sd_ble_gatts_hvx() no return
Now i use sd_ble_gatts_hvx() to send data,it can not return anything while call this function. Step by step trace this function,while it run to code address 0x00016432,function compare two data,one data is store in 0x00016478( data value is 0xDEADBEEF),another data is store in 0x2000012c(data value is 0). If compare result is not equal ,function will fetch HardFault_handler entry and goto HardFault_handler. if manual update this data value from 0x00000000 to 0xDEADBEEF that store in 0x2000012c ,made it compare result is equal.then function is ok. What should i do to solve this program ?
Thanks!
  • Seems like a softdevice assert and call to assert_nrf_callback in your application. It is hard to say what caused this assert. Can you post your code?
  • this is my code to call sd_ble_gatts_hvx().
    uint32_t ble_ccb_ll_cpt_send(ble_ccb_t * p_ccb, ble_ccb_write_t * p_write) { uint32_t err_code;
    if (p_ccb == NULL)
        return NRF_ERROR_NULL;
    // Send value if connected
    if (p_ccb->conn_handle != BLE_CONN_HANDLE_INVALID)
        uint16_t               len;
        uint16_t               hvx_len;
        ble_gatts_hvx_params_t hvx_params;
        len     = p_write->len;
        hvx_len = len;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_ccb->ccb_ll_cpt_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_INDICATION;
        hvx_params.offset = 0;
        hvx_params.p_len  = &hvx_len;
        hvx_params.p_data = p_write->p_data;
        err_code = sd_ble_gatts_hvx(p_ccb->conn_handle, &hvx_params);
        if ((err_code == NRF_SUCCESS) && (hvx_len != len))
            err_code = NRF_ERROR_DATA_SIZE;
        err_code = NRF_ERROR_INVALID_STATE;
    return err_code;
    there is disassembly code to call sd_ble_gatts_hvx():
    646: err_code = sd_ble_gatts_hvx(p_ccb->conn_handle, &hvx_params);
    0x0001A8D6 88E0 LDRH r0,[r4,#0x06]
    0x0001A8D8 4669 MOV r1,sp
    0x0001A8DA DFA6 SVC 0xA6
    0x0001A8DC 4605 MOV r5,r0
    then branch to there:
    0x000006B0 4B01 LDR r3,[pc,#4] ; @0x000006B8
    0x000006B2 681B LDR r3,[r3,#0x00]
    0x000006B4 68DB LDR r3,[r3,#0x0C]
    0x000006B6 4718 BX r3
    and ,branch to there.why there need compare two data?0x0001645A start is fetch HardFault_Handler entry and branch to it.
    0x00016432 4A11 LDR r2,[pc,#68] ; @0x00016478
    0x00016434 4B0F LDR r3,[pc,#60] ; @0x00016474
    0x00016436 681B LDR r3,[r3,#0x00]
    0x00016438 429A CMP r2,r3
    0x0001643A D10E BNE 0x0001645A
    0x0001643C 4B0D LDR r3,[pc,#52] ; @0x00016474
    0x0001643E 2000 MOVS r0,#0x00
    0x00016440 6018 STR r0,[r3,#0x00]
    0x00016442 9801 LDR r0,[sp,#0x04]
    0x00016444 4B0D LDR r3,[pc,#52] ; @0x0001647C
    0x00016446 B504 PUSH {r2,lr}
    0x00016448 4798 BLX r3
    0x0001644A BC0C POP {r2-r3}
    0x0001644C 469E MOV lr,r3
    0x0001644E 4602 MOV r2,r0
    0x00016450 9802 LDR r0,[sp,#0x08]
    0x00016452 9900 LDR r1,[sp,#0x00]
    0x00016454 4B0A LDR r3,[pc,#40] ; @0x00016480
    0x00016456 681B LDR r3,[r3,#0x00]
    0x00016458 4718 BX r3
    0x0001645A 9806 LDR r0,[sp,#0x18]
    0x0001645C 9905 LDR r1,[sp,#0x14]
    0x0001645E 4B09 LDR r3,[pc,#36] ; @0x00016484
    0x00016460 681B LDR r3,[r3,#0x00]
    0x00016462 68DB LDR r3,[r3,#0x0C]
    0x00016464 4718 BX r3
    0x00016466 0000 MOVS r0,r0
    0x00016468 0134 LSLS r4,r6,#4
    0x0001646A 2000 MOVS r0,#0x00
    0x0001646C 0138 LSLS r0,r7,#4
    0x0001646E 2000 MOVS r0,#0x00
    0x00016470 013C LSLS r4,r7,#4
    0x00016472 2000 MOVS r0,#0x00
    0x00016474 012C LSLS r4,r5,#4
    0x00016476 2000 MOVS r0,#0x00
    0x00016478 BEEF BKPT 0xEF
    0x0001647A DEAD DCW 0x0000
  • Thanks RK, Sam, you have same question in another post and this is actively being answered, please followit up there and I will close this issue.
  • Now ,i confirm sd_ble_gatts_hvx() should not be call in gpiote_event_handler().
