Zephyr crash: Civetweb webserver on nRF9160DK with hardware networking
My task is to create a webserver on the nRF9160DK. For this i'm using the civetweb module provided by zephyr and the ethernet-shield from PHYTEC. I got an issue i want to discuss here, so i explain my thoughts here step by step, since this is my first post in this community and i'm quite new to zephyr.
In the beginning i tried to setup the civetweb webserver on the recommended target for the http_server example from vanilla zephyr, the Atmel SAM E70 Xplained. Beside for some unrelated issues i posted here, i got the webserver up and running and even successful implemented some necessary tests for my project, for example DHCP-support.
Next step was switching to the end-target, the nRF9160. I installed the nrf-connect SDK v1.5.0 and the zephyr SDK v2.4.99 according to the getting started guide. Since this board does not have any hardware-networking, i decided to integrate the PHYTEC link board eth since it is supported by the zephyr OS. For this i had to change the .overlay file of the link_board to make it suitable for the nRF9160DK.
link_board_eth.overlay @ zephyr/boards/shields/link_board_eth
&spi3 {
	status = "okay";
	cs-gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;	// D10
	sck-pin = <13>;
    mosi-pin = <11>;
    miso-pin = <12>;
	enc424j600@0 {
		compatible = "microchip,enc424j600";
		spi-max-frequency = <14000000>;
		int-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>;	// D9
		status = "okay";
		label = "ETH_0";
		reg = <0>;
Since the webserver requires more RAM than there is available in the secure-partition, i builded the project for the non-secure version of the nRF9160DK. With the following command, i was able to compile the project.
west build -b nrf9160dk_nrf9160ns %PATH_TO_PROJECT% -DSHIELD=link_board_eth
Now i'll show the output of the building process.
Including boilerplate (Zephyr base): C:/local/nordic_zephyr/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/local/%PATH_TO_PROJECT%
-- Zephyr version: 2.4.99 (C:/local/nordic_zephyr/zephyr)
-- Found Python3: C:/Python39/python.exe (found suitable exact version "3.9.2") found components: Interpreter
-- Found west (found suitable version "0.10.1", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160ns, Revision: 0.7.0, Shield(s): link_board_eth
-- Cache files will be written to: C:/local/nordic_zephyr/zephyr/.cache
-- Found dtc: C:/ProgramData/chocolatey/bin/dtc.exe (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/gnuarmemb)
-- Found BOARD.dts: C:/local/nordic_zephyr/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
-- Found devicetree overlay: C:/local/nordic_zephyr/zephyr/boards/shields/link_board_eth/link_board_eth.overlay
nrf9160dk_nrf9160ns.dts.pre.tmp:366.32-370.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property
nrf9160dk_nrf9160ns.dts.pre.tmp:59.42-71.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
nrf9160dk_nrf9160ns.dts.pre.tmp:311.19-317.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
-- Generated zephyr.dts: C:/local/nordic_zephyr/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/local/nordic_zephyr/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/local/nordic_zephyr/build/zephyr/include/generated/device_extern.h
Parsing C:/local/nordic_zephyr/zephyr/Kconfig
Loaded configuration 'C:/local/nordic_zephyr/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
Merged configuration 'C:/local/nordic_zephyr/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_0_7_0.conf'
Merged configuration 'C:/local/zephyrtest_2_5_0/webserverPlayground/webserver/prj.conf'
Configuration saved to 'C:/local/nordic_zephyr/build/zephyr/.config'
Kconfig header saved to 'C:/local/nordic_zephyr/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 8.3.1
-- The CXX compiler identification is GNU 8.3.1
-- Found assembler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm -  begin ===
-- Application: C:/local/nordic_zephyr/nrf/samples/spm
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found BOARD.dts: C:/local/nordic_zephyr/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: C:/local/nordic_zephyr/nrf/samples/spm/nrf9160dk_nrf9160.overlay
nrf9160dk_nrf9160.dts.pre.tmp:59.42-71.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@50000000/kmu@39000)
nrf9160dk_nrf9160.dts.pre.tmp:311.19-317.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
-- Generated zephyr.dts: C:/local/nordic_zephyr/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/local/nordic_zephyr/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/local/nordic_zephyr/build/spm/zephyr/include/generated/device_extern.h
Loaded configuration 'C:/local/nordic_zephyr/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/local/nordic_zephyr/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_0_7_0.conf'
Merged configuration 'C:/local/nordic_zephyr/nrf/samples/spm/prj.conf'
Merged configuration 'C:/local/nordic_zephyr/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
Merged configuration 'C:/local/nordic_zephyr/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/local/nordic_zephyr/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/local/nordic_zephyr/build/spm/zephyr/.config'
Kconfig header saved to 'C:/local/nordic_zephyr/build/spm/zephyr/include/generated/autoconf.h'
CMake Deprecation Warning at C:/local/nordic_zephyr/modules/lib/civetweb/CMakeLists.txt:2 (cmake_minimum_required):
  Compatibility with CMake < 2.8.12 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/local/nordic_zephyr/build/spm
=== child image spm -  end ===
  CMake.
-- Target architecture - arm
CMake Warning (dev) at C:/cmake-3.19.6-win64-x64/share/cmake-3.19/Modules/GNUInstallDirs.cmake:223 (message):
  Unable to determine default CMAKE_INSTALL_LIBDIR directory because no
  target architecture is known.  Please enable at least one language before
  including GNUInstallDirs.
  C:/local/nordic_zephyr/modules/lib/civetweb/CMakeLists.txt:53 (include)
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Enabling tests in the build - ON
-- Thread Stack Size - 102400
-- Enabling server executable - ON
-- Serve no static files - OFF
-- Disable CGI support - OFF
-- Disable caching support - OFF
-- C++ wrappers - OFF
-- IP Version 6 - OFF
-- Websockets support - OFF
-- Server statistics support - OFF
-- Memory Debugging - OFF
-- ASAN in debug mode - ON
-- Force x32 / x64 architecture - OFF
-- Lua CGI support - OFF
-- Executable installation - ON
-- Build if there are warnings - ON
-- Duktape CGI support - OFF
-- SSL support - ON
-- Compile for OpenSSL 1.1 API - OFF
-- Dynamically load SSL libraries - ON
-- Configuring C Compiler
-- Performing Test HAVE_C_FLAG_STD_C11
-- Performing Test HAVE_C_FLAG_STD_C11 - Failed
-- Performing Test HAVE_C_FLAG_STD_C99
-- Performing Test HAVE_C_FLAG_STD_C99 - Failed
-- Performing Test HAVE_C_FLAG_STD_C89
-- Performing Test HAVE_C_FLAG_STD_C89 - Failed
-- Performing Test HAVE_C_FLAG_FSANITIZE_UNDEFINED
-- Performing Test HAVE_C_FLAG_FSANITIZE_UNDEFINED - Failed
-- Performing Test HAVE_C_FLAG_FSANITIZE_ADDRESS
-- Performing Test HAVE_C_FLAG_FSANITIZE_ADDRESS - Failed
-- Performing Test HAVE_C_FLAG_COVERAGE
-- Performing Test HAVE_C_FLAG_COVERAGE - Failed
-- Configuring done
-- Generating done
[10/215] Performing build step for 'spm_subimage'
[196/201] Linking C executable zephyr\zephyr_prebuilt.elf
           FLASH:         32 KB        48 KB     66.67%
            SRAM:        8648 B        64 KB     13.20%
        IDT_LIST:          72 B         2 KB      3.52%
[201/201] Linking C executable zephyr\zephyr.elf
[209/215] Linking C executable zephyr\zephyr_prebuilt.elf
           FLASH:      153232 B       976 KB     15.33%
            SRAM:       89816 B       192 KB     45.68%
        IDT_LIST:         104 B         2 KB      5.08%
[215/215] Generating zephyr/merged.hex
After the successful build, i flashed the board and got the following console output.
*** Booting Zephyr OS build v2.4.99-ncs1  ***
Flash regions           Domain          Permissions
00 00 0x00000 0x08000   Secure          rwxl
01 31 0x08000 0x100000  Non-Secure      rwxl
Non-secure callable region 0 placed in flash region 0 with size 32.
SRAM region             Domain          Permissions
00 07 0x00000 0x10000   Secure          rwxl
08 31 0x10000 0x40000   Non-Secure      rwxl
Peripheral              Domain          Status
00 NRF_P0               Non-Secure      OK
01 NRF_CLOCK            Non-Secure      OK
02 NRF_RTC0             Non-Secure      OK
03 NRF_RTC1             Non-Secure      OK
04 NRF_NVMC             Non-Secure      OK
05 NRF_UARTE1           Non-Secure      OK
06 NRF_UARTE2           Secure          SKIP
07 NRF_TWIM2            Non-Secure      OK
08 NRF_SPIM3            Non-Secure      OK
09 NRF_TIMER0           Non-Secure      OK
10 NRF_TIMER1           Non-Secure      OK
11 NRF_TIMER2           Non-Secure      OK
12 NRF_SAADC            Non-Secure      OK
13 NRF_PWM0             Non-Secure      OK
14 NRF_PWM1             Non-Secure      OK
15 NRF_PWM2             Non-Secure      OK
16 NRF_PWM3             Non-Secure      OK
17 NRF_WDT              Non-Secure      OK
18 NRF_IPC              Non-Secure      OK
19 NRF_VMC              Non-Secure      OK
20 NRF_FPU              Non-Secure      OK
21 NRF_EGU1             Non-Secure      OK
22 NRF_EGU2             Non-Secure      OK
23 NRF_DPPIC            Non-Secure      OK
24 NRF_REGULATORS       Non-Secure      OK
25 NRF_GPIOTE1          Non-Secure      OK
SPM: NS image at 0xc000
SPM: NS MSP at 0x2001fea8
SPM: NS reset vector at 0x10c59
SPM: prepare to jump to Non-Secure image.
[00:00:00.003,692] <inf> ethdrv: Link down
[00:00:00.003,784] <inf> ethdrv: ENC424J600 Initialized
[00:00:00.007,934] <inf> net_config: Initializing network
[00:00:00.007,965] <inf> net_config: Waiting interface 1 (0x200148b8) to be up...
[00:00:01.673,034] <inf> ethdrv: Link up
[00:00:01.673,278] <inf> ethdrv: 100Mbps
[00:00:01.673,309] <inf> ethdrv: full duplex
[00:00:01.673,492] <inf> ethdrv: Not suspended
[00:00:01.673,522] <inf> net_config: Interface 1 (0x200148b8) coming up
[00:00:01.673,553] <inf> net_config: Running dhcpv4 client...
[00:00:01.720,458] <dbg> lib_extensions.sscanf: [IMPLEMENTATION MISSING : sscanf]
[00:00:06.901,611] <inf> net_dhcpv4: Received: 192.168.0.171
[00:00:06.901,733] <inf> net_config: IPv4 address: 192.168.0.171
[00:00:06.901,733] <inf> net_config: Lease time: 3600 seconds
[00:00:06.901,763] <inf> net_config: Subnet: 255.255.255.0
[00:00:06.901,794] <inf> net_config: Router: 192.168.0.1
Except for the information about the flash, RAM and peripherals, the previous used Atmel-Board showed a similar output. Quite exiting i tried to access the webserver over webbrowser with the IP address, but then zephyr crashes with the following message.
[00:07:41.357,604] <err> os: ***** USAGE FAULT *****
[00:07:41.357,635] <err> os:   Stack overflow (context area not valid)
[00:07:41.357,635] <err> os: r0/a1:  0x20010554  r1/a2:  0x00026c74  r2/a3:  0x2001c908
[00:07:41.357,635] <err> os: r3/a4:  0x00000000 r12/ip:  0x200105c4 r14/lr:  0x00020a29
[00:07:41.357,666] <err> os:  xpsr:  0x61000000
[00:07:41.357,666] <err> os: Faulting instruction address (r15/pc): 0x000209d6
[00:07:41.357,666] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
[00:07:41.357,666] <err> os: Current thread: 0x20014ab8 (unknown)
For completeness i'll share my prj.conf which didn't change for the successfull tests with the Atmel-Board.
# General config
CONFIG_CIVETWEB=y
CONFIG_JSON_LIBRARY=y
# pthreads
CONFIG_POSIX_API=y
CONFIG_PTHREAD_IPC=y
CONFIG_POSIX_MQUEUE=y
# networking
CONFIG_NETWORKING=y
CONFIG_NET_IPV4=y
CONFIG_NET_TCP=y
CONFIG_NET_TCP_BACKLOG_SIZE=5
CONFIG_NET_SOCKETS=y
CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=16384
CONFIG_NET_TX_STACK_SIZE=2048
CONFIG_NET_RX_STACK_SIZE=2048
CONFIG_ISR_STACK_SIZE=4096
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_IDLE_STACK_SIZE=2048
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_NET_CONFIG_SETTINGS=y
CONFIG_NET_DHCPV4=y
CONFIG_NET_MAX_CONN=5
# logging
CONFIG_NET_LOG=y
CONFIG_LOG_STRDUP_BUF_COUNT=16
Can anyone help me with this issue? Does anyone has experience with the ethernet-shield from PHYTEC in combination with the nRF9160DK? Any suggestions appreciated Slight smile
  • I found the problem myself.
    With the thread-analyzer i could identify the problematic thread
    Thread analyze:
     0x20014b70          : STACK: unused 7784 usage 312 / 8096 (3 %); CPU: 0 %
     0x20014a60          : STACK: unused 7640 usage 456 / 8096 (5 %); CPU: 0 %
     thread_analyzer     : STACK: unused 116 usage 396 / 512 (77 %); CPU: 0 %
     rx_q[0]             : STACK: unused 1340 usage 708 / 2048 (34 %); CPU: 0 %
     tx_q[0]             : STACK: unused 1680 usage 368 / 2048 (17 %); CPU: 0 %
     net_mgmt            : STACK: unused 260 usage 508 / 768 (66 %); CPU: 0 %
     0x20014338          : STACK: unused 244 usage 556 / 800 (69 %); CPU: 0 %
     sysworkq            : STACK: unused 524 usage 500 / 1024 (48 %); CPU: 0 %
     idle 00             : STACK: unused 1968 usage 80 / 2048 (3 %); CPU: 94 %
    [00:00:08.219,268] <err> os: ***** USAGE FAULT *****
    [00:00:08.224,914] <err> os:   Stack overflow (context area not valid)
    [00:00:08.232,208] <err> os: r0/a1:  0x20010554  r1/a2:  0x00026354  r2/a3:  0x2001cb00
    [00:00:08.240,997] <err> os: r3/a4:  0x00000000 r12/ip:  0x200105c4 r14/lr:  0x00020179
    [00:00:08.249,786] <err> os:  xpsr:  0x61000000
    [00:00:08.255,065] <err> os: Faulting instruction address (r15/pc): 0x00020126
    [00:00:08.263,061] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00:00:08.271,057] <err> os: Current thread: 0x20014b70 (unknown)
    [00:00:08.277,923] <err> os: Halting system
    Since the problematic thread is "unknown" when zephyr crashes, i could identify the worker-thread from civetweb over the stack size. Pushing the stack size to 16384 solved the problem.
