Hi everyone,
How can I use both NRF_LOG_UART and APP_UART on nRF52840 (SDK 17) ?
Thank you
Hi everyone,
Thank you
Now, I can LOG by UART. But, when I tried adding APP_UART into my project, I got a Fatal Error after APP_UART_FIFO_INIT() function and System Reset
In my sdk_config.h file, I added:
#define APP_UART_ENABLED 1 #define APP_UART_DRIVER_INSTANCE 1 #define APP_FIFO_ENABLED 1
and enabled:
#define UART1_ENABLED 1
What am I missing ?
Please refer to the sdk_config.h of UART Example and modify as the following:
#define APP_UART_ENABLED 1 #define APP_UART_DRIVER_INSTANCE 0 #define APP_FIFO_ENABLED 1 #define UART0_ENABLED 1 #define UART1_ENABLED 0
-Amanda H.
Hi Amanda,
I have already followed your recommended configuration, but I still got the Error 8: NRF_ERROR_INVALID_STATE after APP_UART_FIFO_INIT() function
Do you have the NRF Logger module initialized? If this is set to use UART, you will not be able to initialize the UART module, and APP_UART_FIFO_INIT will return error code 0x08 (NRF_ERROR_INVALID_STATE).
-Amanda H.
But, I would like to use both NRF LOG UART and APP UART.
Is it possible?
Yes, on nRF52840 you can use the second UARTE instance (1) for app_uart by changing APP_UART_DRIVER_INSTANCE
NRF_LOG UART backend is hardcoded to use instance 0.
-Amanda H.
-Amanda H.
