Hi
We need clarification about Nordic Advertiser Extensions (Instaburst).
1. The document (Nordic Advertiser Extensions (Instaburst)) says that the maximum theoretical mesh access layer payload throughput is around 60 kbps.
Can you explain how did you get 60 kbps and which PHY was used in this calculation?
2. Is it possible to use Coded PHY (S=8) in Nordic Advertiser Extensions (Instaburst) feature for mesh? And what will be the throughput?
3. Is there any Soft Device versions that support the periodic advertising feature which is part of extended advertising? If yes, is there any example code for that?
Is it possible to integrate the periodic advertisement feature with mesh to get higher throughput?
