how to make nrf dongle to enter reset by using software
Hi support team,
i'm using nrf dongle 52840 to update firmware for orther device, but somethime i can not able to access to send some command until hard disconnect from usb port or power down system. i can not find any command to make dongle reset by using nrfutil command. Is there anyway to make it reset?
Thanks.
Parents Reply
    The fundamental difference between the DK and the dongle is that the dongle doesn't have a programmer on board. Any communication for programming with the dongle is via a bootloader.
    So if the dongle is unresponsive it won't be able to do any command because the CPU is blocked.
    If you want to trigger a reset, you can think of connecting a DK (or a programmer) to the dongle ( you need to solder the header on the P1 port). You can use nrfjprog --reset when you connect the programmer/DK to the dongle.
    But then it's not much point using a dongle, you can just use the DK.
