Flash FDS Error/Stopped by Vector Catch When Accessing Stored Data.
I'm working on modifying the flash fds example to write to memory then to retrieve it.  I've successfully used the writeTime function to write the word "test" to a memory location and verified that the location contains the correct info.  Using the getTime function when running the program for the first time (ie: nrf 52dk memory is fully erased)  doesn't give any errors but when I try to type any command in putty the program doesn't respond.  If I build the program with the getTime function commented out then the program builds correctly and works as expected, then I can uncomment the getTime function and use it in subsequent builds and it works as expected.  So it seems something about the getTime function is causing an error on initialization but I'm not sure why/how since I'm not getting any errors.
Something else I noticed while debugging is that line 415: cli_start(); says stopped by vector catch and the debugging gets stuck here.  This is all still just the generic flash fds example so I'm not sure what could be going on here to cause the problem.
The flash fds example is unchanged except for my additions of the writeTime() and getTime() functions at lines 239 and 267 respectively.  Then when the functions are called at lines 415 and 416.  Here is my code:
#include <stdint.h>
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "nordic_common.h"
#ifdef SOFTDEVICE_PRESENT
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#else
#include "nrf_drv_clock.h"
#include "fds.h"
#include "app_timer.h"
#include "app_error.h"
#include "nrf_cli.h"
#include "fds_example.h"
#define NRF_LOG_MODULE_NAME app
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_CONN_CFG_TAG    1
/* Array to map FDS events to strings. */
static char const * fds_evt_str[] =
    "FDS_EVT_INIT",
    "FDS_EVT_WRITE",
    "FDS_EVT_UPDATE",
    "FDS_EVT_DEL_RECORD",
    "FDS_EVT_DEL_FILE",
    "FDS_EVT_GC",
/* Dummy configuration data. */
static configuration_t m_dummy_cfg =
    .config1_on  = false,
    .config2_on  = true,
    .boot_count  = 0x0,
    .device_name = "dummy",
/* A record containing dummy configuration data. */
static fds_record_t const m_dummy_record =
    .file_id           = CONFIG_FILE,
    .key               = CONFIG_REC_KEY,
    .data.p_data       = &m_dummy_cfg,
    /* The length of a record is always expressed in 4-byte units (words). */
    .data.length_words = (sizeof(m_dummy_cfg) + 3) / sizeof(uint32_t),
/* Keep track of the progress of a delete_all operation. */
static struct
    bool delete_next;   //!< Delete next record.
    bool pending;       //!< Waiting for an fds FDS_EVT_DEL_RECORD event, to delete the next record.
} m_delete_all;
/* Flag to check fds initialization. */
static bool volatile m_fds_initialized;
const char *fds_err_str(ret_code_t ret)
    /* Array to map FDS return values to strings. */
    static char const * err_str[] =
        "FDS_ERR_OPERATION_TIMEOUT",
        "FDS_ERR_NOT_INITIALIZED",
        "FDS_ERR_UNALIGNED_ADDR",
        "FDS_ERR_INVALID_ARG",
        "FDS_ERR_NULL_ARG",
        "FDS_ERR_NO_OPEN_RECORDS",
        "FDS_ERR_NO_SPACE_IN_FLASH",
        "FDS_ERR_NO_SPACE_IN_QUEUES",
        "FDS_ERR_RECORD_TOO_LARGE",
        "FDS_ERR_NOT_FOUND",
        "FDS_ERR_NO_PAGES",
        "FDS_ERR_USER_LIMIT_REACHED",
        "FDS_ERR_CRC_CHECK_FAILED",
        "FDS_ERR_BUSY",
        "FDS_ERR_INTERNAL",
    return err_str[ret - NRF_ERROR_FDS_ERR_BASE];
static void fds_evt_handler(fds_evt_t const * p_evt)
    if (p_evt->result == NRF_SUCCESS)
        NRF_LOG_GREEN("Event: %s received (NRF_SUCCESS)",
                      fds_evt_str[p_evt->id]);
        NRF_LOG_GREEN("Event: %s received (%s)",
                      fds_evt_str[p_evt->id],
                      fds_err_str(p_evt->result));
    switch (p_evt->id)
        case FDS_EVT_INIT:
                m_fds_initialized = true;
        case FDS_EVT_WRITE:
                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->write.record_id); //this is the command used to write to the record id
                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->write.file_id);
                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->write.record_key);
        } break;
        case FDS_EVT_DEL_RECORD:
                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->del.record_id);
                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->del.file_id);
                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
            m_delete_all.pending = false;
        } break;
/**@brief   Begin deleting all records, one by one. */
void delete_all_begin(void)
    m_delete_all.delete_next = true;
/**@brief   Process a delete all command.
 * Delete records, one by one, until no records are left.
void delete_all_process(void)
    if (   m_delete_all.delete_next
        & !m_delete_all.pending)
        NRF_LOG_INFO("Deleting next record.");
        m_delete_all.delete_next = record_delete_next();
        if (!m_delete_all.delete_next)
            NRF_LOG_CYAN("No records left to delete.");
/**@brief   Function for initializing the SoftDevice and enabling the BLE stack. */
    ret_code_t rc;
    uint32_t   ram_start;
    /* Enable the SoftDevice. */
    rc = nrf_sdh_enable_request();
    APP_ERROR_CHECK(rc);
    rc = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
    rc = nrf_sdh_ble_enable(&ram_start);
#else
static void clock_init(void)
    /* Initialize the clock. */
    ret_code_t rc = nrf_drv_clock_init();
    /* Wait for the clock to be ready. */
    while (!nrf_clock_lf_is_running()) {;}
/**@brief   Initialize the timer. */
static void timer_init(void)
/**@brief   Initialize logging. */
static void log_init(void)
    ret_code_t rc = NRF_LOG_INIT(NULL);
/**@brief   Sleep until an event is received. */
static void power_manage(void)
    (void) sd_app_evt_wait();
#else
    __WFE();
/**@brief   Wait for fds to initialize. */
static void wait_for_fds_ready(void)
    while (!m_fds_initialized)
        power_manage();
void writeTime(void)
   #define FILE_ID         0x0005  /* The ID of the file to write the records into. */
   #define RECORD_KEY_1    0x5555  /* A key for the first record. */
   ret_code_t rc = NULL;
   static char const m_timeStart[]  = "test";
   fds_record_t        record;
   fds_record_desc_t   record_desc;
   // Set up record.
   record.file_id           = FILE_ID;
   record.key               = RECORD_KEY_1;
   record.data.p_data       = &m_timeStart;
   /* The following calculation takes into account any eventual remainder of the division. */
   record.data.length_words = (sizeof(m_timeStart) + 3) / 4;
   rc = fds_record_write(&record_desc, &record);
void getTime(void)
fds_flash_record_t  flash_record = {0};
fds_record_desc_t   desc1 = {0};
fds_find_token_t    tok1 = {0};
ret_code_t rc;
/* It is required to zero the token before first use. */
memset(&tok1, 0x00, sizeof(fds_find_token_t));
rc = fds_record_find(FILE_ID, RECORD_KEY_1, &desc1, &tok1); //after success record_desc and ftok now hold the record_key_1 info but must be opened
if (rc == NRF_SUCCESS)
        /* Open the record and read its contents. */
        rc = fds_record_open(&desc1, &flash_record);
        char hold[20] = {0};
        //this code converts a phyiscal memory address to the data that it holds.
        //for loop to create a char array of the word written into flash memory
        for(int i = 0; i < 4; i++)
          hold[i] = *(volatile uint8_t *)flash_record.p_data;
          flash_record.p_data++;
        //NRF_LOG_INFO("memory location is %x", flash_record.p_data);
       NRF_LOG_INFO("hold var holds: %c%c%c%c", hold[0],hold[1],hold[2],hold[3]);
        /* Close the record when done reading. */
        rc = fds_record_close(&desc1);
    ret_code_t rc;
    ble_stack_init();
#else
    clock_init();
    timer_init();
    log_init();
    cli_init();
    NRF_LOG_INFO("FDS example started.")
    /* Register first to receive an event when initialization is complete. */
    (void) fds_register(fds_evt_handler);
    NRF_LOG_INFO("Initializing fds...");
    rc = fds_init();
    /* Wait for fds to initialize. */
    wait_for_fds_ready();
    NRF_LOG_INFO("Available commands:");
    NRF_LOG_INFO("- print all\t\tprint records");
    NRF_LOG_INFO("- print config\tprint configuration");
    NRF_LOG_INFO("- update\t\tupdate configuration");
    NRF_LOG_INFO("- stat\t\tshow statistics");
    NRF_LOG_INFO("- write\t\twrite a new record");
    NRF_LOG_INFO("- delete\t\tdelete a record");
    NRF_LOG_INFO("- delete_all\tdelete all records");
    NRF_LOG_INFO("- gc\t\trun garbage collection");
    NRF_LOG_INFO("Reading flash usage statistics...");
    fds_stat_t stat = {0};
    rc = fds_stat(&stat);
    NRF_LOG_INFO("Found %d valid records.", stat.valid_records);
    NRF_LOG_INFO("Found %d dirty records (ready to be garbage collected).", stat.dirty_records);
    fds_record_desc_t desc = {0};
    fds_find_token_t  tok  = {0};
    rc = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &desc, &tok);
        /* A config file is in flash. Let's update it. */
        fds_flash_record_t config = {0};
        rc = fds_record_open(&desc, &config);
        /* Copy the configuration from flash into m_dummy_cfg. */
        memcpy(&m_dummy_cfg, config.p_data, sizeof(configuration_t));
        NRF_LOG_INFO("Config file found, updating boot count to %d.", m_dummy_cfg.boot_count);
        /* Update boot count. */
        m_dummy_cfg.boot_count++;
        rc = fds_record_close(&desc);
        /* Write the updated record to flash. */
        rc = fds_record_update(&desc, &m_dummy_record);
        if ((rc != NRF_SUCCESS) && (rc == FDS_ERR_NO_SPACE_IN_FLASH))
            NRF_LOG_INFO("No space in flash, delete some records to update the config file.");
        /* System config not found; write a new one. */
        NRF_LOG_INFO("Writing config file...");
        rc = fds_record_write(&desc, &m_dummy_record);
    cli_start(); //all functionality must come from here?
    writeTime();
    getTime(); //comment out gettime for first build then it works after build is complete.  possibly due to vector catch = hardfault error?
    /* Enter main loop. */
    for (;;)
        if (!NRF_LOG_PROCESS())
            power_manage();
        cli_process();
        delete_all_process();
    I did not manage to replicate the vector catch on my end, nor spot any obvious coding issues, unfortunately. I copied your code into the flash fds sample in SDK 17.0.2 and ran it on a 52 DK. Below is the log output I got after a few startups.
    Any chance that some of the SDK source files may have gotten modified on you setup? It may be a good idea to try again with a fresh SDK copy in that case.
  • Thanks for looking into it!  So you were able to erase the device memory completely and the program ran for the first time with the getTime function enabled?  I double checked my SDK and I'm also running SDK 17.0.2 and installed it through nRF connect toolchain manager with nRF connect SDK v1.5.0.
    I reinstalled the SDK and ran the program but I'm still getting the same problem where if I try to build to an erased device while getTime is enabled the cli doesn't work.  I also checked the memory and nothing was written so even though getTime is called after writeTime writeTime breaks as well which I don't understand.
    When I add a breakpoint to debug I get the vector catch error, and I tried with a fresh unedited flash_fds example adding a breakpoint above the cli_start() function to check how the memory was initializing but I get a vector catch here as well.
  • Yes, I didn't encounter the vector catch on first boot. I had left the getTime() function enabled and I also made sure the chip was erased before I loaded the application.
    Attached below is the .hex file I built here. Please try programming it on your board and see if you still get the same result.
    flash_fds_blank_pca10040.hex
  • I ran your hex file and it works correctly when I flash it to the device.  So this probably means there is something in my SDK that is incorrect then?  How should I go about troubleshooting this issue?
  • You mentioned the toolchain manager to install the SDK, but that's only meant for the new nRF connect SDK. The nRF5 SDK (17.0.2) is distributed as a .zip file and does not require any installation.
    If you haven't already, plase try to download and extract the nRF5 SDK 17.0.2 zip and then build the project from this folder. This will ensure that we build with the same set of source files.
