SAADC example's saadc_callback has a buffer "p_event->data.done.p_buffer" in a for loop, is not printing full buffer size data.
Hi.
I am using nRF52840 dongle and running saadc example on it.
To print the ADC data buffer "p_event->data.done.p_buffer" in PC, I am using USB_CDC. The size of SAMPLES_IN_BUFFER is 5.
In the "saadc_sampling_event_init()", 400 is the parameter value passed in the nrf_drv_timer_ms_to_ticks() function.
However, I am only getting one data in the for loop from the saadc_callback. Actually I should get 5 data.
Any reason why this happens?
Thank you.
    How are you printing the buffer? You will either need to print each element in p_event->data.done.p_buffer:
    printf("%d", p_event->data.done.p_buffer[0]);
    printf("%d", p_event->data.done.p_buffer[1]);
    printf("%d", p_event->data.done.p_buffer[2]);
    etc,
    Or you can take in the size of the pointer as an argument to know how much you need to print, for example using NRF_LOG_HEXDUMP_INFO.
    Marjeris
  • Hi Marjeris.
    Sorry for so much late.
    I am filling up two buffers of 5 capacity each. I am printing as below pic, inside the call back. And I get the output as in the next pic.
    The USBPrint function internally fills up a buffer containing the parameter information and does a "app_usbd_cdc_acm_write".
    So, the for loop is not running correctly I guess. Or may be I am wrong and something else is there. Only two indexes are printing out of 5.
    I did the way you have shared. Printed each values of the buffer individually. Still its the same output is coming on teraterm.
    But I tried printing the buffer outside the call back. And all data are printed.
    I have not changed the value 400 in "nrf_drv_timer_ms_to_ticks".
    This number(400) is the sampling rate of the ADC. Right?
    Thank you.
    I am sorry for not getting back to you on this. Could you attach your whole project here so I can run and verify the issue myself?
    It could be for instance that SAMPLES_IN_BUFFER is defined incorrectly, but it's difficult to point to the reason why the buffer is filling up without taking a look at the whole project.
    Marjeris
