I am using the simple code below to generate a signal from a memory buffer.
I cannot generate a signal cyclically. If ONE sequence is used, then the buffer is played once. If use TWO sequences, the signal is generated continuously. How do I do continuous generation with ONE sequence?
Thank you
#define PWM NRF_PWM1
#define PWM_PIN (17UL)
#define TIMER_RELOAD 10000
#define buffer_size 256
uint16_t pwm_buffer[ buffer_size ];
for( uint16_t j = 0; j < buffer_size; j++) {
pwm_buffer[j] = j << 4;
PWM->PSEL.OUT[0] = (PWM_PIN << PWM_PSEL_OUT_PIN_Pos) |
(PWM_PSEL_OUT_CONNECT_Connected << PWM_PSEL_OUT_CONNECT_Pos);
PWM->ENABLE = (PWM_ENABLE_ENABLE_Enabled << PWM_ENABLE_ENABLE_Pos);
PWM->MODE = (PWM_MODE_UPDOWN_Up << PWM_MODE_UPDOWN_Pos);
PWM->DECODER = (PWM_DECODER_LOAD_Common << PWM_DECODER_LOAD_Pos) |
(PWM_DECODER_MODE_RefreshCount << PWM_DECODER_MODE_Pos);
PWM->PRESCALER = (PWM_PRESCALER_PRESCALER_DIV_16 << PWM_PRESCALER_PRESCALER_Pos);
PWM->COUNTERTOP = (TIMER_RELOAD << PWM_COUNTERTOP_COUNTERTOP_Pos);
PWM->SEQ[0].PTR = ((uint32_t)(pwm_buffer) << PWM_SEQ_PTR_PTR_Pos);
PWM->SEQ[0].CNT = ((sizeof(pwm_buffer) / sizeof(uint16_t)) << PWM_SEQ_CNT_CNT_Pos);
//PWM->SEQ[1].PTR = ((uint32_t)(pwm_buffer) << PWM_SEQ_PTR_PTR_Pos);
//PWM->SEQ[1].CNT = ((sizeof(pwm_buffer) / sizeof(uint16_t)) << PWM_SEQ_CNT_CNT_Pos);
PWM->SEQ[0].REFRESH = 0;
PWM->SEQ[0].ENDDELAY = 0;
//PWM->LOOP = (PWM_LOOP_CNT_Disabled << PWM_LOOP_CNT_Pos);
PWM->LOOP = (4 << PWM_LOOP_CNT_Pos);
PWM->SHORTS = PWM_SHORTS_LOOPSDONE_SEQSTART0_Msk;
PWM->TASKS_SEQSTART[0] = 1;
