Hi everyone,
I'm using NRF51822 controller for an application, to store 2 float variables in the memory using persistent storage manager feature.
However, when I try to update and then retrive these variables, it seems there is some memory corruption & I'm getting garbage values returned back after an update & read back.
Here is my sample code:
#include <pstorage.h>
uint8_t registore_for_mem(void)
param.block_size = 32;
param.block_count = 2;
param.cb = example_cb_handler;
retval = pstorage_register(¶m, &handle);
if (retval == NRF_SUCCESS)
// Registration successful.
return 1;
else if(retval==NRF_ERROR_INVALID_STATE)
// Failed to register, take corrective action.
return 0;
else if(retval==NRF_ERROR_NULL)
return 0;
else if(retval==NRF_ERROR_INVALID_PARAM)
return 0;
else if(retval==NRF_ERROR_NO_MEM)
return 0;
nrf_delay_ms(100);
uint8_t get_block_id(int block_no)
// Registration successfully completed, base_handle is identifier for allocated blocks....
if(block_no==0)
retval = pstorage_block_identifier_get(&handle, block_no, &block_handle1);
else if(block_no==1)
retval = pstorage_block_identifier_get(&handle, block_no, &block_handle2);
{ // Get Block Identifier successful.
return 1;
{ // Failed to get block id, take corrective action.
return 0;
return 0;
uint8_t store_mem_data(char* source_data,int no)
// Request to write 8 bytes to block at an offset of 20 bytes.
if(no==1)
retval = pstorage_store(&block_handle1, (uint8_t*)source_data, 4, 0);
else if(no==2)
retval = pstorage_store(&block_handle2, (uint8_t*)source_data, 4, 0);
//retval = pstorage_update(&block_handle, (uint8_t*)source_data, 4, 0);
// Store successfully requested. Wait for operation result.
return 1;
// Failed to request store, take corrective action.
return 0;
uint8_t read_mem_data(int no)
// Request to read 4 bytes from block at an offset of 12 bytes.
retval=0;
if(no==1)
retval = pstorage_load(dest_data, &block_handle1, 4, 0);
else if(no==2)
retval = pstorage_load(dest_data, &block_handle2, 4, 0);
// Load successful. Consume data.
return 1;
// Failed to load, take corrective action.}
return 0;
uint8_t clear_data(void)
// Request update of one blocks. Block size is 8bytes.
retval = pstorage_clear(&handle, 32*2);
return 1;
return 0;
return 0;
return 0;
return 0;
void main()
char dest_data[8] ;
pstorage_init();
do
status=registore_for_mem(); // Requesting for memory
} while(!status);
do
status=get_block_id(0); // Getting the Memory block ID which was allocated fo data1
} while(!status);
do
status=get_block_id(1); // Getting the Memory block ID which was allocated for data2
} while(!status);
do
status=store_mem_data("xxxx",1); // Stores the data into a particular location
} while(!status);
do
status=store_mem_data("yyyy",2); // Stores the data into a particular location
} while(!status);
do
status=read_mem_data(1); // Getting Data2 from requested Memory block
} while(!status);
do
status=read_mem_data(2); // Getting the Data1 from requested Memory block
} while(!status);
do
status=clear_data(); // Clears the memory location where data1 and data2 is stored
} while(!status);
do
status=store_mem_data("bbbb",1); // updating data into a particular location
} while(!status);
do
status=store_mem_data("aaaa",2); // updating the data into a particular location
} while(!status);
