm_init();
    if (erase_bonds)
        err_code = pm_peers_delete();
    sec_param.bond = false;//true;
    sec_param.mitm = false;
    sec_param.lesc = 1;
    sec_param.keypress = 0;
    sec_param.io_caps = BLE_GAP_IO_CAPS_NONE;
    sec_param.oob = false;
    sec_param.min_key_size = 7;
    sec_param.max_key_size = 16;
    sec_param.kdist_own.enc = 0;//1;
    sec_param.kdist_own.id = 0;//1;
    sec_param.kdist_peer.enc = 0;//1;
    sec_param.kdist_peer.id = 0;//1;
Could you test with your smartphones to see if your android also creates a "bond" even if you specified "no bonding" in your security request? (it is to know if it is an android bug or at home?)
  Secure connection and non secure connection.pcapng
Thank you
