How to upgrate bootloader?
    I want to upgrate bootloader in my firmware.
IC: nRF52832
SDK: 17.02
I have finished my project, this project include boot + softdevice + app + settings,and it works well. But I forget to close the key p0.16 in bootloader project.
So I want to upgrate bootloader.
Can you give me some advice?
Thank you.
    The bootloader can be updates via DFU in the same way as an application. Note that the application will be deleted as part of a bootloader upgrade, so you should also upgrade the application in this case as a secondary step. When making a upgrade package for the bootloader, you use something like this:
    pkg generate --hw-version <your_hw_verion> --sd-req <softdevice_id> --bootloader-version <higher_number_than_before> --bootloader bootloader.hex --key-file key.pem bl_dfu_package.zip
    Then you do the DFU upgrade just like you would with only the app.
