nrf/samples/nrf9160/mqtt_simple: BUS FAULT
This is the output of application compiled with "west build -p -b circuitdojo_feather_nrf9160ns nrf/samples/nrf9160/mqtt_simple":
+CEREG: 2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"
+CEREG: 2,"D1F5","0219BA11",7,0,0,"11100000","11100000"
+CSCON: 1
+CEREG: 5,"D1F5","0219BA11",7,,,"11100000","11100000"
[00:01:02.697,357] <inf> mqtt_simple: LTE Link Connected!
[00:01:02.866,882] <inf> mqtt_simple: IPv4 Address found 137.135.83.217
[00:01:02.867,614] <dbg> mqtt_simple.client_id_get: client_id = nrf-352656107237110
[00:01:03.401,885] <inf> mqtt_simple: MQTT client connected
[00:01:03.401,885] <inf> mqtt_simple: Subscribing to: my/subscribe/topic len 18
[00:01:03.809,875] <inf> mqtt_simple: SUBACK packet id: 1234
[00:01:04.018,859] <inf> mqtt_simple: MQTT PUBLISH result=0 len=5
[00:01:04.018,951] <inf> mqtt_simple: Received: 45664
[00:01:04.064,544] <inf> mqtt_simple: Publishing: 45664
[00:01:04.064,544] <inf> mqtt_simple: to topic: my/publish/topic len: 16
[00:01:04.064,666] <err> os: Exception occurred in Secure State
[00:01:04.064,666] <err> os: ***** HARD FAULT *****
[00:01:04.064,666] <err> os:   Fault escalation (see below)
[00:01:04.064,666] <err> os: ***** BUS FAULT *****
[00:01:04.064,697] <err> os:   Precise data bus error
[00:01:04.064,697] <err> os:   BFAR Address: 0x50008158
[00:01:04.064,697] <err> os: r0/a1:  0x00000000  r1/a2:  0xe000ed00  r2/a3:  0x200156a8
[00:01:04.064,727] <err> os: r3/a4:  0x200148e0 r12/ip:  0x00021ead r14/lr:  0x0001d48d
[00:01:04.064,727] <err> os:  xpsr:  0x60000000
[00:01:04.064,727] <err> os: Faulting instruction address (r15/pc): 0x00000000
[00:01:04.064,727] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
[00:01:04.064,727] <err> os: Current thread: 0x200148e0 (unknown)
Bisect shows this as the first commit that results in failure (as everything is fine with 1.5.1):
26c6230e3bd5c29d77d183eb295aa7426b24a2d7 is the first bad commit
commit 26c6230e3bd5c29d77d183eb295aa7426b24a2d7
Author: Trond Einar Snekvik <[email protected]>
Date: Wed Apr 21 14:32:52 2021 +0200
manifest: Upmerge 21.04.2021
Regular upmerge.
Signed-off-by: Trond Einar Snekvik <[email protected]>
After bisecting nrfxlib project, the following commit seems to make a difference:
nrf_modem: Do not imply CONFIG_FPU
Removes the imply FPU kconfig entry in NRF_MODEM.
Previously, this would fail linking when TFM was enabled, as that forces
FP_SOFTABI, which there is no binary for. The intent of the original
encourage FPU usage when available, but with TFM, this is no longer
valid.
After enabling CONFIG_FPU in master branch of nrf repository, it seem that issue is no longer reproducible. Same happens with downstream code with CoAP library, so it is not mqtt_simple specific. It seems that the problem is with libmodem.a library. Reproducible with 778fa293d74b7a4fb669516837fb2a392d57e26e.
