few questions about bootloader settings
hello Nordic
i am working with nrf52832 soc with SDK 16.0, S132 V7.0.1
following this path:
https://devzone.nordicsemi.com/nordic/short-range-guides/b/software-development-kit/posts/getting-started-with-nordics-secure-dfu-bootloader
and this : https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_nrfutil%2FUG%2Fnrfutil%2Fnrfutil_settings_generate_display.html
1. when trying to read current setting of existing bootloader in the examples i get this:
C:\Nordik SDK\examples\dfu\secure_bootloader>nrfutil settings display pca10040_uart\ses\Output\Release\Exe\secure_bootloader_uart_mbr_pca10040.hex
Bad access at 0x7F000: not enough data to read 4 contiguous bytes
Usage: nrfutil settings display [OPTIONS] HEX_FILE
Error: Failed to parse .hex file: Bad access at 0xFF000: not enough data to read 4 contiguous bytes
why is that ?
2. if i generate a setting for the bootloader and i include the softdevice in the "nrf settings generate command (like so:  --softdevice FILE s132_nrf52_7.0.1_softdevice.hex)
do i still need to mergehex the bootloader with the s132 hex file ? considering that when i flash my application (using SEGGER) after erasing the nrf52832 i do not need to flash the softdevice separately
3. the settings generate command refers to application version, do i need to change the setting each time i change application version or it's name (considering the version is in the name) ?
4. if i mergehex the bootloader settings hex file with the bootloader hex file and i flash the bootloader without having an application flashed on the device, what will happen ? would i be able to flash the application via SEGGER normally or must i have the application hex flashed before the flashing of the bootloader or mergehex with the bootloader ?
that it for now
p.s. 5. in the dfu examples, what's the difference between pca10040_uart to pca10040_uart_debug can both be used for production also can they be used for a PCB not an nrf52832DK ?
hope to read from you soon
best regards
Ziv
    It seems the UART communication between the PC (nrfutil) and nRF is not working properly for some reason, so we need to digg into that.
    • Are you using a DK or custom board?
      • If DK, which DK?
      • If custom board, which pins do you use for UART and have you configured the bootloader to use the correct pins? Do you use flow control?
    • Have you used a logic analyzer to check the data on the UART lines? Is there any data exchange at all?
  • i don't think its the uart
    look at that:
    D:\Ziv\projects\Redent-Nova-FW>nrfutil dfu serial -pkg Redent_0.zip -p COM12
      [####################################]  100%
    Device programmed.
    D:\Ziv\projects\Redent-Nova-FW>nrfutil dfu serial -pkg Redent_1.zip -p COM12
      File "C:\Program Files (x86)\Python383\Scripts\nrfutil-script.py", line 11, in <module>
        load_entry_point('nrfutil==6.1.0', 'console_scripts', 'nrfutil')()
      File "c:\program files (x86)\python383\lib\site-packages\click\core.py", line 829, in __call__
        return self.main(*args, **kwargs)
      File "c:\program files (x86)\python383\lib\site-packages\click\core.py", line 782, in main
        rv = self.invoke(ctx)
      File "c:\program files (x86)\python383\lib\site-packages\click\core.py", line 1259, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "c:\program files (x86)\python383\lib\site-packages\click\core.py", line 1066, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "c:\program files (x86)\python383\lib\site-packages\click\core.py", line 610, in invoke
        return callback(*args, **kwargs)
      File "c:\program files (x86)\python383\lib\site-packages\nordicsemi\__main__.py", line 1055, in serial
        do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, serial_number, True,
      File "c:\program files (x86)\python383\lib\site-packages\nordicsemi\__main__.py", line 970, in do_serial
        dfu.dfu_send_images()
      File "c:\program files (x86)\python383\lib\site-packages\nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
        self._dfu_send_image(self.manifest.application)
      File "c:\program files (x86)\python383\lib\site-packages\nordicsemi\dfu\dfu.py", line 88, in _dfu_send_image
        self.dfu_transport.open()
      File "c:\program files (x86)\python383\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 214, in open
        raise NordicSemiException("No ping response after opening COM port")
    pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
    you can see that when there is no application yet, just softdevice and bootloader then the dfu on serial works and i check the application it is working and i am communicating with the application on the same serial.. next i give the application this command
    NRF_POWER->GPREGRET = 0xB1;
    NVIC_SystemReset();
    and then i close the comm on which i was communicating with the app so it will be free to preform the dfu
    and then i go to the terminal and try to dfu as can be seen above
    the generate pkg commands:
    nrfutil pkg generate --application Output\Pca10040_Debug\Exe\Redent_Nova.hex --application-version 1 --hw-version 52 --sd-req 0xCB --key-file bootloader\src\private.key Redent_1.zip
    Zip created at Redent_1.zip
    nrfutil pkg generate --application Output\Pca10040_Debug\Exe\Redent_Nova.hex --application-version 0 --hw-version 52 --sd-req 0xCB --key-file bootloader\src\private.key Redent_0.zip
    Zip created at Redent_0.zip
    I see you use the _debug bootloader, so it would be very interesting to see the RTT log. That way we could see if the device enters DFU mode after  you write to GPREGRET and reset or not. Does it? If not, what state is the bootloader in, seen from the log?
    By the way, please provide full logs and contexts going forward so I get the full picture when trying to understand what is going on.
  • i am not using _debug bootloader
    what you might look at "Pca10040_Debug" is a configuration of the app itself
    <configuration
        Name="Debug"
        c_preprocessor_definitions="DEBUG;DEBUG_NRF"
        gcc_optimization_level="None"
        hidden="Yes" />
      <configuration
        Name="Pca10040"
        c_preprocessor_definitions="BOARD_PCA10040"
        hidden="Yes" />
      <configuration
        Name="RedentPCB"
        c_preprocessor_definitions="REDENT_NOVA_BOARD;BOARD_CUSTOM=REDENT_NOVA_BOARD"
        hidden="Yes" />
      <configuration
        Name="Pca10040_Release"
        inherited_configurations="Pca10040;Release" />
      <configuration
        Name="Pca10040_Debug"
        inherited_configurations="Pca10040;Debug" />
    but i can try to so the same with the debug bootloader.. what do i need to configure to get the full log ?
  • You should definitely use the pca10040_uart_debug project in this case. That will be very useful. You do not need to do any configuration, just use the debug bootloader project instead of the non-debug project, and if you have made any changes in the "normal" bootloader, do the same in the _debug bootloader. Then simply use it. It has RTT logging enabled by default which will give a lot of information during boot and DFU upgrade.
