I wanted to add TWI functionality to the flash fds example and was confused about adding drivers with CMSISwizard. I manually added all the necessary twi drivers based off of the twi scanner example and added the necessary #includes.
From my understanding I still needed to enable these drivers through the sdk_config file, but in the CMSIS wizard the drivers I had added weren't showing up. I manually opened the sdk_config.h file and added lines of code such as:
but I was wondering if there was a way to do this through CMSIS wizard.
When adding drivers is there a way to make the CMSIS wizard recognize that drivers have been newly added so that they can be enabled through the wizard? Or do the added drivers need to be manually enabled within the sdk_config file by adding lines of code to enable the drivers?
Also, is there a proper format to follow when adding lines of code to enable drivers within the sdk_config file? Now when I open the CMSIS wizard no drivers come up even though my project builds and runs properly, so I'm assuming when I added lines to the sdk_config file that I messed up the format somehow.
Thanks!
