macro deprecated DT_INST_FOREACH_STATUS_OKAY
Quite a few drivers use this deprecated macro.  For example bme280.
It was OK on ncs v1.4 but throwing warning on v1.5
Solution?
  • I'm not able to reproduce this. I did the following
    • Used NCS v1.5.0
    • Added the file nrf9160dk_nrf9160ns.overlay to zephyr\samples\sensor\bme280\boards, with the same content showed in 1.2 Walkthrough for BME280
    • Built the sample  zephyr\samples\sensor\bme280 for the board nrf9160dk_nrf9160ns and got no warnings:
    $ west build -b nrf9160dk_nrf9160ns
    Including boilerplate (Zephyr base): C:/Users/Simon/ncs/v1.5.0/zephyr/cmake/app/boilerplate.cmake
    -- Application: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280
    -- Using NCS Toolchain 1.5.0 for building. (C:/Users/Simon/ncs/v1.5.0/toolchain/cmake)
    -- Zephyr version: 2.4.99 (C:/Users/Simon/ncs/v1.5.0/zephyr)
    -- Found Python3: C:/Users/Simon/ncs/v1.5.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
    -- Board: nrf9160dk_nrf9160ns, Revision: 0.7.0
    -- Cache files will be written to: C:/Users/Simon/ncs/v1.5.0/zephyr/.cache
    -- Found dtc: C:/Users/Simon/ncs/v1.5.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (C:/Users/Simon/ncs/v1.5.0/toolchain/opt)
    -- Found BOARD.dts: C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
    -- Found devicetree overlay: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/boards/nrf9160dk_nrf9160ns.overlay
    -- Generated zephyr.dts: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/zephyr/include/generated/device_extern.h
    Parsing C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/Kconfig
    Loaded configuration 'C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
    Merged configuration 'C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_0_7_0.conf'
    Merged configuration 'C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/prj.conf'
    Configuration saved to 'C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/zephyr/.config'
    Kconfig header saved to 'C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Found assembler: C:/Users/Simon/ncs/v1.5.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
    Changed board to secure nrf9160dk_nrf9160 (NOT NS)
    === child image spm -  begin ===
    -- Application: C:/Users/Simon/ncs/v1.5.0/nrf/samples/spm
    -- Board: nrf9160dk_nrf9160, Revision: 0.7.0
    -- Found BOARD.dts: C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
    -- Found devicetree overlay: C:/Users/Simon/ncs/v1.5.0/nrf/samples/spm/nrf9160dk_nrf9160.overlay
    -- Generated zephyr.dts: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/spm/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/spm/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/spm/zephyr/include/generated/device_extern.h
    Parsing C:/Users/Simon/ncs/v1.5.0/zephyr/Kconfig
    Loaded configuration 'C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
    Merged configuration 'C:/Users/Simon/ncs/v1.5.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_0_7_0.conf'
    Merged configuration 'C:/Users/Simon/ncs/v1.5.0/nrf/samples/spm/prj.conf'
    Merged configuration 'C:/Users/Simon/ncs/v1.5.0/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
    Merged configuration 'C:/Users/Simon/ncs/v1.5.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration 'C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/spm/zephyr/.config'
    Kconfig header saved to 'C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/spm/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/Simon/ncs/v1.5.0/zephyr/samples/sensor/bme280/build/spm
    === child image spm -  end ===
    -- Configuring done
    -- Generating done
    [5/165] Performing build step for 'spm_subimage'
    [196/201] Linking C executable zephyr\zephyr_prebuilt.elf
               FLASH:         32 KB        48 KB     66.67%
                SRAM:        8648 B        64 KB     13.20%
            IDT_LIST:          72 B         2 KB      3.52%
    [201/201] Linking C executable zephyr\zephyr.elf
    [159/165] Linking C executable zephyr\zephyr_prebuilt.elf
               FLASH:       30340 B       976 KB      3.04%
                SRAM:        6608 B       192 KB      3.36%
            IDT_LIST:         104 B         2 KB      5.08%
    [165/165] Generating zephyr/merged.hex
    Could you tell me how to reproduce it?
    Simon
  • Thx Simon,
    Must be something about the board I'm using.  I could also build the bme280 example.  Needs further investigation.
    Regards.
