BLE app uart code write to the BMD 350 device. BLE is disconnected.
If any reasons?
How to configure the TX and RX pins ? when i change the pins, fatal error will come.
Hardware pins
Rx - 20
Tx - 19
RTS - 21
CTS - 22
Parthiv
If any reasons?
Hardware pins
Rx - 20
Tx - 19
RTS - 21
CTS - 22
Parthiv
please give some more details on that
Also give a link to the module. Doesn't the manufacturer provide any examples or anything to get you started?
Hello Parthiv,
Please describe the behavior you are seeing. The more details you provide us, the easier it will be for us to help you, and the faster your issue may be resolved.
Does the application start at all, and is it discoverable for other devices? Do you mean to say that you are able to connect, but after some time or condition, the connection is broken? What device are you using for your central, is it the nRF Connect for Desktop/smartphone application? If so, what does its logs say when the disconnect happens?
Please make sure that you have DEBUG defined in your preprocessor defines, like shown in the included image.
This will make your logger output a detailed error message whenever a non-NRF_SUCCSS error code is passed to an APP_ERROR_CHECK.
The pins are configured as part of the UART initialization. You can change their configuration there, but please make sure to check with your module's datasheet that the pins you intend to use are available, and that they are not designated low-frequency pins in the nRF52832 SoC Pin Assignment documentation.
Karl
