I'm using PWM driver DEMO5 to change the voltage of IOs.Now I need different voltage ranges.
Here is my code:
void demoPWM(void)
* This demo, similarly to demo1, plays back a sequence with different
* values for individual channels. Unlike demo 1, however, it does not use
* an event handler. Therefore, the PWM peripheral does not use interrupts
* and the CPU can stay in sleep mode.
* The LEDs (1-4) blink separately. They are turned on for 125 ms each,
* in counterclockwise order (looking at the board).
nrf_drv_pwm_config_t const config0 =
.output_pins =
CTRL1_PIN | NRF_DRV_PWM_PIN_INVERTED, // channel 0
NRF_DRV_PWM_PIN_NOT_USED, // channel 1 RED_PIN
NRF_DRV_PWM_PIN_NOT_USED, // channel 2
NRF_DRV_PWM_PIN_NOT_USED // channel 3
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.base_clock = NRF_PWM_CLK_125kHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 625, //15625 -- 125ms 626 -- 5ms
.load_mode = NRF_PWM_LOAD_INDIVIDUAL,
.step_mode = NRF_PWM_STEP_AUTO
APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL));
m_used |= USED_PWM(0);
// This array cannot be allocated on stack (hence "static") and it must
// be in RAM (hence no "const", though its content is not changed).
static nrf_pwm_values_individual_t /*const*/ seq_values[] =
0x1D5 //2.5v 0.75
static nrf_pwm_values_individual_t /*const*/ mid_values[] =
0x155 //1.8v 0.54
static nrf_pwm_values_individual_t /*const*/ low_values[] =
0xBC //1.0v 0.33
nrf_pwm_sequence_t const seq =
.values.p_individual = seq_values,
.length = NRF_PWM_VALUES_LENGTH(seq_values),
.repeats = 0,
.end_delay = 0
nrf_pwm_sequence_t const mid_seq =
.values.p_individual = mid_values,
.length = NRF_PWM_VALUES_LENGTH(mid_values),
.repeats = 0,
.end_delay = 0
nrf_pwm_sequence_t const low_seq =
.values.p_individual = low_values,
.length = NRF_PWM_VALUES_LENGTH(low_values),
.repeats = 0,
.end_delay = 0
if(cycle == 2)
(void)nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1, NRF_DRV_PWM_FLAG_LOOP);
}else if(cycle == 4)
(void)nrf_drv_pwm_simple_playback(&m_pwm0, &mid_seq, 1, NRF_DRV_PWM_FLAG_LOOP);
}else if(cycle == 6)
(void)nrf_drv_pwm_simple_playback(&m_pwm0, &low_seq, 1, NRF_DRV_PWM_FLAG_LOOP);
The voltage will change when button is pushed,but the voltage is not accurate.Is there a better way?
BTW, I need the IO to output low after reached a certain voltage value.So I used nrf_drv_pwm_uninit(&m_pwm0), but the IO output high.
The SDK is SDK14.2.
