I'm working on modifying the flash fds example to write to memory then to retrieve it. I've successfully used the writeTime function to write the word "test" to a memory location and verified that the location contains the correct info. Using the getTime function when running the program for the first time (ie: nrf 52dk memory is fully erased) doesn't give any errors but when I try to type any command in putty the program doesn't respond. If I build the program with the getTime function commented out then the program builds correctly and works as expected, then I can uncomment the getTime function and use it in subsequent builds and it works as expected. So it seems something about the getTime function is causing an error on initialization but I'm not sure why/how since I'm not getting any errors.
Something else I noticed while debugging is that line 415: cli_start(); says stopped by vector catch and the debugging gets stuck here. This is all still just the generic flash fds example so I'm not sure what could be going on here to cause the problem.
The flash fds example is unchanged except for my additions of the writeTime() and getTime() functions at lines 239 and 267 respectively. Then when the functions are called at lines 415 and 416. Here is my code:
#include <stdint.h>
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "nordic_common.h"
#ifdef SOFTDEVICE_PRESENT
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#else
#include "nrf_drv_clock.h"
#include "fds.h"
#include "app_timer.h"
#include "app_error.h"
#include "nrf_cli.h"
#include "fds_example.h"
#define NRF_LOG_MODULE_NAME app
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_CONN_CFG_TAG 1
/* Array to map FDS events to strings. */
static char const * fds_evt_str[] =
"FDS_EVT_INIT",
"FDS_EVT_WRITE",
"FDS_EVT_UPDATE",
"FDS_EVT_DEL_RECORD",
"FDS_EVT_DEL_FILE",
"FDS_EVT_GC",
/* Dummy configuration data. */
static configuration_t m_dummy_cfg =
.config1_on = false,
.config2_on = true,
.boot_count = 0x0,
.device_name = "dummy",
/* A record containing dummy configuration data. */
static fds_record_t const m_dummy_record =
.file_id = CONFIG_FILE,
.key = CONFIG_REC_KEY,
.data.p_data = &m_dummy_cfg,
/* The length of a record is always expressed in 4-byte units (words). */
.data.length_words = (sizeof(m_dummy_cfg) + 3) / sizeof(uint32_t),
/* Keep track of the progress of a delete_all operation. */
static struct
bool delete_next; //!< Delete next record.
bool pending; //!< Waiting for an fds FDS_EVT_DEL_RECORD event, to delete the next record.
} m_delete_all;
/* Flag to check fds initialization. */
static bool volatile m_fds_initialized;
const char *fds_err_str(ret_code_t ret)
/* Array to map FDS return values to strings. */
static char const * err_str[] =
"FDS_ERR_OPERATION_TIMEOUT",
"FDS_ERR_NOT_INITIALIZED",
"FDS_ERR_UNALIGNED_ADDR",
"FDS_ERR_INVALID_ARG",
"FDS_ERR_NULL_ARG",
"FDS_ERR_NO_OPEN_RECORDS",
"FDS_ERR_NO_SPACE_IN_FLASH",
"FDS_ERR_NO_SPACE_IN_QUEUES",
"FDS_ERR_RECORD_TOO_LARGE",
"FDS_ERR_NOT_FOUND",
"FDS_ERR_NO_PAGES",
"FDS_ERR_USER_LIMIT_REACHED",
"FDS_ERR_CRC_CHECK_FAILED",
"FDS_ERR_BUSY",
"FDS_ERR_INTERNAL",
return err_str[ret - NRF_ERROR_FDS_ERR_BASE];
static void fds_evt_handler(fds_evt_t const * p_evt)
if (p_evt->result == NRF_SUCCESS)
NRF_LOG_GREEN("Event: %s received (NRF_SUCCESS)",
fds_evt_str[p_evt->id]);
NRF_LOG_GREEN("Event: %s received (%s)",
fds_evt_str[p_evt->id],
fds_err_str(p_evt->result));
switch (p_evt->id)
case FDS_EVT_INIT:
m_fds_initialized = true;
case FDS_EVT_WRITE:
NRF_LOG_INFO("Record ID:\t0x%04x", p_evt->write.record_id); //this is the command used to write to the record id
NRF_LOG_INFO("File ID:\t0x%04x", p_evt->write.file_id);
NRF_LOG_INFO("Record key:\t0x%04x", p_evt->write.record_key);
} break;
case FDS_EVT_DEL_RECORD:
NRF_LOG_INFO("Record ID:\t0x%04x", p_evt->del.record_id);
NRF_LOG_INFO("File ID:\t0x%04x", p_evt->del.file_id);
NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
m_delete_all.pending = false;
} break;
/**@brief Begin deleting all records, one by one. */
void delete_all_begin(void)
m_delete_all.delete_next = true;
/**@brief Process a delete all command.
* Delete records, one by one, until no records are left.
void delete_all_process(void)
if ( m_delete_all.delete_next
& !m_delete_all.pending)
NRF_LOG_INFO("Deleting next record.");
m_delete_all.delete_next = record_delete_next();
if (!m_delete_all.delete_next)
NRF_LOG_CYAN("No records left to delete.");
/**@brief Function for initializing the SoftDevice and enabling the BLE stack. */
ret_code_t rc;
uint32_t ram_start;
/* Enable the SoftDevice. */
rc = nrf_sdh_enable_request();
APP_ERROR_CHECK(rc);
rc = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
rc = nrf_sdh_ble_enable(&ram_start);
#else
static void clock_init(void)
/* Initialize the clock. */
ret_code_t rc = nrf_drv_clock_init();
/* Wait for the clock to be ready. */
while (!nrf_clock_lf_is_running()) {;}
/**@brief Initialize the timer. */
static void timer_init(void)
/**@brief Initialize logging. */
static void log_init(void)
ret_code_t rc = NRF_LOG_INIT(NULL);
/**@brief Sleep until an event is received. */
static void power_manage(void)
(void) sd_app_evt_wait();
#else
__WFE();
/**@brief Wait for fds to initialize. */
static void wait_for_fds_ready(void)
while (!m_fds_initialized)
power_manage();
void writeTime(void)
#define FILE_ID 0x0005 /* The ID of the file to write the records into. */
#define RECORD_KEY_1 0x5555 /* A key for the first record. */
ret_code_t rc = NULL;
static char const m_timeStart[] = "test";
fds_record_t record;
fds_record_desc_t record_desc;
// Set up record.
record.file_id = FILE_ID;
record.key = RECORD_KEY_1;
record.data.p_data = &m_timeStart;
/* The following calculation takes into account any eventual remainder of the division. */
record.data.length_words = (sizeof(m_timeStart) + 3) / 4;
rc = fds_record_write(&record_desc, &record);
void getTime(void)
fds_flash_record_t flash_record = {0};
fds_record_desc_t desc1 = {0};
fds_find_token_t tok1 = {0};
ret_code_t rc;
/* It is required to zero the token before first use. */
memset(&tok1, 0x00, sizeof(fds_find_token_t));
rc = fds_record_find(FILE_ID, RECORD_KEY_1, &desc1, &tok1); //after success record_desc and ftok now hold the record_key_1 info but must be opened
if (rc == NRF_SUCCESS)
/* Open the record and read its contents. */
rc = fds_record_open(&desc1, &flash_record);
char hold[20] = {0};
//this code converts a phyiscal memory address to the data that it holds.
//for loop to create a char array of the word written into flash memory
for(int i = 0; i < 4; i++)
hold[i] = *(volatile uint8_t *)flash_record.p_data;
flash_record.p_data++;
//NRF_LOG_INFO("memory location is %x", flash_record.p_data);
NRF_LOG_INFO("hold var holds: %c%c%c%c", hold[0],hold[1],hold[2],hold[3]);
/* Close the record when done reading. */
rc = fds_record_close(&desc1);
ret_code_t rc;
ble_stack_init();
#else
clock_init();
timer_init();
log_init();
cli_init();
NRF_LOG_INFO("FDS example started.")
/* Register first to receive an event when initialization is complete. */
(void) fds_register(fds_evt_handler);
NRF_LOG_INFO("Initializing fds...");
rc = fds_init();
/* Wait for fds to initialize. */
wait_for_fds_ready();
NRF_LOG_INFO("Available commands:");
NRF_LOG_INFO("- print all\t\tprint records");
NRF_LOG_INFO("- print config\tprint configuration");
NRF_LOG_INFO("- update\t\tupdate configuration");
NRF_LOG_INFO("- stat\t\tshow statistics");
NRF_LOG_INFO("- write\t\twrite a new record");
NRF_LOG_INFO("- delete\t\tdelete a record");
NRF_LOG_INFO("- delete_all\tdelete all records");
NRF_LOG_INFO("- gc\t\trun garbage collection");
NRF_LOG_INFO("Reading flash usage statistics...");
fds_stat_t stat = {0};
rc = fds_stat(&stat);
NRF_LOG_INFO("Found %d valid records.", stat.valid_records);
NRF_LOG_INFO("Found %d dirty records (ready to be garbage collected).", stat.dirty_records);
fds_record_desc_t desc = {0};
fds_find_token_t tok = {0};
rc = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &desc, &tok);
/* A config file is in flash. Let's update it. */
fds_flash_record_t config = {0};
rc = fds_record_open(&desc, &config);
/* Copy the configuration from flash into m_dummy_cfg. */
memcpy(&m_dummy_cfg, config.p_data, sizeof(configuration_t));
NRF_LOG_INFO("Config file found, updating boot count to %d.", m_dummy_cfg.boot_count);
/* Update boot count. */
m_dummy_cfg.boot_count++;
rc = fds_record_close(&desc);
/* Write the updated record to flash. */
rc = fds_record_update(&desc, &m_dummy_record);
if ((rc != NRF_SUCCESS) && (rc == FDS_ERR_NO_SPACE_IN_FLASH))
NRF_LOG_INFO("No space in flash, delete some records to update the config file.");
/* System config not found; write a new one. */
NRF_LOG_INFO("Writing config file...");
rc = fds_record_write(&desc, &m_dummy_record);
cli_start(); //all functionality must come from here?
writeTime();
getTime(); //comment out gettime for first build then it works after build is complete. possibly due to vector catch = hardfault error?
/* Enter main loop. */
for (;;)
if (!NRF_LOG_PROCESS())
power_manage();
cli_process();
delete_all_process();
