Difference between iOS and Android Bluetooth "search for devices" mechanism
I have a BLE application running on a nRF51822 chip with the S120 softdefice. If I use the standard Android "search for device" mechanism for Bluetooth devices, I can find my nRF51822 and get connected.
On the other side, if I use the standard "search for device" mechanism of iOS (iPhone), I am not able to see my nRF51822. Additionally I`m not able to get connected to the nRF51822. If I use a special Bluetooth scanner application on the iPhone, I can see the nRF51822 device.
Is there any chance to get connected on the iPhone via the standard iOS Bluetooth search mechanism?
Regards!
  • @BTprogrammer: Could you let me know which mode did you run with the S120. If you run it in central mode, I don't think any phone would be able to search for it. S120 is central stack and will only do scanning.
    I assume the "search for device" you mentioned was the button in the Bluetooth setting. On iPhone only the device that is HID device, audio device or bonded device will appear. This explain why you couldn't see it in the list.
    What I suggest you to do is to have a look at the nRFToolbox app for iOS. The source code is provided, and you should be able to find how to scan for the device in your own app.
  • Hello Hung,
    In my understanding, I can use S120 as central and peripheral. In my application I use it in peripheral mode:
        uint32_t err_code;
    		ble_uuid128_t base_uuid = DEVICE_PERIPHERAL_BASE_UUID;
    		// Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
        // Enable BLE stack
    		ble_enable_params_t ble_enable_params;
        memset(&ble_enable_params, 0, sizeof(ble_enable_params));
        ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
    	  ble_enable_params.gap_enable_params.role              = BLE_GAP_ROLE_PERIPH;
    		err_code = sd_ble_enable(&ble_enable_params);
    		err_code = sd_ble_uuid_vs_add(&base_uuid, &m_base_uuid_type);
    	  err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    But later on, I will do an dynamical switch between central and peripheral. But in connection mode to a smartphone, it will always be peripheral mode. I think your second paragraph is the answer I was searching for. So there is no other option for me like to search in my iOS application for my devices. On iOS I can`t use the standard iOS search function, as this only allows to see HID devices, audio devices or bonded devices!?
    After bonding the device via my iOS app, the device should also appear in the iOS Bluetooth list...
    Thanks
    Regards!
  • @BTProgrammer: If you use S120 in peripheral mode, then you should be able to scan for your device from your app". "So there is no other option for me like to search in my iOS application for my devices."=> I don't really understand it. Yes, you can scan, search and connect in your iOS application the same way as you can see in the Bluetooth scanner app as you mentioned in the question.
  • Yes, of course, I can scan, search and connect to my device from my iOS application. But I can not use the standard iOS Bluetooth search mechanism for scan, search connect to my device. I can use the standard iOS mechanism, only if my device is bonded to the specific iPhone. Sorry for my comlicate wording.
  • @BTprogrammer: You can add HID profile (keyboard/mouse) in your att table and in advertising packet, so that the phone will show you device in the bluetooth setting.
    But I don't quite understand why you want to connect to the device from bluetooth setting window ? You would need an app anyway to read data or to control the device.
