nrf sdk 1.5.1 command line build fails to build at_client sample
I have installed nrf sdk 1.5.1 via toolchain manager.
I have opened a bash via dropdown in your toolchain manager.
From there I have followed your instructions on how to build via command line, and I choose the sample from the docs - at_client and for the 91 board.
Q: do you test build all samples before making a release, so they build without failing?
It might be me doing something wrong, but I can't see any errors.
/Johan
Log output below:
Test 1 - non secure build target
jsa@DESKTOP-R94H4M6 MINGW64 /c/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client ((v1.5.1))
$ west build -b thingy91_nrf9160ns
Including boilerplate (Zephyr base): C:/ncs-by-toolchain-app/v1.5.1/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client
-- Using NCS Toolchain 1.5.1 for building. (C:/ncs-by-toolchain-app/v1.5.1/toolchain/cmake)
-- Zephyr version: 2.4.99 (C:/ncs-by-toolchain-app/v1.5.1/zephyr)
-- Found Python3: C:/ncs-by-toolchain-app/v1.5.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
-- Board: thingy91_nrf9160ns
-- Cache files will be written to: C:/ncs-by-toolchain-app/v1.5.1/zephyr/.cache
-- Found dtc: C:/ncs-by-toolchain-app/v1.5.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/ncs-by-toolchain-app/v1.5.1/toolchain/opt)
-- Found BOARD.dts: C:/ncs-by-toolchain-app/v1.5.1/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160ns.dts
-- Generated zephyr.dts: C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/zephyr/include/generated/device_extern.h
Parsing C:/ncs-by-toolchain-app/v1.5.1/zephyr/Kconfig
Loaded configuration 'C:/ncs-by-toolchain-app/v1.5.1/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160ns_defconfig'
Merged configuration 'C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/prj.conf'
Configuration saved to 'C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/zephyr/.config'
Kconfig header saved to 'C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/ncs-by-toolchain-app/v1.5.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
Changed board to secure thingy91_nrf9160 (NOT NS)
=== child image spm - begin ===
Including boilerplate (Zephyr base): C:/ncs-by-toolchain-app/v1.5.1/zephyr/cmake/app/boilerplate.cmake-- Application: C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/spm
-- Found BOARD.dts: C:/ncs-by-toolchain-app/v1.5.1/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts
-- Generated zephyr.dts: C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm/zephyr/include/generated/device_extern.h
Loaded configuration 'C:/ncs-by-toolchain-app/v1.5.1/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_defconfig'
Merged configuration 'C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/spm/prj.conf'
Merged configuration 'C:/ncs-by-toolchain-app/v1.5.1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm/zephyr/.config'
Kconfig header saved to 'C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm
=== child image spm - end ===
CMake Warning at C:/ncs-by-toolchain-app/v1.5.1/zephyr/CMakeLists.txt:1357 (message):
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
[1/192] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[2/192] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[3/192] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h
[4/192] Generating include/generated/driver-validation.h
[5/192] Creating directories for 'spm_subimage'
[6/192] No download step for 'spm_subimage'
[7/192] No patch step for 'spm_subimage'
[8/192] No update step for 'spm_subimage'
[9/192] No configure step for 'spm_subimage'
[9/192] Performing build step for 'spm_subimage'
[1/206] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[2/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_external.dir/C_/ncs-by-toolchain-app/v1.5.1/zephyr/misc/empty_file.c.obj
[3/206] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/206] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h
[5/206] Generating include/generated/driver-validation.h
[6/206] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/206] Generating include/generated/offsets.h
[8/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/shared/CMakeFiles/mbedcrypto_shared.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/sha512.c.obj
[9/206] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[10/206] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[11/206] Generating linker.cmd
[12/206] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[13/206] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[14/206] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[15/206] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[16/206] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[17/206] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[18/206] Linking C static library zephyr\arch\common\libisr_tables.a
[19/206] Linking C static library zephyr\arch\common\libarch__common.a
[20/206] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[21/206] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[22/206] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[23/206] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[24/206] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[25/206] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[26/206] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[27/206] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[28/206] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[29/206] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[30/206] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[31/206] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[32/206] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[33/206] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_mpu.c.obj
[34/206] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_core_mpu.c.obj
[35/206] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[36/206] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[37/206] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\mpu\libarch__arm__core__aarch32__cortex_m__mpu.a
[38/206] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[39/206] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
[40/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[41/206] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
[42/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[43/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[44/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[45/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[46/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[47/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[48/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[49/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[50/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[51/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[52/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[53/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[54/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[55/206] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[56/206] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[57/206] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[58/206] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[59/206] Linking C static library zephyr\lib\posix\liblib__posix.a
[60/206] Building C object zephyr/boards/boards/arm/thingy91_nrf9160/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/board_secure.c.obj
[61/206] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[62/206] Linking C static library zephyr\boards\boards\arm\thingy91_nrf9160\lib..__nrf__boards__arm__thingy91_nrf9160.a
[63/206] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[64/206] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[65/206] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
[66/206] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
[67/206] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[68/206] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[69/206] Linking C static library zephyr\drivers\i2c\libdrivers__i2c.a
[70/206] Building C object CMakeFiles/app.dir/src/main.c.obj
[71/206] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[72/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[73/206] Linking C static library app\libapp.a
[74/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[75/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[76/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[77/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[78/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[79/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[80/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[81/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[82/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[83/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[84/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[85/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[86/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[87/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[88/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/work_q.c.obj
[89/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[90/206] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[91/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[92/206] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[93/206] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[94/206] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[95/206] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
[96/206] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[97/206] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/reboot.c.obj
[98/206] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/policy/policy_residency.c.obj
[99/206] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[100/206] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/power.c.obj
[101/206] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[102/206] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
[103/206] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs-by-toolchain-app/v1.5.1/nrf/lib/adp536x/adp536x.c.obj
[104/206] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs-by-toolchain-app/v1.5.1/nrf/subsys/spm/spm.c.obj
[105/206] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
[106/206] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
[107/206] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs-by-toolchain-app/v1.5.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[108/206] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs-by-toolchain-app/v1.5.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[109/206] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs-by-toolchain-app/v1.5.1/nrf/subsys/spm/secure_services.c.obj
[110/206] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[111/206] Linking C static library zephyr\libzephyr.a
[112/206] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[113/206] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[114/206] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/ncs-by-toolchain-app/v1.5.1/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[115/206] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/nrfx/nrfx_glue.c.obj
[116/206] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[117/206] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/ncs-by-toolchain-app/v1.5.1/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[118/206] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/ncs-by-toolchain-app/v1.5.1/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[119/206] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/ncs-by-toolchain-app/v1.5.1/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[120/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/shared/CMakeFiles/mbedcrypto_shared.dir/C_/ncs-by-toolchain-app/v1.5.1/zephyr/misc/empty_file.c.obj
[121/206] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\libmbedtls_external.a
[122/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/cc310/CMakeFiles/mbedcrypto_cc3xx_noglue.dir/C_/ncs-by-toolchain-app/v1.5.1/zephyr/misc/empty_file.c.obj
[123/206] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\cc310\libmbedcrypto_cc3xx_noglue.a
[124/206] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\shared\libmbedcrypto_shared.a
[125/206] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/ncs-by-toolchain-app/v1.5.1/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj
[126/206] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/ncs-by-toolchain-app/v1.5.1/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
[127/206] Generating libmbedcrypto_cc3xx.a
[128/206] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
[129/206] Linking C static library modules\hal_nordic\libmodules__hal_nordic.a
[130/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/base64.c.obj
[131/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/aesni.c.obj
[132/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/arc4.c.obj
[133/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/asn1write.c.obj
[134/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/asn1parse.c.obj
[135/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/aria.c.obj
[136/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/cipher_wrap.c.obj
[137/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/bignum.c.obj
[138/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/blowfish.c.obj
[139/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/cipher.c.obj
[140/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/camellia.c.obj
[141/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/error.c.obj
[142/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/entropy.c.obj
[143/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/entropy_poll.c.obj
[144/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/gcm.c.obj
[145/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/ctr_drbg.c.obj
[146/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/des.c.obj
[147/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/hmac_drbg.c.obj
[148/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/md2.c.obj
[149/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/havege.c.obj
[150/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/hkdf.c.obj
[151/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/md.c.obj
[152/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/md5.c.obj
[153/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/md4.c.obj
[154/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/oid.c.obj
[155/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/nist_kw.c.obj
[156/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/padlock.c.obj
[157/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/pkparse.c.obj
[158/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/pk_wrap.c.obj
[159/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/pkcs5.c.obj
[160/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/pkcs12.c.obj
[161/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/pk.c.obj
[162/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/pkwrite.c.obj
[163/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/timing.c.obj
[164/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/ripemd160.c.obj
[165/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/version.c.obj
[166/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/platform_util.c.obj
[167/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/platform.c.obj
[168/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/xtea.c.obj
[169/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/replacements/memory_buffer_alloc.c.obj
[170/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/ncs-by-toolchain-app/v1.5.1/mbedtls/library/version_features.c.obj
[171/206] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/replacements/pem.c.obj
[172/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[173/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[174/206] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\libmbedtls_base_vanilla.a
[175/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[176/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[177/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[178/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[179/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[180/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[181/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[182/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[183/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[184/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[185/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[186/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[187/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[188/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread_abort.c.obj
[189/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[190/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[191/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[192/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/smp.c.obj
[193/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[194/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[195/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work_q.c.obj
[196/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[197/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[198/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[199/206] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[200/206] Linking C static library zephyr\kernel\libkernel.a
[201/206] Linking C executable zephyr\zephyr_prebuilt.elf
FAILED: zephyr/zephyr_prebuilt.elf
cmd.exe /C "cd . && C:\ncs-by-toolchain-app\v1.5.1\toolchain\opt\bin\arm-none-eabi-gcc.exe zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr\zephyr_prebuilt.elf -Wl,-T zephyr/linker.cmd -Wl,-Map=C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/libarch__arm__core__aarch32__cortex_m__mpu.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/libarch__arm__core__aarch32__cortex_m__tz.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/boards/boards/arm/thingy91_nrf9160/lib..__nrf__boards__arm__thingy91_nrf9160.a zephyr/drivers/i2c/libdrivers__i2c.a zephyr/drivers/serial/libdrivers__serial.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/nrfxlib/nrf_security/src/mbedtls/libmbedtls_base_vanilla.a modules/hal_nordic/libmodules__hal_nordic.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"c:/ncs-by-toolchain-app/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main+fp/hard" -LC:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm/zephyr -lgcc -Wl,--print-memory-usage zephyr/arch/common/libisr_tables.a modules/nrfxlib/nrf_security/src/mbedtls/shared/libmbedcrypto_shared.a modules/nrfxlib/nrf_security/src/mbedtls/cc310/libmbedcrypto_cc3xx.a C:/ncs-by-toolchain-app/v1.5.1/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_platform_0.9.7.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,--out-implib=C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/spm/libspmsecureentries.a -Wl,--cmse-implib && cd ."
Memory region Used Size Region Size %age Used
FLASH: 64 KB 48 KB 133.33%
SRAM: 8768 B 64 KB 13.38%
IDT_LIST: 88 B 2 KB 4.30c:/ncs-by-toolchain-app/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr\zephyr_prebuilt.elf section `.gnu.sgstubs' will not fit in region `FLASH'
c:/ncs-by-toolchain-app/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: SPM and app are sharing an SPU region. Cannot partition flash correctly into secure and non-secure. Adjust partitions sizes so they are placed in separate regions.
c:/ncs-by-toolchain-app/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 16384 bytes
collect2.exe: error: ld returned 1 exit status
FAILED: modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build spm/zephyr/zephyr.hex spm/zephyr/zephyr.elf spm/libspmsecureentries.a
cmd.exe /C "cd /D C:\ncs-by-toolchain-app\v1.5.1\nrf\samples\nrf9160\at_client\build\spm && C:\ncs-by-toolchain-app\v1.5.1\toolchain\opt\bin\cmake.exe --build . --"
FATAL ERROR: command exited with status 1: 'C:\ncs-by-toolchain-app\v1.5.1\toolchain\opt\bin\cmake.EXE' --build 'C:\ncs-by-toolchain-app\v1.5.1\nrf\samples\nrf9160\at_client\build'
Test 2: secure build target
$ west build -b thingy91_nrf9160 --pristine
-- west build: making build dir C:\ncs-by-toolchain-app\v1.5.1\nrf\samples\nrf9160\at_client\build pristine
-- Configuring done
-- Generating done
[1/180] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[2/180] Generating include/generated/driver-validation.h
[3/180] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/180] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h
[5/180] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[6/180] Generating include/generated/offsets.h
[7/180] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[8/180] Generating linker.cmd
[9/180] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[10/180] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[11/180] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[12/180] Linking C static library zephyr\arch\common\libisr_tables.a
[13/180] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[14/180] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[15/180] Linking C static library zephyr\arch\common\libarch__common.a
[16/180] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[17/180] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[18/180] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[19/180] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[20/180] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[21/180] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[22/180] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[23/180] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[24/180] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[25/180] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[26/180] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[27/180] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[28/180] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[29/180] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[30/180] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[31/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[32/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[33/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[34/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[35/180] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_core_mpu.c.obj
[36/180] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_mpu.c.obj
[37/180] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[38/180] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[39/180] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[40/180] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\mpu\libarch__arm__core__aarch32__cortex_m__mpu.a
[41/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[42/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[43/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[44/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[45/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[46/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[47/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[48/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[49/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[50/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[51/180] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[52/180] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[53/180] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[54/180] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[55/180] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[56/180] Linking C static library zephyr\lib\posix\liblib__posix.a
[57/180] Building C object zephyr/boards/boards/arm/thingy91_nrf9160/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/board_secure.c.obj
[58/180] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[59/180] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
[60/180] Linking C static library zephyr\boards\boards\arm\thingy91_nrf9160\lib..__nrf__boards__arm__thingy91_nrf9160.a
[61/180] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
[62/180] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
[63/180] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
[64/180] Linking C static library zephyr\subsys\net\libsubsys__net.a
[65/180] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
[66/180] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[67/180] Linking C static library zephyr\subsys\net\ip\libsubsys__net__ip.a
[68/180] Linking C static library zephyr\subsys\random\libsubsys__random.a
[69/180] Building C object CMakeFiles/app.dir/src/main.c.obj
[70/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[71/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[72/180] Linking C static library app\libapp.a
[73/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[74/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[75/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[76/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[77/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[78/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[79/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[80/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[81/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[82/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[83/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[84/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[85/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[86/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[87/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/work_q.c.obj
[88/180] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[89/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[90/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[91/180] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[92/180] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[93/180] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[94/180] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[95/180] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[96/180] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[97/180] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/getaddrinfo.c.obj
[98/180] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/socket_offload.c.obj
[99/180] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/power.c.obj
[100/180] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets_select.c.obj
[101/180] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets.c.obj
[102/180] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/reboot.c.obj
[103/180] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
[104/180] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
[105/180] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/policy/policy_residency.c.obj
[106/180] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
[107/180] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
[108/180] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs-by-toolchain-app/v1.5.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[109/180] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs-by-toolchain-app/v1.5.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[110/180] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs-by-toolchain-app/v1.5.1/nrf/lib/adp536x/adp536x.c.obj
[111/180] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
[112/180] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
[113/180] Linking C static library zephyr\libzephyr.a
[114/180] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
[115/180] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[116/180] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[117/180] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[118/180] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[119/180] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/ncs-by-toolchain-app/v1.5.1/nrf/drivers/entropy/entropy_cc310.c.obj
[120/180] Linking C static library zephyr\drivers\i2c\libdrivers__i2c.a
[121/180] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
FAILED: modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
C:\ncs-by-toolchain-app\v1.5.1\toolchain\opt\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v2.4.99-ncs2 -DKERNEL -DNRF9160_XXAA -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs-by-toolchain-app/v1.5.1/zephyr/include -Izephyr/include/generated -IC:/ncs-by-toolchain-app/v1.5.1/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/ncs-by-toolchain-app/v1.5.1/zephyr/subsys/net/lib/sockets/. -I../../../../include -I../../../../lib/at_notif/. -IC:/ncs-by-toolchain-app/v1.5.1/nrfxlib/nrf_modem/include -IC:/ncs-by-toolchain-app/v1.5.1/modules/hal/nordic/nrfx -IC:/ncs-by-toolchain-app/v1.5.1/modules/hal/nordic/nrfx/drivers/include -IC:/ncs-by-toolchain-app/v1.5.1/modules/hal/nordic/nrfx/mdk -IC:/ncs-by-toolchain-app/v1.5.1/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs-by-toolchain-app/v1.5.1/modules/hal/cmsis/CMSIS/Core/Include -isystem C:/ncs-by-toolchain-app/v1.5.1/zephyr/lib/libc/minimal/include -isystem c:/ncs-by-toolchain-app/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/ncs-by-toolchain-app/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem C:/ncs-by-toolchain-app/v1.5.1/nrfxlib/crypto/nrf_cc310_platform/include -Os -imacros C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -imacros C:/ncs-by-toolchain-app/v1.5.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/ncs-by-toolchain-app/v1.5.1/nrf/samples/nrf9160/at_client=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs-by-toolchain-app/v1.5.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs-by-toolchain-app/v1.5.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj -MF modules\nrf\lib\nrf_modem_lib\CMakeFiles\..__nrf__lib__nrf_modem_lib.dir\nrf_modem_os.c.obj.d -o modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj -c C:/ncs-by-toolchain-app/v1.5.1/nrf/lib/nrf_modem_lib/nrf_modem_os.c
C:/ncs-by-toolchain-app/v1.5.1/nrf/lib/nrf_modem_lib/nrf_modem_os.c:16:10: fatal error: pm_config.h: No such file or directory
16 | #include <pm_config.h>
compilation terminated.
[122/180] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
/Johan
