unstable connection from IoT example: ipv6_icmp to RPI border router
 I use nRF52832 DK as the node and RPI as the border router.
I fowllowed the guide setup the border router and flash the example ipv6_icmp to the nRF52832 DK.
The connection can be established. The local-link address is right.But I can not find the global address.
And most important thing is that the connection can only last about a few seconds, then disconnected unexpectly.
Is there something wrong ?
mount -t debugfs none /sys/kernel/debug
echo 1 > /sys/kernel/debug/bluetooth/6lowpan_enable
echo "connect 00:E9:92:E1:xx:xx 1" > /sys/kernel/debug/bluetooth/6lowpan_control
/home/pi# ifconfig bt0
bt0: flags=4161<UP,RUNNING,MULTICAST> mtu 1280
inet6 fe80::dca6:32ff:fexx:xxxx prefixlen 64 scopeid 0x20<link>
unspec DC-A6-32-xx-xx-xx-00-00-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 6 bytes 361 (361.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
/home/pi# ping6 -I bt0 fe80::e9:92ff:fee1:xxxx
ping6: Warning: source address might be selected on device other than bt0.
PING fe80::e9:92ff:fee1:9871(fe80::e9:92ff:fee1:9871) from :: bt0: 56 data bytes
64 bytes from fe80::e9:92ff:fee1:9871%bt0: icmp_seq=1 ttl=64 time=62.2 ms
64 bytes from fe80::e9:92ff:fee1:9871%bt0: icmp_seq=2 ttl=64 time=84.9 ms
64 bytes from fe80::e9:92ff:fee1:9871%bt0: icmp_seq=3 ttl=64 time=107 ms
ping: sendmsg: \u6ca1\u6709\u90a3\u4e2a\u8bbe\u5907
^C
--- fe80::e9:92ff:fee1:9871 ping statistics ---
15 packets transmitted, 10 received, 33.3333% packet loss, time 168ms
rtt min/avg/max/mdev = 54.804/78.305/106.797/16.196 ms
bt0: error fetching interface information: Device not found
    bluetooth 6lowpan examples have been deprecated (removed) from newer nRF5 SDK versions.
    Which SDK are you using?
     The global address is something you assign on the host side. See here: https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/iot_ug_border_router.html?cp=8_5_1_5_5_0
    You have to debug why the connection is lost. Does the nRF assert or similar? What does the logs state on the RPi side?
    Håkon
  • I'm using the nrf52 SDK 16.0, and I follow the instructions the index you provided.
    I'd like to know why the bluetooth 6lowpan removed.
  • /var/log/syslog
    message below repeats everytime trying to connect:
    May 29 16:04:22 raspberrypi bluetoothd[5362]: No cache for 00:E9:92:E1:98:71
    May 29 16:04:24 raspberrypi avahi-daemon[393]: Joining mDNS multicast group on interface bt0.IPv6 with address fe80::dca6:32ff:fed1:1e2c.
    May 29 16:04:24 raspberrypi avahi-daemon[393]: New relevant interface bt0.IPv6 for mDNS.
    May 29 16:04:24 raspberrypi avahi-daemon[393]: Registering new address record for fe80::dca6:32ff:fed1:1e2c on bt0.*.
    May 29 16:04:24 raspberrypi kernel: [ 8085.977647] Bluetooth: hci0: link tx timeout
    May 29 16:04:24 raspberrypi kernel: [ 8086.415729] Bluetooth: hci0: link tx timeout
    May 29 16:04:25 raspberrypi kernel: [ 8086.819299] Bluetooth: hci0: link tx timeout
    May 29 16:04:25 raspberrypi ModemManager[392]: <info> Couldn't check support for device '/sys/devices/platform/soc': not supported by any plugin
    May 29 16:04:25 raspberrypi ntpd[551]: Listen normally on 36 bt0 [fe80::dca6:32ff:fed1:1e2c%22]:123
    May 29 16:04:25 raspberrypi ntpd[551]: new interface(s) found: waking up resolver
    May 29 16:05:02 raspberrypi avahi-daemon[393]: Interface bt0.IPv6 no longer relevant for mDNS.
    May 29 16:05:02 raspberrypi avahi-daemon[393]: Leaving mDNS multicast group on interface bt0.IPv6 with address fe80::dca6:32ff:fed1:1e2c.
    May 29 16:05:02 raspberrypi avahi-daemon[393]: Withdrawing address record for fe80::dca6:32ff:fed1:1e2c on bt0.
    May 29 16:05:04 raspberrypi ntpd[551]: Deleting interface #36 bt0, fe80::dca6:32ff:fed1:1e2c%22#123, interface stats: received=0, sent=0, dropped=0, active_time=39 secs
    What does the firmware itself state? Does it show any uart output that might give an indication on what the disconnect reason is?
    Håkon
    The firmware didn't use uart as output.But I checked the RTT LOG info.
    I found no error in the log. I only got this message when the connection breaks:
       <info>  app: Interface removed!
       <info>  app: Physical layer disconnected.
       <info>  app: Physical layer in connectable mode.
    I think the firmware runs well.The problem must happends in the RPI.
    But I'm not familar with this part of RPI.
    I hope I can get help from you guys.
    Tanks a lot.
    Sincerely regards,
    mark baum
