set PASSKEY to 4 digits
We are using a passkey in our application and by default is 6 digits long. I have found in other posts that this is mandatory a cannot be changed.
Is it real?
the strange thing is that both iOS and Android suggest a 4 digit PIN by default when trying to pair with our device. Therefore my client is a bit annoyed that the APP suggest a 4 digits pin and he has to put a 6 digits instead.
here the snippet of the code I am using:
#define BLE_DEFAULT_PASSKEY "000000"
//set defaul passkey
uint8_t passkey[] = BLE_DEFAULT_PASSKEY;
ble_opt_t ble_opt;
ble_opt.gap_opt.passkey.p_passkey = passkey;
err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &ble_opt);
Thanks and Regards!
    Is it real?
     Yes.
    From BLUETOOTH CORE SPECIFICATION Version 5.2 | Vol 3, Part C page 1289 , https://www.bluetooth.com/specifications/specs/core-specification/
    For Secure Simple Pairing and Security Manager, the Bluetooth passkey is a 6-
    digit numerical value.
    In BR/EDR Legacy Pairing it was possible to use a 4-digit PIN, but this is not possible with Bluetooth Low Energy.
    From BLUETOOTH CORE SPECIFICATION Version 5.2 | Vol 1, Part A page 271
    Secure Simple Pairing has two security goals: protection against passive
    eavesdropping and protection against man-in-the-middle (MITM) attacks
    (active eavesdropping). It is a goal of Secure Simple Pairing to exceed the
    maximum security level provided by the use of a 16 character, alphanumeric,
    case-sensitive PIN with BR/EDR Legacy Pairing, which often used a 4-digit
    PIN or a fixed PIN of commonly known values significantly limiting the security
    on the link.
