I've recently been porting a program over to Zephyr and hoping someone here might be able to shed some insight on this issue.
I can't seem to get flash_write to actually write anything even though it returns successful.
Here is my device tree section,
/* Flash Layout * Bootloader 0x00000 - 0x10000 (Size 0x10000 65536 Bytes) * Code 0x10000 - 0xFC000 (Size 0xEC000 966656 Bytes) * NVM Data 0xFC000 - 0x100000 (Size 0x4000 16384 Bytes) */ &flash0 { partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; code_partition: partition@10000 { label = "code"; reg = <0x10000 0xEC000>; read-only; }; datapt_partition: partition@EC000 { label = "datapt"; reg = <0xEC000 0x4000>; }; }; };
And KConfig,
# Flash CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_SOC_FLASH_NRF=y CONFIG_MPU_ALLOW_FLASH_WRITE=y
And finally the code,
#define FLASH_ADDR FLASH_AREA_OFFSET(datapt) #define FLASH_SPACE FLASH_AREA_SIZE(datapt) void flash_Init() { flash_device = device_get_binding(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL); if (!flash_device) { serialWrite("**No flash controller found!**\r\n"); serialWrite("Run set_device <name> to specify one before using other commands.\r\n"); return; } serialWrite("Found flash controller %s.\r\n"); serialWrite(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL); serialWrite("Flash I/O commands can be run.\r\n"); } int writeFlash(const char *datain, int len) { if(!flash_device) return -1; // Don't let other flash get overwritten if(len > FLASH_SPACE) return -1; // Erase flash space, enough for all settings. JSON formatted printf("HT: Flash Address %#10x \r\n", FLASH_ADDR); printf("HT: Flash Space %d\r\n", FLASH_SPACE); if(flash_erase(flash_device, FLASH_ADDR, FLASH_SPACE) != 0) { printf("HT: Flash Erase Failed"); return -1; } printf("HT: Flash Space Erased (%d bytes)\r\n", FLASH_SPACE); int rv = flash_write(flash_device, FLASH_ADDR, datain, len); if(!rv) { printf("HT: Flash Write Failure %d\r\n", rv); return -1; } return 0; }
When I call write flash it returns success, but if I examine the memory after at 0xEC000 it's still all erased at 0xFF
Did I do something wrong here? Not sure if this is a Zephyr specific thing or part of Nordics driver.. so I'm asking here first.
Thank you for any help
