LWM2M Client fails to upgrade modem firmware
modem fw 1.3.0
ncs 1.5.0 and master
I am trying to test modem firmware upgrades using the lwm2m client sample and every time it is writing the 20% downloaded chunk, the modem throws an
DFU_ERROR_INTERNAL_03 error. The modem firmware delta is attached
Log of downloading the firmware and error applying firmware
uart:~$ *** Booting Zephyr OS build v2.4.99-ncs1  ***
[00:00:00.207,794] <dbg> net_lwm2m_engine.lwm2m_engine_init: LWM2M engine socket receive thread started
[00:00:00.207,885] <dbg> net_lwm2m_obj_security.security_create: Create LWM2M security instance: 0
--- 20 messages dropped ---
[00:00:00.207,916] <dbg> net_lwm2m_obj_server.server_create: Create LWM2M server instance: 0
[00:00:00.208,007] <dbg> net_lwm2m_obj_device.device_create: Create LWM2M device instance: 0
[00:00:00.208,038] <dbg> net_lwm2m_obj_conn_mon.connmon_create: Create LWM2M connectivity monitoring instance: 0
[00:00:00.208,068] <dbg> net_lwm2m_obj_firmware.firmware_create: Create LWM2M firmware instance: 0
[00:00:00.208,099] <dbg> net_lwm2m_obj_location.location_create: Create Location instance: 0
[00:00:00.208,526] <inf> app_lwm2m_client: Run LWM2M client
[00:00:00.208,740] <dbg> app_lwm2m_client.main: Set DNS to custom address 8.8.8.8
[00:00:00.209,503] <inf> app_lwm2m_client: Initializing modem.
[00:00:00.233,459] <dbg> net_ipso_onoff_switch.switch_create: Create IPSO On/Off Switch instance: 1
[00:00:00.233,520] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:3342/1/5500, value:0x20025c27, len:1
[00:00:00.233,581] <dbg> net_lwm2m_engine.lwm2m_engine_create_obj_inst: path:3313/0
[00:00:00.233,642] <dbg> net_ipso_accel.accel_create: Create IPSO Accelerometer instance: 0
[00:00:00.233,734] <dbg> net_lwm2m_engine.lwm2m_engine_get: path:3/0/13, buf:0x20025c14, buflen:4
[00:00:00.233,764] <inf> app_lwm2m_accel: accelerometer normal
[00:00:00.233,795] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:3313/0/5702, value:0x20025c18, len:8
[00:00:00.233,856] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:3313/0/5703, value:0x20025c18, len:8
[00:00:00.233,917] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:3313/0/5704, value:0x20025c18, len:8
[00:00:00.233,978] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:3313/0/5518, value:0x20025c04, len:4
[00:00:00.234,039] <inf> app_lwm2m_firmware: Update Counter: current 0, update 0
[00:00:00.234,069] <inf> app_lwm2m_firmware: Image is not confirmed OK
[00:00:00.234,130] <inf> app_lwm2m_firmware: Marked image as OK
[00:00:00.234,313] <inf> app_lwm2m_firmware: Update Counter updated
[00:00:00.234,344] <inf> app_lwm2m_firmware: Firmware updated successfully
[00:00:00.234,375] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:5/0/5, value:0x20025c17, len:1
[00:00:01.896,240] <inf> app_lwm2m_client: Connecting to LTE network.
[00:00:01.896,270] <inf> app_lwm2m_client: This may take several minutes.
[00:00:01.896,331] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,1,0
[00:00:05.006,256] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"2332","02592A20",9
[00:00:05.332,702] <dbg> lte_lc.at_handler: +CSCON notification
[00:00:06.644,134] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 5,"2332","02592A20",9,,,"11100000","00101000"
[00:00:06.644,470] <dbg> lte_lc.parse_psm_cfg: TAU: 28800 sec, active time: -1 sec
[00:00:06.644,592] <inf> app_lwm2m_client: Connected to LTE network
[00:00:06.646,118] <inf> net_lwm2m_rd_client: Start LWM2M Client: nrf-352656106650180
[00:00:06.680,450] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:4/0/0, value:0x20026d7f, len:1
[00:00:06.680,603] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:4/0/8, value:0x20026d7c, len:4
[00:00:06.680,633] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:4/0/9, value:0x20026d7e, len:2
[00:00:06.680,664] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:4/0/10, value:0x20026d7e, len:2
[00:00:06.680,786] <dbg> net_lwm2m_engine.lwm2m_engine_set: path:4/0/2, value:0x20026d77, len:1
[00:00:07.209,075] <dbg> net_lwm2m_engine.lwm2m_engine_get: path:0/0/1, buf:0x20023767, buflen:1
[00:00:07.209,167] <dbg> net_lwm2m_engine.lwm2m_engine_get: path:0/0/10, buf:0x20023792, buflen:2
[00:00:07.209,197] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'nrf-352656106650180' with client lifetime 0
[00:00:07.209,259] <dbg> net_lwm2m_engine.lwm2m_parse_peerinfo: Parse url: coaps://leshan.eclipseprojects.io
[00:00:08.624,542] <dbg> net_lwm2m_engine.lwm2m_engine_get: path:1/0/1, buf:0x20023750, buflen:4
[00:00:08.626,220] <dbg> net_lwm2m_rd_client.sm_send_registration: registration sent [23.97.187.154]
[00:00:08.804,229] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:08.804,260] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:08.804,260] <dbg> net_lwm2m_rd_client.do_registration_reply_cb: Registration callback (code:2.1)
[00:00:08.804,290] <dbg> app_lwm2m_client.rd_client_event: Registration complete
[00:00:08.804,321] <inf> net_lwm2m_rd_client: Registration Done (EP='ItPzcT0F3x')
[00:00:08.804,351] <dbg> net_lwm2m_engine.lwm2m_udp_receive: reply 0x2001505c handled and removed
[00:00:15.982,482] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:15.982,513] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:22.163,604] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:22.163,635] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:22.163,696] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:22.163,879] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:0 last:0
[00:00:22.163,909] <dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_state: Update state = 1
[00:00:22.164,642] <inf> dfu_target_modem_delta: Modem DFU Socket created
[00:00:22.164,947] <inf> dfu_target_modem_delta: Modem firmware version: e7f4d5d4-f607-43a6-b383-cfdb6d725c82
[00:00:22.165,710] <inf> dfu_target_modem_delta: Deleting firmware image, this can take several minutes
[00:00:32.318,206] <dbg> lte_lc.at_handler: +CSCON notification
[00:00:37.908,569] <inf> dfu_target_modem_delta: Modem FW delete complete
[00:00:37.908,599] <inf> app_lwm2m_firmware: Modem firmware download started.
[00:00:37.946,166] <inf> app_lwm2m_firmware: Downloaded 1%
[00:00:38.559,051] <dbg> lte_lc.at_handler: +CSCON notification
[00:00:38.794,372] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:38.794,372] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:38.794,372] <dbg> net_lwm2m_engine.lwm2m_udp_receive: No handler for response
[00:00:47.148,498] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:47.148,529] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:47.148,590] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:47.148,773] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:0 last:0
[00:00:47.148,803] <inf> app_lwm2m_firmware: Downloaded 3%
[00:00:47.149,261] <inf> app_lwm2m_firmware: Downloaded 5%
[00:00:47.449,096] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:47.449,096] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:47.449,188] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:47.449,310] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:512 last:0
[00:00:47.449,371] <inf> app_lwm2m_firmware: Downloaded 7%
[00:00:47.711,090] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:47.711,151] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:47.711,212] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:47.711,334] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:768 last:0
[00:00:47.711,395] <inf> app_lwm2m_firmware: Downloaded 9%
[00:00:48.015,106] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:48.015,136] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:48.015,197] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:48.015,350] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:1024 last:0
[00:00:48.015,380] <inf> app_lwm2m_firmware: Downloaded 11%
[00:00:48.346,099] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:48.346,130] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:48.346,191] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:48.346,343] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:1280 last:0
[00:00:48.346,374] <inf> app_lwm2m_firmware: Downloaded 12%
[00:00:48.691,131] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:48.691,162] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:48.691,223] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:48.691,375] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:1536 last:0
[00:00:48.691,406] <inf> app_lwm2m_firmware: Downloaded 14%
[00:00:49.003,143] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:49.003,173] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:49.003,234] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:49.003,387] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:1792 last:0
[00:00:49.003,448] <inf> app_lwm2m_firmware: Downloaded 16%
[00:00:49.554,168] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:49.554,199] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:49.554,260] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:49.554,412] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:2048 last:0
[00:00:49.554,443] <inf> app_lwm2m_firmware: Downloaded 18%
[00:00:49.850,189] <err> net_lwm2m_engine: Unknown IP address family:0
[00:00:49.850,219] <dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[00:00:49.850,280] <dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[00:00:49.850,433] <dbg> net_lwm2m_engine.lwm2m_write_handler: BLOCK1: total:13772 current:2304 last:0
[00:00:49.850,463] <inf> app_lwm2m_firmware: Downloaded 20%
[00:00:49.852,050] <err> dfu_target_modem_delta: send failed, modem errno 8, dfu err -5
[00:00:49.852,050] <err> app_lwm2m_firmware: dfu_target_write error, err -14
[00:00:49.852,050] <inf> dfu_target_modem_delta: Modem upgrade aborted.
[00:00:49.852,508] <dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_state: Update state = 0
[00:00:49.852,539] <dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_result: Update result = 5
uart:~$
I got the same result from using NCS v1.5.0 and on master.
I added in a custom DNS server as our SIM provider doesn't serve one from the network but otherwise, the sample is unchanged
