I have 2 nRF52840 DK but suddenly both are not showing on my PC. I have checked my data cable which is working fine on mobile and transferring data. I have also checked my port which is working fine.
What should I do?
Thanks!
What should I do?
Thanks!
Maybe it could be similiar to the issue reported here in this post: https://devzone.nordicsemi.com/f/nordic-q-a/73729/nrf5340-dk-doesn-t-work even though it's not the exact same board? Either way. Please make sure the switches are in their correct positions and let me know if LED5 is on or not.
Vidar
Yes, switches are in the same position and LED5 in off.
Bluetooth is advertising but not detected on PC.
Could you try see if the board gets detected if you keep the reset button pressed while powering on the board?
Yes it shows this screen
That's a good sign, that means the connection to the PC should be ok. Now, please try program the Jlink FW onto the board. You can download the jlink FW as a bin from the product file here: https://www.nordicsemi.com/Software-and-tools/Development-Kits/nRF52840-DK/Download#infotabs. After you have downloaded it, you can program it onto the board by copying the file to the BOOTLOADER drive.
Thanks, Problem Solved
