Dear Nordic Community,
Help me in interfacing AT42QT2120 capacitive touch sensor to nrf52840 controller.
So what have you tried? Where are you stuck?
Remember that the AT42QT2120 - like any other external chip - neither knows nor cares what microcontroller you use.
The AT42QT2120 has an I2C interface; so all the AT42QT2120 requires is that you give it the correct sequence of Start Condition, Slave Address, etc, etc, as specified in its datasheet - and it will respond as specified in its datasheet.
https://www.microchip.com/wwwproducts/en/AT42qt2120
Similarly, the nRF52 I2C controller neither knows nor cares what slave(s) are connected to the bus: all it does is generate Start Condition, Slave Address, etc and receives responses, ACK/NACK, etc - as specified in its documentation:
https://infocenter.nordicsemi.com/topic/struct_nrf52/struct/nrf52840.html
There are TWI examples in the SDK - start with the TWI Scanner Example to verify that you can correctly address the peripheral:
infocenter.nordicsemi.com/.../twi_scanner_example.html
Thank you for your response Mr.Awneil.
