I'm using SDK 16.0, Soft device 340 v6.1.1, chip nRF52833. Currently no bootloader loaded, but I do use the secure bootloader with light mods. BLE stack and ANT stack are disabled when this occurs. System is basically idle.
This is quite odd. This has been working fine up until this morning, and now I have not been able to solve it. As soon as fds_gc is called, I get a hard fault. I'm using fds with the sd backend. The writes/updates all work fine, but as soon as I call gc, fault.
The PC reported in app_error_weak is 0x5450, which is definitely in the softdevice. The id is 1, so soft device assert failed.
[I read a post that said the actual calling function was in the stack, SP + 0x14. I checked that, and the address is also in SD space: 0x2C331]
Can anyone tell me what assert is at 0x5450(or 0x2C331)? I've been using this setup for multiple projects, and no idea why this one just went south. I'm sure it is something dumb, but beating my head against the wall. Just knowing what assert failed would probably give me the answer.
I'm not writing that much data. I have two records, one is settings(40 bytes) and one is some statistics(72 bytes). All aligned properly. The records initialize fine. When the first statistic gets incremented, and the system is idle it attempts to update the record. This is successful. In the event call for the fds, on success a flag is set that gc is needed. When the system is idle, it tries to call gc. Instant hard fault.
Relevant SDK configs:
virtual pages: 5
virtual page size: 1024
using sd backend
fstorage max write size: 1024
fstorage max retries: 16
max users: 4 (only using 1 though)
Appreciate any insight!
