Thermostat cluster enable issue
Hi All,
I am developing product using nRF52840 and SDK nRF5_SDK_for_Thread_and_Zigbee_v3.0.0_d310e71.
This product is basically, using the Thermostat cluster and Zigbee protocol to communicate with the Zigbee gateway.
So, I referred light_bulb example and followed steps to enable "Thermostat cluster and attributes".
I have included the respective files also but I am unable to execute the below callback function case statement,
static zb_void_t zcl_device_cb(zb_uint8_t param)
    zb_uint8_t                       cluster_id;
    zb_uint8_t                       attr_id;
    zb_buf_t                       * p_buffer = ZB_BUF_FROM_REF(param);
    zb_zcl_device_callback_param_t * p_device_cb_param =
                     ZB_GET_BUF_PARAM(p_buffer, zb_zcl_device_callback_param_t);
    NRF_LOG_INFO("zcl_device_cb id %hd", p_device_cb_param->device_cb_id);
    /* Set default response value. */
    p_device_cb_param->status = RET_OK;
    switch (p_device_cb_param->device_cb_id)
        case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
            cluster_id = p_device_cb_param->cb_param.set_attr_value_param.cluster_id;
            attr_id    = p_device_cb_param->cb_param.set_attr_value_param.attr_id;
            if (cluster_id == ZB_ZCL_CLUSTER_ID_THERMOSTAT)
                uint16_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data16;
                NRF_LOG_INFO("thermostat local temperature: %d", value);
                if (attr_id == ZB_ZCL_ATTR_THERMOSTAT_LOCAL_TEMPERATURE_ID)
                    local_temperature_value(value);
                /* Other clusters can be processed here */
                NRF_LOG_INFO("Unhandled cluster attribute id: %d", cluster_id);
            p_device_cb_param->status = RET_ERROR;
    NRF_LOG_INFO("zcl_device_cb status: %hd", p_device_cb_param->status);
Also, I am attaching code for reference please let me know what else I forgot to enable the functions. It is urgent for me to solve this issue.
Radiator_nRF_v0.9.0.zip
And, with these attributes, for some of the commands, I need to implement custom attributes so if you share how to add custom attributes to this cluster.
Thanks in advance.
Rohit R
  • Hi Marte,
    Thank you for the response,
    To configure the device as a SED you must call zb_set_rx_on_when_idle(ZB_FALSE) in main, such as in the multi sensor example. This enables sleepy behavior and makes your device act as a Sleepy End Device.
    You are correct in that you must call zb_sleep_now() in zboss_signal_handler(), when receiving the signal ZB_COMMON_SIGNAL_CAN_SLEEP. Again, you should do as in the multi sensor example.
    - Okay, Noted.
     Yes, with SED you will use zb_sleep_now() to put the device and radio to sleep, and you can remove zb_osif_go_idle() from main.c. The function zb_osif_go_idle() is not really necessary to have in main.c if you are not using SED either, as it is already implemented in external/zboss/osif/zb_nrf52840_common.c. The only reason to use it in main.c is if you want to override the function to make it do something else than what it does in the implementation in zb_nrf52840_common.c.
    - Okay, Noted.
    You can read about the clock sources for the LFCLK controller here: LFCLK controller. Further down on that page you will find 32.768 kHz crystal oscillator (LFXO), where you can read about LFXO.
     You can see more about typical current consumption for nRF52840 in the electrical specification, where you can find information such as sleep current and radio transmitting/receiving current. The nRF52840 specification does not show the typical current for using LFXO, only LFRC, but the electrical specification for some of the other SoCs does, to show a comparison between using LFRC and LFXO as clock source:
    - Okay, I will check.
    I have noted down your points for configuring SED. And as per your previous post I have discussed your points about SED with my team. But  they are like we will test the current default code on custom hardware and check the current.
    - After testing default code on custom it gave us 3.9mA. This is too high. We are testing again on Dev-kit as well as custom. I will get back to you on result early.
    And they want device should wake up Zigbee commands( it must) as per client requirement. But since nordic developer are busy. I will wait for something can we do here. But need help as early as possible make system wake up on Zigbee command and sleep if no commands. - Need help for this.
    One more update from my end.
    - There is one feature in my device, that is perform "network leave or erase the current connect coordinator info"
    - To this what I done is, used zigbee_erase_persistent_storage() and set ZB_TRUE; this means by setting true it will erase the info.
    - I did the same but it not erasing nor performing NVIC_SystemReset() correctly.
    - My requirement is I have long button press which result in Reset of my STM8 board and that give me signal to nRF board (node) and I have perform erase info and softreset the device and start again.
    Let me know whether I have followed correct API to execute this erase info and NVIC_SystemReset() is for software?
    Thanks and Regards
    Rohit R
  • Hi Marte,
    As I said last post that I am getting 3.9mA current with this config as you explained me,
    zb_void_t zb_osif_go_idle(zb_void_t)
    //TODO: implement your own logic if needed
    zb_osif_wait_for_event();
    I have tested multiple times and gave me 3.9mA. My last reading 0.03 mA was not correct. My mistake while taking readings. But I need help to reduce current.
    Can you help me what could be the issue here?.
    After battery life calculation we came to conclusion that we need at least 30/ 35uA only nRF part. My nrf52840 node should give me 30 to 35uA.
    Please find the attached code, as per your instruction I made the changes in my code regarding sleepy end device. Let me know I have followed your all steps so that I can test the current for this. As I am getting higher current in previous code so decide to test this sleepy end device also. main.c file
     * Copyright (c) 2018 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup zigbee_examples_light_bulb main.c
     * @ingroup zigbee_examples
     * @brief Dimmable light sample (HA profile)
    #include "sdk_config.h"
    #include "zboss_api.h"
    #include "zb_mem_config_med.h"
    #include "zb_error_handler.h"
    #include "zb_nrf52840_internal.h"
    #include "zigbee_helpers.h"
    #include "bsp.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    /**User Include file*********/
    #include "uart_config.h"
    #include "gpio_config.h"
    #include "timer_config.h"
    #include "commands.h"
    #include "uart_statemachine.h"
    #include "app_flash_memory.h"
    #include "zb_custom1_thermostat.h"
    #include "custom_app_event.h"
    /**< Scan only one, predefined channel to find the coordinator. */
    #define IEEE_CHANNEL_MASK                (ZB_TRANSCEIVER_ALL_CHANNELS_MASK)    // (1l << ZIGBEE_CHANNEL)
    #define ERASE_PERSISTENT_CONFIG           ZB_FALSE                              /**< Do not erase NVRAM to save the network parameters after device reboot or power-off. */
    #define ZIGBEE_NETWORK_STATE_LED          BSP_BOARD_LED_2                       /**< LED indicating that light switch successfully joind ZigBee network. */
    #if !defined ZB_ED_ROLE
    #error Define ZB_ED_ROLE to compile End Device source code.
    * GLOBAL VARIABLES
    uint16_t ui16CurrentTemp =0, ui16OccupiedHeatSetpoint = 0, ui16UnOccupiedHeatSetpoint = 0;
    uint8_t  ui8LocalTemperatureCalibration = 0;
    uint32_t ui32HostflagsData = 0;
    bool boolSetTemperature = false;
    bool boolGetStatus = false;
    bool boolSetHostflags = false;
    bool boolSendDeviceConfig = false;
    *EXTERNAL VARIABLES
    extern bool boolReady;
    extern bool boolMCUInterrupt;
    extern bool boolSetCommand;
    extern uint8_t ui8SendDeviceConfig[BUFFER_SIZE];
    extern App_tsEventUart sAppUartEvent;
    extern E_StateMachineThermostat e_StateMachineThermostat;
    *FUNCTIONS
    /* Declare attribute list for Basic cluster. */
    ZB_ZCL_DECLARE_BASIC_ATTRIB_LIST_EXT(basic_attr_list,
                                         &m_dev_ctx.basic_attr.zcl_version,
                                         &m_dev_ctx.basic_attr.app_version,
                                         &m_dev_ctx.basic_attr.stack_version,
                                         &m_dev_ctx.basic_attr.hw_version,
                                         m_dev_ctx.basic_attr.mf_name,
                                         m_dev_ctx.basic_attr.model_id,
                                         m_dev_ctx.basic_attr.date_code,
                                         &m_dev_ctx.basic_attr.power_source,
                                         m_dev_ctx.basic_attr.location_id,
                                         &m_dev_ctx.basic_attr.ph_env,
                                         m_dev_ctx.basic_attr.sw_ver);
    /* Declare attribute list for Identify cluster. */
    ZB_ZCL_DECLARE_IDENTIFY_ATTRIB_LIST(identify_attr_list,
                                        &m_dev_ctx.identify_attr.identify_time);
    /**power attributes**/
    ZB_ZCL_DECLARE_POWER_CONFIG_BATTERY_ATTRIB_LIST_EXT(power_config_attr_list,
                                            &m_dev_ctx.power_attr.battery_voltage,
                                            &m_dev_ctx.power_attr.battery_size,
                                            &m_dev_ctx.power_attr.battery_quantity,
                                            &m_dev_ctx.power_attr.battery_rated_voltage,
                                            &m_dev_ctx.power_attr.battery_alarm_mask,
                                            &m_dev_ctx.power_attr.battery_voltage_min_threshold,
                                            &m_dev_ctx.power_attr.battery_percentage_remaining,
                                            &m_dev_ctx.power_attr.battery_voltage_threshold1,
                                            &m_dev_ctx.power_attr.battery_voltage_threshold2,
                                            &m_dev_ctx.power_attr.battery_voltage_threshold3,
                                            &m_dev_ctx.power_attr.battery_percentage_min_threshold,
                                            &m_dev_ctx.power_attr.battery_percentage_threshold1,
                                            &m_dev_ctx.power_attr.battery_percentage_threshold2,
                                            &m_dev_ctx.power_attr.battery_percentage_threshold3,
                                            &m_dev_ctx.power_attr.battery_alarm_state);
    ZB_ZCL_DECLARE_TIME_ATTRIB_LIST(time_attr_list,
                                    &m_dev_ctx.time_attr.timeId,
                                    &m_dev_ctx.time_attr.time_status,
                                    &m_dev_ctx.time_attr.time_zone,
                                    &m_dev_ctx.time_attr.dst_start,
                                    &m_dev_ctx.time_attr.dst_end,
                                    &m_dev_ctx.time_attr.dst_shift,
                                    &m_dev_ctx.time_attr.standard_time,
                                    &m_dev_ctx.time_attr.local_time,
                                    &m_dev_ctx.time_attr.last_settime,
                                    &m_dev_ctx.time_attr.valid_untilTime);
    /* Declare extended attribute list for Thermostat cluster. */
    ZB_ZCL_DECLARE_THERMOSTAT_ATTRIB_LIST_EXT(thermostat_attr_list,
                                              &m_dev_ctx.thermostat_attr.local_temperature,
                                              &m_dev_ctx.thermostat_attr.local_temperature_calibration,
                                              &m_dev_ctx.thermostat_attr.occupied_heating_setpoint,
                                              &m_dev_ctx.thermostat_attr.unoccupied_heating_setpoint,
                                              &m_dev_ctx.thermostat_attr.pi_heating_demand,
                                              &m_dev_ctx.thermostat_attr.min_heating_setpoint_limit,
                                              &m_dev_ctx.thermostat_attr.max_heating_setpoint_limit,
                                              &m_dev_ctx.thermostat_attr.remote_sensing,
                                              &m_dev_ctx.thermostat_attr.control_seq_of_operation,
                                              &m_dev_ctx.thermostat_attr.system_mode,
                                              &m_dev_ctx.thermostat_attr.trv_mode,
                                              &m_dev_ctx.thermostat_attr.set_valve_position,
                                              &m_dev_ctx.thermostat_attr.error,
                                              &m_dev_ctx.thermostat_attr.current_setpoint,
                                              &m_dev_ctx.thermostat_attr.host_flags);
    /* Declare cluster list for Thermostat device (Basic, Identify, Thermostat, Fan Control, Thermostat UI). */
    ZB_DECLARE_CUSTOM_THERMOSTAT_CLUSTER_LIST(thermostat_clusters,
                                          basic_attr_list,
                                          identify_attr_list,
                                          time_attr_list);
    ZB_HA_DECLARE_CUSTOM_THERMOSTAT_EP(thermostat_ep,
                                   THERMOSTAT_SENSOR_ENDPOINT,
                                   thermostat_clusters);
    ZB_HA_DECLARE_CUSTOM_THERMOSTAT_CTX(thermostat_ctx, thermostat_ep);
    /**@brief Function for initializing the application timer.
    static void timer_init(void)
        uint32_t error_code = app_timer_init();
        APP_ERROR_CHECK(error_code);
    static void log_init(void)
    /**@brief Function for initializing LEDs.
    static void leds_init(void)
    /**@brief Function for initializing all clusters attributes.
    static void thermostat_clusters_attr_init(void)
         /* Basic cluster attributes data */
         m_dev_ctx.basic_attr.zcl_version = ZB_ZCL_VERSION;
         m_dev_ctx.basic_attr.app_version = THERMOSTAT_INIT_BASIC_APP_VERSION;
         m_dev_ctx.basic_attr.stack_version = THERMOSTAT_INIT_BASIC_STACK_VERSION;
         m_dev_ctx.basic_attr.hw_version = THERMOSTAT_INIT_BASIC_HW_VERSION;
        /* Use ZB_ZCL_SET_STRING_VAL to set strings, because the first byte should
         * contain string length without trailing zero.
         * For example "test" string wil be encoded as:
         *   [(0x4), 't', 'e', 's', 't']
          ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.mf_name,
                              THERMOSTAT_INIT_BASIC_MANUF_NAME,
                              ZB_ZCL_STRING_CONST_SIZE(THERMOSTAT_INIT_BASIC_MANUF_NAME));
          ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.model_id,
                              THERMOSTAT_INIT_BASIC_MODEL_ID,
                              ZB_ZCL_STRING_CONST_SIZE(THERMOSTAT_INIT_BASIC_MODEL_ID));
          ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.date_code,
                              THERMOSTAT_INIT_BASIC_DATE_CODE,
                              ZB_ZCL_STRING_CONST_SIZE(THERMOSTAT_INIT_BASIC_DATE_CODE));
          m_dev_ctx.basic_attr.power_source = THERMOSTAT_INIT_BASIC_POWER_SOURCE;
          ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.location_id,
                              THERMOSTAT_INIT_BASIC_LOCATION_DESC,
                              ZB_ZCL_STRING_CONST_SIZE(THERMOSTAT_INIT_BASIC_LOCATION_DESC));
          m_dev_ctx.basic_attr.ph_env = THERMOSTAT_INIT_BASIC_PH_ENV;
          //m_dev_ctx.basic_attr.sw_ver = "00000000";
          memcpy( m_dev_ctx.basic_attr.sw_ver,"00000000", 8);
        /* Identify cluster attributes data */
        m_dev_ctx.identify_attr.identify_time        = ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
    //    /**power configuration attributes data**/
        m_dev_ctx.power_attr.battery_percentage_remaining = 0x02;
        m_dev_ctx.power_attr.battery_quantity = ZB_POWER_CONFIG_BATTERY_QUANTITY;
        m_dev_ctx.power_attr.battery_size = ZB_ZCL_POWER_CONFIG_BATTERY_SIZE_AA;
       /* Thermostat cluster attributes data */
        m_dev_ctx.thermostat_attr.local_temperature             = 0x07D0;
        m_dev_ctx.thermostat_attr.local_temperature_calibration = 0x00;
        m_dev_ctx.thermostat_attr.pi_heating_demand             = 0xFF;
        m_dev_ctx.thermostat_attr.occupied_heating_setpoint     = 0x07D0;
        m_dev_ctx.thermostat_attr.unoccupied_heating_setpoint   = 0x07D0;
        m_dev_ctx.thermostat_attr.min_heating_setpoint_limit    = 0x01F4;
        m_dev_ctx.thermostat_attr.max_heating_setpoint_limit    = 0x0BB8;
        m_dev_ctx.thermostat_attr.control_seq_of_operation      = ZB_ZCL_THERMOSTAT_CONTROL_SEQ_OF_OPERATION_HEATING_ONLY;
        m_dev_ctx.thermostat_attr.system_mode                   = ZB_ZCL_THERMOSTAT_SYSTEM_MODE_HEAT;
        m_dev_ctx.thermostat_attr.current_setpoint             = 0x0898;
        m_dev_ctx.thermostat_attr.trv_mode                     = ZB_ZCL_THERMOSTAT_TRV_MODE_DEFAULT_VALUE;
        m_dev_ctx.thermostat_attr.set_valve_position           = 0;
        m_dev_ctx.thermostat_attr.error                        = 0;
             /***time cluster attributes data**/
        m_dev_ctx.time_attr.timeId = ZB_ZCL_TIME_TIME_DEFAULT_VALUE;
        m_dev_ctx.time_attr.time_status = ZB_ZCL_TIME_TIME_STATUS_DEFAULT_VALUE;
        /*local temperature set attribute**/
       ZB_ZCL_SET_ATTRIBUTE(THERMOSTAT_SENSOR_ENDPOINT,
                            ZB_ZCL_CLUSTER_ID_THERMOSTAT,
                            ZB_ZCL_CLUSTER_SERVER_ROLE,
                            ZB_ZCL_ATTR_THERMOSTAT_LOCAL_TEMPERATURE_ID,
                            (zb_uint8_t *)&m_dev_ctx.thermostat_attr.local_temperature,
                            ZB_FALSE);
                            ZB_ZCL_ATTR_THERMOSTAT_OCCUPIED_HEATING_SETPOINT_ID,
                            (zb_uint8_t *)&m_dev_ctx.thermostat_attr.occupied_heating_setpoint,
                            ZB_FALSE);
                            ZB_ZCL_ATTR_THERMOSTAT_UNOCCUPIED_HEATING_SETPOINT_ID,
                            (zb_uint8_t *)&m_dev_ctx.thermostat_attr.unoccupied_heating_setpoint,
                            ZB_FALSE);
                             ZB_ZCL_ATTR_THERMOSTAT_HOST_FLAG_ID,
                             (zb_uint8_t *)&m_dev_ctx.thermostat_attr.host_flags,
                             ZB_FALSE);
                             ZB_ZCL_ATTR_THERMOSTAT_TRV_MODE_ID,
                             (zb_uint8_t *)& m_dev_ctx.thermostat_attr.trv_mode,
                             ZB_FALSE);
       /**Battery percentage value**/
                            ZB_ZCL_CLUSTER_ID_POWER_CONFIG,
                            ZB_ZCL_ATTR_POWER_CONFIG_BATTERY_REMAINING_ID,
                            (zb_uint8_t *)&m_dev_ctx.power_attr.battery_percentage_remaining,
                            ZB_FALSE);
                            ZB_ZCL_ATTR_POWER_CONFIG_BATTERY_QUANTITY_ID,
                            (zb_uint8_t *)&m_dev_ctx.power_attr.battery_quantity,
                            ZB_FALSE);
    /**@brief Function for local temperature
     * @param[in]   new_value local temp value
    void localTemperatureValue(zb_uint16_t ui16local_tempvalue)
       zb_zcl_status_t zcl_status;
       zcl_status = zb_zcl_set_attr_val(THERMOSTAT_SENSOR_ENDPOINT,
                                         (zb_uint8_t *)&ui16local_tempvalue ,
                                         ZB_FALSE);
       if(zcl_status != ZB_ZCL_STATUS_SUCCESS)
          NRF_LOG_INFO("Set local temperature value fail. zcl_status: %d", zcl_status);
    void CurrentSetpointChangeValue(zb_uint16_t ui16CurrentSetpoint)
                                        ZB_ZCL_ATTR_THERMOSTAT_CURRENT_SETPOINT_CHANGE_ID,
                                        (zb_uint8_t *)&ui16CurrentSetpoint,
                                        ZB_FALSE);
          NRF_LOG_INFO("Setc current set point temperature value fail. zcl_status: %d", zcl_status);
       if(ui16CurrentSetpoint != 0xFFFF)
          ui16CurrentTemp = ui16CurrentSetpoint;
          ui16CurrentTemp = 0xFFFF;
    **function to read/write the occupied heating setpoint
    **Any change in occupied heating value will automatically copied to set point change attribute
    void OccupiedHeatingSetpoint(zb_uint16_t ui16OccupiedSetpoint)
                                        (zb_uint8_t *)&ui16OccupiedSetpoint,
                                        ZB_FALSE);
       if(ui16OccupiedSetpoint != 0xFFFF)
          ui16OccupiedHeatSetpoint = ui16OccupiedSetpoint;
          ui16CurrentTemp = ui16OccupiedSetpoint;
          CurrentSetpointChangeValue(ui16CurrentTemp);
          ui16OccupiedHeatSetpoint == 0xFFFF;
          NRF_LOG_INFO("Set occupied heating setpoint temperature value fail. zcl_status: %d", zcl_status);
    void ReadOccupiedHeatingSetpoint(zb_uint16_t ui16ReadOccupiedSetpoint)
                                        (zb_uint8_t *)&ui16ReadOccupiedSetpoint,
                                        ZB_FALSE);
    **function to read/write the unoccupied heating setpoint
    **Any change in unoccupied heating value will automatically copied to set point change attribute
    void UnOccupiedHeatingSetpoint(zb_uint16_t ui16UnOccupiedSetpoint)
                                        (zb_uint8_t *)&ui16UnOccupiedSetpoint,
                                        ZB_FALSE);
       if(ui16UnOccupiedSetpoint != 0xFFFF)
         ui16UnOccupiedHeatSetpoint = ui16UnOccupiedSetpoint;
         ui16CurrentTemp = ui16UnOccupiedSetpoint;
         ui16UnOccupiedHeatSetpoint =  0xFFFF;
          NRF_LOG_INFO("Set unoccupied heating setpoint temperature value fail. zcl_status: %d", zcl_status);
    **function to read value of pi heating demand
    **Any change in valve position value will be copied to PI heating demand attribute which only read attribute
    static void PIHeatingDemand (zb_uint8_t ui8PiHeatingDemand)
                                        ZB_ZCL_ATTR_THERMOSTAT_PI_HEATING_DEMAND_ID,
                                        &ui8PiHeatingDemand,
                                        ZB_FALSE);
          NRF_LOG_INFO("read pi heating demand value fail. zcl_status: %d", zcl_status);
    **function for read/write local temperature calibration
    **Any change in local temperature attribute then add this value to D11 and D12 of set temperature command
    static void LocalTemperatureCalibration(zb_uint8_t ui8localTempCalibration)
                                        ZB_ZCL_ATTR_THERMOSTAT_LOCAL_TEMPERATURE_CALIBRATION_ID,
                                        &ui8localTempCalibration,
                                        ZB_FALSE);
       ui8LocalTemperatureCalibration = ui8localTempCalibration;
          NRF_LOG_INFO("local temperature calibration value fail. zcl_status: %d", zcl_status);
    **function to read/write the valve position
    void SetValvePosition(zb_uint8_t ui8ValvePosition)
                                        ZB_ZCL_ATTR_THERMOSTAT_SET_VALVE_POSITION_ID,
                                        &ui8ValvePosition,
                                        ZB_FALSE);
       PIHeatingDemand(ui8ValvePosition);
          NRF_LOG_INFO("Set valve position value fail. zcl_status: %d", zcl_status);
    void SetTRVMode (zb_uint8_t ui8TRVMode)
                                        &ui8TRVMode,
                                        ZB_FALSE);
          NRF_LOG_INFO("Set trv mode value fail. zcl_status: %d", zcl_status);
    /**@brief Function for remaining battery percentage
    void ReadRemainigBatteryPercentage(zb_uint8_t ui8BatteryPercentage)
                                         &ui8BatteryPercentage ,
                                         ZB_FALSE);
          NRF_LOG_INFO("Set Battery percentage value fail. zcl_status: %d", zcl_status);
    **function to read the error status for different valve status
    **Any change in valve status respective error state copied to Error attribute which is read only attribute
    void ReadErrorStatus(zb_uint8_t ui8ErrorStatus)
                                         ZB_ZCL_ATTR_THERMOSTAT_ERROR_ID,
                                         &ui8ErrorStatus ,
                                         ZB_FALSE);
          NRF_LOG_INFO("read error status fail. zcl_status: %d", zcl_status);
    **function to read/write the flag status for different operation
    void HostFlagStatus(zb_uint32_t ui32HostFlagsStatus)
                                         (zb_uint8_t *)&ui32HostFlagsStatus,
                                         ZB_FALSE);
       ui32HostflagsData = ui32HostFlagsStatus;
        //Rotate LCD by 180
        if((ui32HostflagsData & 0x000002)== 0x02)
          boolSendDeviceConfig = true;
          if((ui8SendDeviceConfig[5] ^ DEVICE_CONFIG_BYTE_3_LCD_ROTATION) & DEVICE_CONFIG_BYTE_3_LCD_ROTATION )
            ui8SendDeviceConfig[5] |= DEVICE_CONFIG_BYTE_3_LCD_ROTATION;
        //LCD in default position
        if((ui32HostflagsData ^ 0x000002) & 0x02 )
          if(ui8SendDeviceConfig[5]  & DEVICE_CONFIG_BYTE_3_LCD_ROTATION)
            ui8SendDeviceConfig[5]  &= ui8SendDeviceConfig[5] ^ DEVICE_CONFIG_BYTE_3_LCD_ROTATION;
          NRF_LOG_INFO("Host flag status fail. zcl_status: %d", zcl_status);
    /**@brief Callback function for handling ZCL commands.
     * @param[in]   param   Reference to ZigBee stack buffer used to pass received data.
        zb_uint16_t                cluster_id;
        zb_uint16_t                attr_id;
                      if (attr_id == ZB_ZCL_ATTR_THERMOSTAT_OCCUPIED_HEATING_SETPOINT_ID)
                          zb_int16_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data16;
                          OccupiedHeatingSetpoint(value);
                           boolSetTemperature = true;
                           boolReady = true;
                           boolMCUInterrupt = false;
                      else if (attr_id == ZB_ZCL_ATTR_THERMOSTAT_UNOCCUPIED_HEATING_SETPOINT_ID)
                          UnOccupiedHeatingSetpoint(value);
                           boolReady = true;
                      else if (attr_id ==ZB_ZCL_ATTR_THERMOSTAT_CURRENT_SETPOINT_CHANGE_ID)
                          CurrentSetpointChangeValue(value);
                           boolReady = true;
                      else if(attr_id ==ZB_ZCL_ATTR_THERMOSTAT_LOCAL_TEMPERATURE_CALIBRATION_ID)
                          zb_uint8_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data8;
                          LocalTemperatureCalibration(value);
                      else if (attr_id ==ZB_ZCL_ATTR_THERMOSTAT_SET_VALVE_POSITION_ID)
                          SetValvePosition(value);
                      else if(attr_id == ZB_ZCL_ATTR_THERMOSTAT_HOST_FLAG_ID)
                         zb_uint32_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data32;
                         HostFlagStatus(value);
                         boolSetHostflags  = true;
                         boolReady = true;
                      else if(attr_id == ZB_ZCL_ATTR_THERMOSTAT_TRV_MODE_ID)
                         SetTRVMode(value);
    /**@brief ZigBee stack event handler.
     * @param[in]   param   Reference to ZigBee stack buffer used to pass arguments (signal).
    void zboss_signal_handler(zb_uint8_t param)
        zb_zdo_app_signal_hdr_t  * p_sg_p = NULL;
        zb_zdo_app_signal_type_t   sig    = zb_get_app_signal(param, &p_sg_p);
        zb_ret_t                   status = ZB_GET_APP_SIGNAL_STATUS(param);
        zb_bool_t                  comm_status;
        switch (sig)
            case ZB_BDB_SIGNAL_DEVICE_FIRST_START:
            case ZB_BDB_SIGNAL_DEVICE_REBOOT:
                if (status == RET_OK)
                    NRF_LOG_INFO("Joined network successfully");
                    bsp_board_led_on(ZIGBEE_NETWORK_STATE_LED);
                    boolSetCommand  = true;
                    boolReady = true;
                    boolGetStatus = true;
                    NRF_LOG_ERROR("Failed to join network. Status: %d", status);
                    bsp_board_led_off(ZIGBEE_NETWORK_STATE_LED);
                    comm_status = bdb_start_top_level_commissioning(ZB_BDB_NETWORK_STEERING);
                    ZB_COMM_STATUS_CHECK(comm_status);
            case ZB_ZDO_SIGNAL_PRODUCTION_CONFIG_READY:
                if (status != RET_OK)
                    NRF_LOG_WARNING("Production config is not present or invalid");
            case ZB_COMMON_SIGNAL_CAN_SLEEP:
                    zb_sleep_now(); //when receiving the signal ZB_COMMON_SIGNAL_CAN_SLEEP call sleep_now()
            case ZB_ZDO_SIGNAL_LEAVE:
                    zb_zdo_signal_leave_params_t * p_leave_params = ZB_ZDO_SIGNAL_GET_PARAMS(p_sg_p, zb_zdo_signal_leave_params_t);
                    NRF_LOG_INFO("Network left. Leave type: %d", p_leave_params->leave_type);
                    NRF_LOG_ERROR("Unable to leave network. Status: %d", status);
                /* Unhandled signal. For more information see: zb_zdo_app_signal_type_e and zb_ret_e */
                NRF_LOG_INFO("Unhandled signal %d. Status: %d", sig, status);
        if (param)
            ZB_FREE_BUF_BY_REF(param);
    /**@brief Function for application main entry.
    void main(void)
        zb_ret_t       zb_err_code;
        zb_ieee_addr_t ieee_addr;
        nrf_delay_ms(1500);
        /* Initialize logging system and GPIOs. */
        timer_init();
        log_init();
        leds_init();
        Uart_Init_Func();
        timer_config_func();
        ulp_input_pin_configuration();
        Flashinitialization();
        /* Set ZigBee stack logging level and traffic dump subsystem. */
        ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
        ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
        ZB_SET_TRAF_DUMP_OFF();
        /* Initialize Zigbee stack. */
        ZB_INIT("thermostat");
        /* Set device address to the value read from FICR registers. */
        zb_osif_get_ieee_eui64(ieee_addr);
        zb_set_long_address(ieee_addr);
        /* Set static long IEEE address. */
        zb_set_network_ed_role(IEEE_CHANNEL_MASK);
        zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
        zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN);
        zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
        zb_set_rx_on_when_idle(ZB_FALSE); // This enables sleepy behavior and makes your device act as a Sleepy End Device.
        zb_set_node_descriptor_manufacturer_code(ZB_ZCL_MANF_CODE);
        /* Initialize application context structure. */
        UNUSED_RETURN_VALUE(ZB_MEMSET(&m_dev_ctx, 0, sizeof(m_dev_ctx)));
        /* Register callback for handling ZCL commands. */
        ZB_ZCL_REGISTER_DEVICE_CB(zcl_device_cb);
        /* Register thermostat device context (endpoints). */
        ZB_AF_REGISTER_DEVICE_CTX(&thermostat_ctx);
        thermostat_clusters_attr_init();
        /** Start Zigbee Stack. */
        zb_err_code = zboss_start();
        ZB_ERROR_CHECK(zb_err_code);
        CommandBootloader();  //get bootloader command
        while(1)
           zboss_main_loop_iteration();
           UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
            CommunicationStateExecution();   //MCU and NP communication state
            DataProcessing();                //Flag bit processing
            UARTStateStateMachine();
    Also, below snippet is regarding erasing bonding info. The snippet present in attached  uart_statemachin.c file. Let me know if I followed anything wrong here to erase info.
                  //Master reset is executed
                  if(ui8GetFlagBuffer[2] & FLAGS_BYTE_2_MASTER_RESET_REQUEST)
    //                boolReady = false; //set flag to execute communication state
    //                boolIsMCURequest = true;
                    zigbee_erase_persistent_storage(ZB_TRUE);  //erase bonding info or leave network
     uart_statemachine.c - uart state machine source file for communication
     Version: 0.9.1
     Created on: 21/05/2021
     Created by: Rohit Rajapure
     Copyright (c) 2017 Shalaka Connected Devices LLP.  All rights reserved.
     Software License Agreement
       Redistribution and use in source and binary forms, with or without
       modification, are not permitted.
       Redistributions of source code must retain the above copyright
       notice, this list of conditions and the following disclaimer.
       Redistributions in binary form must reproduce the above copyright
       notice, this list of conditions and the following disclaimer in the
       documentation and/or other materials provided with the
       distribution.
       Neither the name of Shalaka Connected Devices LLP nor the names of
       its contributors may be used to endorse or promote products derived
       from this software without specific prior written permission.
     THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "stdlib.h"
    #include "string.h"
    #include "nrf.h"
    #include "app_rtc.h"
    *MACROS
    *TYPEDEFS
    State CurrentState, PreviousState;
    State CurrentState = State_Ready;
    E_StateMachine e_StateMachine;
    E_StateMachine e_StateMachine = IDLE_STATE;
    E_StateMachineThermostat e_StateMachineThermostat = POWER_CYCLE;
    App_tsEventBootloader sAppBootloaderEvent;
    App_tsEventProduction sAppProductionEvent;
    *EXTERNAL VARIABLES
    extern bool boolSetTemperature;
    extern uint8_t ui8GetCommandBuffer[BUFFER_SIZE], ui8SetCommandBuffer[BUFFER_SIZE],ui8SendDeviceConfig[BUFFER_SIZE], ui8GetFlagBuffer[BUFFER_SIZE], ui8ResponceValueSend[BUFFER_SIZE], ui8ResponceValueSend2[BUFFER_SIZE], ui8StartFirmwareUpdate[BUFFER_SIZE], ui8TransferFirmware[BUFFER_SIZE], ui8TempGetFlagBuffer[BUFFER_SIZE];
    extern bool boolGetStatus;
    extern bool boolSetHostflags;
    extern uint32_t ui32HostflagsData;
    extern bool boolSendDeviceConfig;
    *LOCAL VARIABLES
    uint8_t ui8ReadGetFlagBuffer[BUFFER_SIZE] = {0};
    uint8_t ui8SetpointChange[SET_POINT_CHANGE_BUFFER] = {0}; //store set point change value into buffer
    uint8_t ui8BatteryStatus[4] = {0};
    uint8_t ui8ValvePositionChange[2] = {0};
    uint8_t ui8FirmwareVersion[26] = {0};
    uint8_t ui8DeviceConfigData[6] = {0};
    uint8_t ui8GetBootloaderStatus[2] = {0};
    uint8_t ui8Rx = 0, ui8RxIndex =0, ui8Index =0;
    uint16_t ui16LocalTemperature = 0, ui16SetPointChange = 0, ui16UnOccupiedTemp = 0, ui16OccupiedTemp = 0;
    uint8_t ui8TelegramRepeatCount = 0;
    uint32_t ui32ReadHostFlagsByte = 0;
    uint32_t ui32CurrentVersion[6] = {0};
    char u8CurrentRFVersionString[] = "";
    char u32CurrentVersionString[] = "";
    uint16_t  ui16BatteryVoltage = 0;
    float flBatteryPercentage = 0.0;
    uint16_t ui16SaveAttributeID;
    uint8_t ui8TrvModeBackup;
    bool StartFrimwareUpdateTimer = false;
    static uint32_t ui32HostImageStartAddress;
    static uint32_t ui32HostImageEndAddress;
    bool boolSetCommand = false;
    bool boolIsMCURequest = false; //this flag is general to send getflag command whenever requried. So, set this flag accordingly.
    bool boolMCUInterrupt = false;
    bool FirmwareUpdateTransferFinished  = false;
    *BOOLEAN VARIABLES FOR GETFLAG COMMANDS
    //Data 01
    bool boolManualMode = false;
    bool boolHeatingMode = false;
    bool boolKeyProtection = false;
    bool boolInternalWindowOpen = false;
    bool boolExternalWindowOpen = false;
    bool boolRTCInValid = false;
    bool boolBatteryWeak = false;
    bool boolHolidayMode = false;
    //Data 02
    bool boolEncoderChange = false;
    bool boolSetPointChange = false;
    bool boolMasterResetRequest = false;
    bool boolMeasuredTempChange = false;
    bool boolMasterResetChange = false;
    bool boolBoostModeActive = false;
    bool boolProductModeRF = false;
    bool boolValvePositionChange = false;
    //Data 03
    bool boolButton1Push = false;
    bool boolButton2Push = false;
    bool boolButton3Push = false;
    bool boolButton4Push = false;
    bool boolButton5Push = false;
    bool boolButtonShortPush = false;
    bool boolButtonLongPush = false;
    bool boolButtonVeryLongpush = false;
    //Data 04
    bool boolADAPSuccess = false;
    bool boolErrorE1State = false;
    bool boolErrorE2State = false;
    bool boolErrorE3State = false;
    bool boolPrepMode = false;
    bool boolINST = false;
    bool boolADAP = false;
    bool boolADAPNotValid = false;
    //Data 05
    bool boolPairRequest = false;
    bool boolUnPairRequest = false;
    bool boolPairTimeOut = false;
    bool boolDevicePairState = false;
    *FUNCTIONS
    *function for communication state handling between MCU and Network processor
    *(this function used to execute the state machine between Radiator and nRF node)
    *return void
    void CommunicationStateExecution(void)
       while(boolReady)
           switch(CurrentState)
            case State_Ready:
                    PreviousState = CurrentState;   //if interrupt on ULP switch state to command
                    CurrentState  = State_Command;
                    ui8TelegramRepeatCount =0;
            case State_Command:
                  ulp_pin_transaction();  //ULP pin toggle configuration and high for 5msec
                  //send get flag telegram message to device
                  if(!boolIsMCURequest)
                     GetMessageIdResponse(GET_FLAGS);
                  Uart_PutData(ui8GetCommandBuffer,sizeof(ui8GetCommandBuffer));
                  PreviousState = CurrentState;   //after command sent switch state to read ACK
                  CurrentState  = State_ACKRead;
            case State_ACKRead:
                  //after get flag read ACK and send EOC
                  Uart_GetByte(&ui8Rx);
                  if((ui8Rx ==RESP_ACK) && (boolSetCommand == true))
                      PreviousState = CurrentState;   //if EOC and Set command then switch to state Set_Command
                      CurrentState  = State_SetCommand;
                  else if((ui8Rx ==RESP_ACK) && (boolSetTemperature == true))
                  else if((ui8Rx ==RESP_ACK) && (boolSetHostflags == true))
                  else if((ui8Rx ==RESP_ACK) && (boolSendDeviceConfig == true))
                  else if(ui8Rx ==RESP_ACK)
                    PreviousState = CurrentState;   //after EOC read switch state to send EOC
                    CurrentState  = State_SendEOC;
                  //if statement to check NACK response and perform the repeatation action
                  if(ui8Rx == RESP_NACK)
                     ui8TelegramRepeatCount++;
                     if(ui8TelegramRepeatCount == 3)
                         PreviousState = CurrentState;   //After command repeatation is done for 3 times switch state to Ready state
                         boolReady = false;
                         //if NACK then repeat the command for 3 time.
                         CurrentState  = PreviousState;
                  if(ui8Rx == RESP_TNS)
                       PreviousState = CurrentState;   //After command repeatation if it not supportive command (TNS) then go to ready state
                       boolReady = false;
            case State_SendEOC:
                  Uart_PutByte(EOC);
                  PreviousState = CurrentState;   //after EOC read switch state to read dummy ACK
                  CurrentState  = State_ACKReadDummy;
            case State_ACKReadDummy:
                        PreviousState = CurrentState;   //after dummy ACK read switch state to read response data
                        CurrentState  = State_ReadDataResponse;
            case State_SetCommand:
                 if((!boolSetTemperature) && (!boolSetHostflags) && (!boolSendDeviceConfig))
                   SetFlags();  //send set flag command
                   Uart_PutData(ui8SetCommandBuffer,sizeof(ui8SetCommandBuffer));
                   memset(ui8SetCommandBuffer,0,sizeof(ui8SetCommandBuffer));
                 else if((boolSetTemperature) && (!boolSetHostflags) && (!boolSendDeviceConfig))
                   SendSetTemperature();
                 else if(boolSetHostflags)
                   UARTStateSendFlags();
                 else if(boolSendDeviceConfig)
                     UARTStateSendDeviceConfig();          //send set device config command
                     Uart_PutData(ui8SendDeviceConfig,sizeof(ui8SendDeviceConfig));
                     memset(ui8SendDeviceConfig,0,sizeof(ui8SendDeviceConfig));
            case State_ReadDataResponse:
                  //read command response from MCU
                  if(ui8Rx == SYNC)
                     //read length of data
                     ui8RxIndex = ui8Rx;
                     GetFlagsResponse();   //store getflag data into buffer
                    // after data read send ACK to device
                     Uart_PutByte(RESP_ACK);
                     PreviousState = CurrentState;   //after data read send ACK to device  switch state EOC
                     CurrentState  = State_EOCRead;
            case State_EOCRead:
                 //After data read from MCU check for EOC
                  if(ui8Rx ==EOC)
                    //send ACK back
                      PreviousState = CurrentState;   //all state executed then switch to ready state
                      boolReady = false;
                      boolMCUInterrupt = true;
                  ResetFlags();
    *function for read the getflag bits and store into variable
    *return void
    void GetFlagsResponse (void)
         for(ui8Index = 0; ui8Index< ui8RxIndex-2; ui8Index++)  //loop to store read get flag data into variable
            //store data into buffer
            ui8ReadGetFlagBuffer[ui8Index] = ui8Rx;
    *This function is used to process the commands based on Id comparision.
    *return void
    void DataProcessing(void)
       if(boolMCUInterrupt)
           switch(ui8ReadGetFlagBuffer[0])
              case GET_FLAGS:
                   memcpy(ui8GetFlagBuffer,ui8ReadGetFlagBuffer,sizeof(ui8ReadGetFlagBuffer));
                   nrf_delay_ms(100);
    //               DecodeFlags();
    //               ProcessFlags();
                    //Data 01 of flag byte
                   if(ui8GetFlagBuffer[1] & FLAGS_BYTE_1_MANU_MODE)
    //                  SetTRVMode(ZB_ZCL_THERMOSTAT_TRV_MODE_DEFAULT_VALUE);
                      m_dev_ctx.thermostat_attr.host_flags |= FLAGS_BYTE_1_MANU_MODE;
    //                  HostFlagStatus(ui32ReadHostFlagsByte);
                   if(ui8GetFlagBuffer[1] & FLAGS_BYTE_1_KEY_PROTECTION_ACTIVE)
                     m_dev_ctx.thermostat_attr.host_flags |= 0x000080;
                   if((ui8GetFlagBuffer[1] ^ FLAGS_BYTE_1_KEY_PROTECTION_ACTIVE)& FLAGS_BYTE_1_KEY_PROTECTION_ACTIVE)
                     m_dev_ctx.thermostat_attr.host_flags &=m_dev_ctx.thermostat_attr.host_flags ^ 0x000080;
                   if(ui8GetFlagBuffer[1] & FLAGS_BYTE_1_INT_WINDOW_TRIGGERD)
                      m_dev_ctx.thermostat_attr.host_flags |= START_INTERNAL_WINDOW_OPEN;
                  if ((ui8GetFlagBuffer[1] ^ FLAGS_BYTE_1_INT_WINDOW_TRIGGERD)& FLAGS_BYTE_1_INT_WINDOW_TRIGGERD)
                      m_dev_ctx.thermostat_attr.host_flags &= m_dev_ctx.thermostat_attr.host_flags ^ STOP_INTERNAL_WINDOW_OPEN;
                  if (ui8GetFlagBuffer[1] & FLAGS_BYTE_1_EXT_WINDOW_ACTIVATE)
                  // If the external window open detection is active, the same bit is set in the RF telegram as for the internal one.
                  if (ui8GetFlagBuffer[1] & FLAGS_BYTE_1_BATTERY_WEAK)
    //                  ReadErrorStatus(BATTERY_WEAK_ERROR);
                      m_dev_ctx.thermostat_attr.error |= 0x01;
                      boolReady = true; //set flag to execute communication state
                      e_StateMachineThermostat = RUNNING_STATE;
                      sAppUartEvent.eType_UartNextState = APP_E_EVENT_UART_GET_BATTERY;
                  if((ui8GetFlagBuffer[1] ^ FLAGS_BYTE_1_BATTERY_WEAK) & FLAGS_BYTE_1_BATTERY_WEAK )
    //                  ui32ReadHostFlagsByte &= ui32ReadHostFlagsByte ^ 0x01;
    //                  ReadErrorStatus(0);
                      m_dev_ctx.thermostat_attr.error &=  m_dev_ctx.thermostat_attr.error ^ 0x01;
                   //Data 02 of flag byte
                   //Query whether setpoint temperature has been changed
                  if (ui8GetFlagBuffer[2] & FLAGS_BYTE_2_SETPOINT_CHANGED)
                      sAppUartEvent.eType_UartNextState = APP_E_EVENT_UART_GET_TEMPERATURE;
                  //Has the ACTUAL temperature changed, a request is sent to the controller.
                  if(ui8GetFlagBuffer[2] & FLAGS_BYTE_2_MEASURED_TEMP_CHANGED)
                  if(ui8GetFlagBuffer[2] & FLAGS_BYTE_2_BOOST_MODE)
                    m_dev_ctx.thermostat_attr.host_flags |= 0x04;
                  if((ui8GetFlagBuffer[2] ^ FLAGS_BYTE_2_BOOST_MODE) & FLAGS_BYTE_2_BOOST_MODE)
                    m_dev_ctx.thermostat_attr.host_flags &= m_dev_ctx.thermostat_attr.host_flags ^ 0x04;
                  if (ui8GetFlagBuffer[2] & FLAGS_BYTE_2_VALVE_POSITION_CHANGED)
                     sAppUartEvent.eType_UartNextState  = APP_E_EVENT_UART_GET_VALVE_POSITION;
                  //Data 04 flag byte
                  if(ui8GetFlagBuffer[4] == FLAGS_BYTE_4_ADAP_SUCCESSFUL)
                    ReadErrorStatus(NO_ERROR);
                  if((ui8GetFlagBuffer[4] & (0x07)) == FLAGS_BYTE_4_ERROR_E1)
                    ReadErrorStatus(VALVE_ADAPTATION_FAIL_E1);//Error ER1 Adaptation failed because not mounted
                  if((ui8GetFlagBuffer[4] & (0x07)) == FLAGS_BYTE_4_ERROR_E2)
                    ReadErrorStatus(VALVE_MOVEMENT_SLOW_E2); //Error ER2 adaptation failed because closing point not found
                  if((ui8GetFlagBuffer[4] & (0x07)) == FLAGS_BYTE_4_ERROR_E3)
                    ReadErrorStatus(VALVE_NOT_MOVING_E3); //Error ER3 adaptation failed because valve stroke too short or adaptation not possible
              case GET_BOOTLOADER_STATE:
                   memcpy(ui8GetBootloaderStatus,ui8ReadGetFlagBuffer,sizeof(ui8GetBootloaderStatus));
                   if(ui8GetBootloaderStatus[1] == 0x01)
                      e_StateMachineThermostat = BOOTLOADER_STATE;
                      sAppBootloaderEvent.eType_BootloaderState = APP_E_EVENT_UART_START_FIRMWARE_UPDATE;
    //                  sAppBootloaderEvent.eType_BootloaderState = APP_E_EVENT_UART_TRANSFER_FRIMWARE_UPDATE;
                   else if(ui8GetBootloaderStatus[1] == 0x00)
                      sAppUartEvent.eType_UartNextState = APP_E_EVENT_UART_GET_FIRMWARE_VERSION; // this state should execute only once when device starts
              case GET_TEMPERATURES:
                   memcpy(ui8SetpointChange,ui8ReadGetFlagBuffer,sizeof(ui8SetpointChange));
                  ui16LocalTemperature = ui8SetpointChange[1] << 8;
                  ui16LocalTemperature = ui16LocalTemperature + ui8SetpointChange[2];
                  localTemperatureValue(ui16LocalTemperature);
                  ui16SetPointChange   = ui8SetpointChange[5] << 8;
                  ui16SetPointChange   = ui16SetPointChange + ui8SetpointChange[6];
                  CurrentSetpointChangeValue(ui16SetPointChange);
                  ReadOccupiedHeatingSetpoint(ui16SetPointChange);  // When get temperature in requested copy the set point value on Occupied heating point id.
                  nrf_delay_ms(50);
              case GET_BATTERY_STATUS:
                   memcpy(ui8BatteryStatus, ui8ReadGetFlagBuffer,sizeof(ui8BatteryStatus));
                   //flBatteryPercentage = ((ui8BatteryStatus[1] * 100)/255);
                   vCalculateBattery(ui8BatteryStatus[1]);
    //               ui16BatteryVoltage = ui8BatteryStatus[2] << 8;    /**voltage calculation**/
    //               ui16BatteryVoltage = ui16BatteryVoltage + ui8BatteryStatus[3];
                    nrf_delay_ms(50);
                    if(boolGetStatus)
                        sAppUartEvent.eType_UartNextState = APP_E_EVENT_UART_GET_DEVICE_CONFIG;
                        sAppUartEvent.eType_UartNextState = APP_E_EVENT_UART_IDLE;
              case GET_FIRMWARE_VER:
                   memcpy(ui8FirmwareVersion,ui8ReadGetFlagBuffer,sizeof(ui8FirmwareVersion));
                   ui32CurrentVersion[0] = (ui8FirmwareVersion[19] - 0x30)	* 100000;
                   ui32CurrentVersion[1] = (ui8FirmwareVersion[20] - 0x30)	* 10000;
                   ui32CurrentVersion[2] = (ui8FirmwareVersion[21] - 0x30)	* 1000;
                   ui32CurrentVersion[3] = (ui8FirmwareVersion[22] - 0x30)	* 100;
                   ui32CurrentVersion[4] = (ui8FirmwareVersion[23] - 0x30)	* 10;
                   ui32CurrentVersion[5] = (ui8FirmwareVersion[24] - 0x30);
    //               itoa(m_dev_ctx.basic_attr.app_version,u8CurrentRFVersionString,8);
    //               itoa((int*)ui32CurrentVersion,u32CurrentVersionString,8);
    //               strcat(u8CurrentRFVersionString, u32CurrentVersionString);
    //               memcpy(m_dev_ctx.basic_attr.sw_ver,u8CurrentRFVersionString, 8);
                   nrf_delay_ms(25);
              case GET_DEVICE_CONFIG:
                   memcpy(ui8DeviceConfigData,ui8ReadGetFlagBuffer,sizeof(ui8DeviceConfigData));
                   if(ui8DeviceConfigData[3] == DEVICE_CONFIG_BYTE_3_VALVE_CONTROLLER)
                      m_dev_ctx.thermostat_attr.trv_mode = 0x01;     //TRV position mode
                   nrf_delay_ms(25);
              case GET_POSITION:
                   memcpy(ui8ValvePositionChange,ui8ReadGetFlagBuffer, sizeof(ui8ValvePositionChange));
                   SetValvePosition(ui8ValvePositionChange[1]);   //if valve position change then set valve and copy the data on pi heating demand attribute.
           memset(ui8ReadGetFlagBuffer,0,sizeof(ui8ReadGetFlagBuffer));
    *function for read bit status change whenever any command process
    *return void
    void DecodeFlags (void)
         //Data 01
         boolManualMode = (((ui8GetFlagBuffer[1] & MANUAL_MODE_BIT) !=0)? true:false);   //manual mode
         boolHeatingMode = (((ui8GetFlagBuffer[1] & HEATING_MODE_BIT) !=0) ? true: false);  //heating mode
         boolKeyProtection = (((ui8GetFlagBuffer[1] & KEY_PROTECTION_ACTIVE) !=0) ? true: false);  //key protection active
         boolInternalWindowOpen = (((ui8GetFlagBuffer[1] & INTERNAL_WINDOW_OPEN) !=0) ? true: false);  //internal window open
         boolExternalWindowOpen = (((ui8GetFlagBuffer[1] & EXTERNAL_WINDOW_OPEN) !=0) ? true: false);  //external window open
         boolRTCInValid = (((ui8GetFlagBuffer[1] & RTC_INVALID) !=0) ? true: false);  //rtc invalid
         boolBatteryWeak = (((ui8GetFlagBuffer[1] & BATTERY_WEAK) !=0) ? true: false);  //battery weak
         boolHolidayMode = (((ui8GetFlagBuffer[1] & HOLIDAY_MODE_ACTIVE) !=0) ? true: false);  //holiday mode active
         //Data 02
         boolEncoderChange = (((ui8GetFlagBuffer[2] & ENCODER_CHANGED) !=0) ? true: false);  //encoder change
         boolSetPointChange = (((ui8GetFlagBuffer[2] & SETPOINT_CHANGED_BIT) !=0) ? true: false);  //setpoint changed
         boolMasterResetRequest = (((ui8GetFlagBuffer[2] & MASTER_RESET_REQUEST) !=0) ? true: false);  //master reset request
         boolMeasuredTempChange = (((ui8GetFlagBuffer[2] & MEASURED_TEMPERATURE_CHANGE) !=0) ? true: false);  //measured temperature change
         boolMasterResetChange = (((ui8GetFlagBuffer[2] & MASTER_RESET_SUCCESS) !=0) ? true: false);  //master reset success
         boolBoostModeActive = (((ui8GetFlagBuffer[2] & BOOST_MODE_ACTIVE) !=0) ? true: false);  //boost mode active
         boolProductModeRF = (((ui8GetFlagBuffer[2] & PRODUCTION_MODE_RF) !=0) ? true: false);  //production mode
         boolValvePositionChange = (((ui8GetFlagBuffer[2] & VALVE_POSITION_CHANGE) !=0) ? true: false);  //valve position change
         //Data 03
         boolButton1Push = (((ui8GetFlagBuffer[3] & BUTTON_1_PUSH) !=0) ? true: false);  //button 1 push
         boolButton2Push = (((ui8GetFlagBuffer[3] & BUTTON_2_PUSH) !=0) ? true: false);  //button 2 push
         boolButton3Push = (((ui8GetFlagBuffer[3] & BUTTON_3_PUSH) !=0) ? true: false);  //button 3 push
         boolButton4Push = (((ui8GetFlagBuffer[3] & BUTTON_4_PUSH) !=0) ? true: false);  //button 4 push
         boolButton5Push = (((ui8GetFlagBuffer[3] & BUTTON_5_PUSH) !=0) ? true: false);  //button 5 push
         boolButtonShortPush = (((ui8GetFlagBuffer[3] & BUTTON_SHORT_PUSH) !=0) ? true: false);  //button short push
         boolButtonLongPush = (((ui8GetFlagBuffer[3] & BUTTON_LONG_PUSH) !=0) ? true: false);  //button long push
         boolButtonVeryLongpush = (((ui8GetFlagBuffer[3] & BUTTON_VERY_LONG_PUSH) !=0) ? true: false);  //button very long push
         //Data 04
         boolADAPSuccess = (((ui8GetFlagBuffer[4] & ADAP_SUCCESSFUL) !=0) ? true: false);  //ADAP success
         boolErrorE1State = (((ui8GetFlagBuffer[4] & VALVE_ERROR_E1) !=0) ? true: false);  //valve error 1
         boolErrorE2State = (((ui8GetFlagBuffer[4] & MACHANICAL_FAIL_ERROR_E2) !=0) ? true: false);  //machanical fail error 2
         boolErrorE3State = (((ui8GetFlagBuffer[4] & VALVE_TRAVEL_SHORT_ERROR_E3) !=0) ? true: false);  //valve travel short error 3
         boolPrepMode = (((ui8GetFlagBuffer[4] & PREP_MOUNTING_POSITION) !=0) ? true: false);  //prep mounting position
         boolINST = (((ui8GetFlagBuffer[4] & INST_MOUNTING_POSITION) !=0) ? true: false);  //INST_MOUNTING_POSITION
         boolADAP = (((ui8GetFlagBuffer[4] & ADAP_VALVE_PROGRESS) !=0) ? true: false);  //ADAP_VALVE_PROGRESS
         boolADAPNotValid = (((ui8GetFlagBuffer[4] & ADAP_NOT_VALID) !=0) ? true: false);  //ADAP_NOT_VALID
         //Data 05
         boolPairRequest = (((ui8GetFlagBuffer[5] & PAIR_REQUEST) !=0) ? true: false);  //pair request
         boolUnPairRequest = (((ui8GetFlagBuffer[5] & UNPAIR_REQUEST) !=0) ? true: false);  //unpair request
         boolPairTimeOut = (((ui8GetFlagBuffer[5] & PAIR_TIMEOUT) !=0) ? true: false);  //pair time out
         boolDevicePairState = (((ui8GetFlagBuffer[5] & DEVICE_PAIRED) !=0) ? true: false);  //device paired
    *function for depending on the bit status change execute the corresponding commands
    *return void
    void ProcessFlags(void)
    //      //Data 01 of getflag
          if(boolManualMode)
            //process manual mode whenever it is active
            ui32HostflagsData |= FLAGS_BYTE_1_MANU_MODE;
            HostFlagStatus(ui32HostflagsData);
    //      if(boolHeatingMode)
    //        //process heating mode whenever it is active
    //        boolHeatingMode = false;
          if(boolKeyProtection)
            //process boolKeyProtection whenever it is active
    //      if(boolInternalWindowOpen)
    //         //process boolInternalWindowOpen whenever it is active
    //         boolInternalWindowOpen = false;
    //      if(boolExternalWindowOpen)
    //         //process boolExternalWindowOpen whenever it is active
    //         boolExternalWindowOpen = false;
          if(boolRTCInValid)
             //process boolRTCInValid whenever it is active
             boolRTCInValid = false;   //if rtc bit is invalid then process action TBD
    //         vRTC_vRequestTimeFromCoordiantor();
          if(boolBatteryWeak)
             ReadErrorStatus(BATTERY_WEAK_ERROR);  //error status for battery weak detect
             //process boolBatteryWeak whenever it is active
             boolBatteryWeak = false; //if battery weak bit is high then send "Get_battery_status" command
    //      if(boolHolidayMode)
    //        //process boolHolidayMode whenever it is active
    //         boolHolidayMode = false;
    //      //Data 02
    //      if(boolEncoderChange)
    //         //process boolEncoderChange whenever it is active
    //         boolEncoderChange = false;
          //if setpoint change bit is high then send "Get_temperature" command
          if(boolSetPointChange)
          if(boolMasterResetRequest)
             //process boolMasterResetRequest whenever it is active
    //         NVIC_SystemReset();  //soft reset device when factory reset button pressed
    //         CurrentState  = State_Ready;   //after Reset set to device  switch state ready
    //         ResetFlags();
    //      if(boolMeasuredTempChange)
    //        //process boolMeasuredTempChange whenever it is active
    //         boolMeasuredTempChange = false;
    //      if(boolMasterResetChange)
    //        //process boolMasterResetChange whenever it is active
    //         boolMasterResetChange = false;
    //      if(boolBoostModeActive)
    //        //process boolBoostModeActive whenever it is active
    //         boolBoostModeActive = false;
    //                      //start boost mode bit if it is high and set host flag to 0x000004
    //      if(boolProductModeRF)
    //        //process boolProductModeRF whenever it is active
    //         boolProductModeRF = false;
          if(boolValvePositionChange)
            //process boolValvePositionChange whenever it is active
    //      //Data 03 of getflag
    //      if(boolButton1Push)
    //        //process boolButton1Push whenever it is active
    //        boolButton1Push = false;
    //      if(boolButton2Push)
    //        //process boolButton2Push whenever it is active
    //        boolButton2Push = false;
    //      if(boolButton3Push)
    //        //process boolButton3Push whenever it is active
    //         boolButton3Push = false;
    //      if(boolButton4Push)
    //         //process boolButton4Push whenever it is active
    //         boolButton4Push = false;
    //      if(boolButton5Push)
    //         //process boolButton5Push whenever it is active
    //         boolButton5Push = false;
    //      if(boolButtonShortPush)
    //         //process boolButtonShortPush whenever it is active
    //         boolButtonShortPush = false;
    //      if(boolButtonLongPush)
    //         //process boolButtonLongPush whenever it is active
    //         boolButtonLongPush = false;
    //      if(boolButtonVeryLongPush)
    //        //process boolButtonVeryLongPush whenever it is active
    //         boolButtonVeryLongPush = false;
    //      //Data 04 of getflag
    //      if(boolADAPSuccess)
    //        //process boolADAPSuccess whenever it is active
    //        boolADAPSuccess = false;
          if(boolErrorE1State)
            //process boolErrorE1State mode whenever it is active
            ReadErrorStatus(VALVE_ADAPTATION_FAIL_E1);  //error status e1 when valve adaptation fail
          if(boolErrorE2State)
            //process boolErrorE2State whenever it is active
             ReadErrorStatus(VALVE_MOVEMENT_SLOW_E2);  //error status e2 when valve movement too slow
          if(boolErrorE3State)
             //process boolErrorE3State whenever it is active
             ReadErrorStatus(VALVE_NOT_MOVING_E3);    //error status e3 when valve not moving
    //      if(boolPrepMode)
    //         //process boolPrepMode whenever it is active
    //         boolPrepMode = false;
    //      if(boolINST)
    //         //process boolINST whenever it is active
    //         boolINST = false;
    //      if(boolADAP)
    //         //process boolADAP whenever it is active
    //         boolADAP = false;
    //      if(boolADAPNotValid)
    //        //process boolADAPNotValid whenever it is active
    //         boolADAPNotValid = false;
    //      //Data 05 of getflag
    //      if(boolPairRequest)
    //        //process boolPairRequest whenever it is active
    //        boolPairRequest = false;
    //      if(boolUnPairRequest)
    //        //process boolUnPairRequest whenever it is active
    //        boolUnPairRequest = false;
    //      if(boolPairTimeOut)
    //        //process boolPairTimeOut whenever it is active
    //         boolPairTimeOut = false;
    //      if(boolDevicePairState)
    //         //process boolDevicePairState whenever it is active
    //         boolDevicePairState = false;
    //function to reset all flags
    void ResetFlags(void)
      boolReady = false;
     * NAME: vUART_STATE_StateMachine
     * DESCRIPTION:
     * Check different states of Thermostat and RF
     * RETURNS:
     * void
    void UARTStateStateMachine(void)
       if (e_StateMachineThermostat == BOOTLOADER_STATE)
            switch (sAppBootloaderEvent.eType_BootloaderState)
                case APP_E_EVENT_UART_START_FIRMWARE_UPDATE:
                        //bRestartBootloaderMode = FALSE;  did not get declaration
                      UARTStateStartFirmwareUpdate();
                case APP_E_EVENT_UART_TRANSFER_FRIMWARE_UPDATE:
                        //UARTStateTransferFirmwareUpdate(); This function is not created here
                case APP_E_EVENT_BOOTLOADER_STATE_IDLE:
       else if (e_StateMachineThermostat == PRODCUTION_MODE)
            switch (sAppProductionEvent.eType_ProductionState)
                case APP_E_EVENT_PRODUCTION_STATE:
                     GetMessageIdResponse(GET_PRODUCTION_MODE);  // send get production mode command
       else if (e_StateMachineThermostat == RUNNING_STATE)
                switch (sAppUartEvent.eType_UartNextState)
                  case APP_E_EVENT_UART_SEND_TEMPERATURE:
                         //UARTStateSendTemperature(u16SaveAttributeID);  TBD for replacement send set temperature command
                  case APP_E_EVENT_UART_GET_TEMPERATURE:
                        GetMessageIdResponse(GET_TEMPERATURES); //send get temeperature command
                  case APP_E_EVENT_UART_GET_BATTERY:
                         GetMessageIdResponse(GET_BATTERY_STATUS); //send get battey status command
                  case APP_E_EVENT_UART_GET_COMPOSITE_DATA:
                          GetMessageIdResponse(GET_COMPOSITE_DATA1); //send get comosite data command
                  case APP_E_EVENT_UART_ULP_WAS_TRIGGERED:
                          GetMessageIdResponse(GET_FLAGS);   //send get flag command
                  case APP_E_EVENT_UART_SEND_FLAGS:
                  case APP_E_EVENT_UART_SEND_FLAGS_AUTO_MODE:
                          UARTStateSendFlagsAuto();     //send set flag with auto mode flag command
                  case APP_E_EVENT_UART_SEND_FLAGS_MANU_MODE:
                          UARTStateSendFlagsManu();     //send set flag with manual mode flag command
                  case APP_E_EVENT_UART_SEND_VALVE_POSITION:
                          UARTStateSendValvePosition();   //send set valve position command
                  case APP_E_EVENT_UART_GET_VALVE_POSITION:
                          GetMessageIdResponse(GET_POSITION);   //send get valve position command
                  case APP_E_EVENT_UART_SEND_DEVICE_CONFIG:
    //                      UARTStateSendDeviceConfig();          //send set device config command
                  case APP_E_EVENT_UART_SEND_DEVICE_CONFIG_2:
                          UARTStateSendDeviceConfig2();           //send set device config2 command
                  case APP_E_EVENT_UART_GET_DEVICE_CONFIG:
                          GetMessageIdResponse(GET_DEVICE_CONFIG);   //send get device config command
                  case APP_E_EVENT_UART_SEND_FLAGS_JOINED:
                          UARTStateSendFlagsJoined();            //send set flag command with joined parameter
                  case APP_E_EVENT_UART_SEND_FLAGS_LEAVE:
                          UARTStateSendFlagsLeave();             //send set flag command with leave ntw parameter
                  case APP_E_EVENT_UART_SEND_FLAGS_RF_COMMUNICATION_OK:
                          UARTStateSendFlagsRFCommunicationOK();   //send set flag with RF communication okay command
                  case APP_E_EVENT_UART_SEND_FLAGS_RF_COMMUNICATION_LOST:
                          UARTStateSendFlagsRFCommunicationLost();    //send set flag with RF communication lost command
                  case APP_E_EVENT_UART_SEND_RTC:
                          UARTStateSendRTC();                    //send set RTC command
                  case APP_E_EVENT_UART_GET_RTC:
                          GetMessageIdResponse(GET_RTC);          //send get RTC command
                  case APP_E_EVENT_UART_GET_FIRMWARE_VERSION:
                          GetMessageIdResponse(GET_FIRMWARE_VER);   //send get firmware version command
                  case APP_E_EVENT_UART_IDLE:
                  case APP_E_EVENT_UART_SEND_SYSTEM_MODE:
                         // vUART_STATE_SendDeviceConfig();    This is not created here
                  case APP_E_EVENT_UART_GET_RTC_FROM_COORDINATOR:
                  case APP_E_EVENT_UART_SEND_MASTER_RESET_REQUEST:
                          UARTStateMasterResetRequest();                 //send master reset with request flag command
                  case APP_E_EVENT_UART_SEND_MASTER_RESET_SUCCESS:
                          UARTStateMasterResetSuccess();                //send master reset with rest flag command
                  case APP_E_EVENT_UART_SEND_GET_PRODUCTION_MODE:
                          GetMessageIdResponse(GET_PRODUCTION_MODE);    //send get production mode command
                  case APP_E_EVENT_UART_SEND_SET_PRODUCTION_MODE_PASS:
                          UARTStateSendSetProductionModePass();    //send set production mode pass command
                  case APP_E_EVENT_UART_SEND_START_PRODUCTION_MODE:
                          UARTStateSendStartProductionMode();     //send set production mode start command
                  case APP_E_EVENT_UART_LEAVE_NETWORK:
                       //   vUART_STATE_vLeaveNetwork();   This function not created here
                  case APP_E_EVENT_UART_IDENTIFY_MODE:
                  case APP_E_EVENT_UART_SEND_SWITCHPOINTS:
                        //UARTStateSendSwitchPoints();   //send switch point function. This function not created here
    - After bonding erase I would like to perform soft reset and I used NVIC_SystemReset() function here. What I observed is after reset my while(1) loop not executing and when i paused the code it show me in  nrf_log_frontend()  file's bool nrf_log_frontend_dequeue(void) function.
    -Why reset not working correctly?Let me know your feedback on this.
    Thanks and Regards
    Rohit R
  • Hi Marte,
    Update from my end,
    As per your suggestion, I made the code in SED configuration. I have shared my main file in previous post. - Let me know any changes.
    But with this SED, configuration what I observed is with Dev-kit and Radiator base (STM) board I am getting 1mA current. Which is comparatively less than what I was getting previously.
    Now I would like to do further reduction in current including nRF dev-kit and STM8 board I need almost 60uA and only nRF i need 30uA.
    So, I decided to add ram retention also here along with sleep. Please find the attached image of my memory usage and let me know how I to power down unused ram section.
    I request you, please give your feedback as early as possible on this.
    And also, I would like to know can we use system off in sleepy end device and wake up on GPIO interrupt. I mean device should work as sleepy end device as well as system off mode. It should wake up periodically like SED and wake up on system off mode? Let me know your feedback on this.
    And is there any update from developer regarding system wakeup on zigbee command? I am getting pressure from team to resolve sleep issue.
    Thanks and Regards
    Rohit R
  • Hi Rohit,
     I have already answered this, and explained that this is not possible with SED. With devices that are not SED, this will happen by default if you are using zb_osif_wait_for_event() to reduce power.
    • SED: A Sleepy End Device will go into sleep mode, and not only low power mode. This will, among other things, turn off the radio. So the device cannot receive Zigbee packets, as the radio is not receiving anything. Sending a command to wake the device will do nothing, as it will only receive the command after it is already awake. This is part of the Zigbee specification, for RxOnWhenIdle = false devices (some places call it RxOnIdle = false or RxOffWhenIdle = true).
    • Non-SED: Calling zb_osif_wait_for_event() makes the device go into low power mode. This is functionally the same as a single call of __WFE() instruction (wait for event). The CPU goes into a low-power state until an event occurs. Any interrupt occurring between zb_osif_wait_for_event() calls will wake up the device, same as with __WFE(). The radio is not turned off, so the device will still receive Zigbee packets. Receiving Zigbee packets will be an event, so it will wake up.
     As this feature is only available in v4.1.0, you must implement it yourself in v3.0.0. As I stated before you should look at the function zigbee_power_down_unused_ram() in zigbee_helpers.c in v4.1.0 to see how this can be done. After implementing the function, you should call it right after setting SED with zb_set_rx_on_when_idle() in main().
     It should be enough to define ERASE_PERSISTENT_CONFIG as ZB_TRUE and call zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG). This should erase network data on a reset or power cycle of the device. This function calls zb_set_nvram_erase_at_start(), which enables or disables NVRAM erasing on application startup. If using zigbee_erase_persistent_storage() does not work, you can try calling zb_set_nvram_erase_at_start(ZB_TRUE) directly, but I would recommend using zigbee_erase_persistent_storage() instead. You should call these functions during the initialization, and not when the application is running. The function zigbee_erase_persistent_storage() will not make the device leave the network.
    Since you are using v3.0.0, you can make your device leave the network by creating a function that does the same as light_switch_leave_nwk() in the light switch example.
    static void light_switch_leave_nwk(zb_uint8_t param)
        /* We are going to leave */
        if (param)
            zb_buf_t                  * p_buf = ZB_BUF_FROM_REF(param);
            zb_zdo_mgmt_leave_param_t * p_req_param;
            p_req_param = ZB_GET_BUF_PARAM(p_buf, zb_zdo_mgmt_leave_param_t);
            UNUSED_RETURN_VALUE(ZB_BZERO(p_req_param, sizeof(zb_zdo_mgmt_leave_param_t)));
            /* Set dst_addr == local address for local leave */
            p_req_param->dst_addr = ZB_PIBCACHE_NETWORK_ADDRESS();
            p_req_param->rejoin   = ZB_FALSE;
            UNUSED_RETURN_VALUE(zdo_mgmt_leave_req(param, NULL));
            zb_err_code = ZB_GET_OUT_BUF_DELAYED(light_switch_leave_nwk);
    I will come back to you regarding this.
    Marte
  • Hi Marte,
    Thanks for the response.
    - My point here is, I want less current consumption for my device it should be 30uA. As per your suggestion we tried SED because zb_osif_wait_for_event(); Didn't worked. It gave us current 3.9mA.
    So, Till we get developer feedback on waking up device using Zigbee command. We tried SED config. And it gave us some better result around 1mA. But again this huge my target is 30uA.
    - That's why asked any update from Developer for this? If the waking up device using Zigbee command gives us better result in current consumption I will definitely use that not SED. On other hand after configuring SED if would resulted me in uA (micro Ampear) then I would go ahead with. I didn't bother for waking up on Zigbee command.
    - Point is, using SED or zb_osif_wait_for_event() not gave me less current. In document typical value mentioned. Also, some points regarding System ON, no ram retention but how to do that no explanation. System Off also same. Only wakeup on reset or GPIO interrupt that also not help me here.
    Then how to reduce current?? We trying different different ways but still same result. Current not reducing below mA.
    - I saw some post and suggestion followed below to configure the same.
    NRF_POWER->RAM[0].POWERCLR = 0x3;
    NRF_POWER->RAM[1].POWERCLR = 0x3;
    NRF_POWER->RAM[2].POWERCLR = 0x3;
    NRF_POWER->RAM[3].POWERCLR = 0x3;
    NRF_POWER->RAM[4].POWERCLR = 0x3;
    NRF_POWER->RAM[5].POWERCLR = 0x3;
    NRF_POWER->RAM[6].POWERCLR = 0x3;
    NRF_POWER->RAM[7].POWERCLR = 0x3;
    NRF_POWER->RAM[8].POWERCLR = 0x3F;
    - As per our study I commented RAM[0], RAM[1] and RAM[2] and set RAM[8] = 0x3 then able to run my code.
    - And, if i just comment RAM[0] and RAM[8] = 0x3F as per one of nrf engineer post, I am not able to run code. IT enters into hardfault.
    - Okay, I will follows your steps. Use 4.1 to port in 3.0 SDK.
    - Yes, please I will wait.
    Thanks and Regards
    Rohit R
