PPK2 handling of in-rush currents?
I have a card with some large capacitors in parallel with the VBAT line. How does the PPK2 work (in source mode) at board start-up where there might be a short in-rush current that might exceed the rated 1A? Does it limit the output current to 1A or will the PPK2 break down?
Is there a difference if I use the PPK2 amp meter mode together with an external supply (battery or supply generator) with regards to board start in-rush current that might go above 1A? Will it manage or break?
Peter
