Stack Tracing with softdevice
I want to implement stack tracing to check stack overflow and remaining stack. I followed the implementation given in example github.com/.../memory_watcher.
Memory watcher code is not working when I am using softdevice S120 along with my application. But when I am using the same application without softdevice memory watcher code is working fine. Even GET_SP() is not working with softdevice. My application uses SDK 8.0.0., Softdevice S120 2.0.0 and ARMCC compilerV5.05.
Thanks
  • I will have to try this out in my leisure time, hope someone who has already tried this gives us an answer.
  • Hi Aryan,
    I found that Keil startup files do not expose the stack nor the heap location in memory. Till now the solution i implemented is:
    register uint32_t __regProcessStackPointer  __ASM("msp");
    	 stackStart = (uint32_t )__regProcessStackPointer;
    	 stackEnd = stackStart - 0x800; //stack size 2048
    uint32_t getRemainingStack(void)
    	uint32_t currentSP;
    	uint32_t stack;
    	 currentSP = (uint32_t )__regProcessStackPointer;
    	 stack = currentSP - stackEnd;
    	return (stack);
      while(1)
    return 0;
    To get the stack usage periodically, getRemainingStack handler is called by app timer every 10ms. It is polling method. but idea was have get an exception whenever stack overflow happens.
    Thanks
  • Sorry for typo mistake. I will rewrite the code again:
      while(1)
    return 0;
        uint32_t currentSP;
        uint32_t stack;
        return (stack);
  • I figured that the while statement was there for debugging :)
