Hi all,
I have the following issue: For an electrochemical measurement I need to use 4 GPIO pins bundled in pairs, each pair with an output (GPIO HI) and ground (GPIO LO). Sadly I cannot just configure the 4 as LO and then activate the one I need, since in the solution everything would be virtually short circuited, rendering one output with three grounds.
What I thought of is having the four pins "disconnected" or "hi-Z" and just activating the pair on demand. After some reading I found out the GPIOs in the nRF5340 do not support high impedance. Someone suggested to reconfigure them as inputs to achieve high impedance, which could possibly work, but I have not found out how to reconfigure them during runtime. Next a snippet of my strategy:
void funcion(){
int ret;
ret = gpio_pin_configure(dev0, PIN0, GPIO_OUTPUT_INACTIVE | FLAGS0);
while(ret);
ret = gpio_pin_configure(dev1, PIN1, GPIO_OUTPUT_INACTIVE | FLAGS1);
while(ret);
gpio_pin_toggle(dev0, PIN0);
k_usleep((PULSE_DURATION));
ret = gpio_pin_configure(dev0, PIN0, GPIO_DISCONNECTED);
while(ret);
ret = gpio_pin_configure(dev1, PIN1, GPIO_DISCONNECTED);
while(ret);
//ret = gpio_pin_configure(dev0, PIN0, GPIO_INPUT | FLAGS0);
//while(ret);
//ret = gpio_pin_configure(dev1, PIN1, GPIO_INPUT | FLAGS1);
//while(ret);
This seems to crash the app whenever I do the second re-configuring, both with disconnecting and input.
How could I do the switching properly? Or is there a better solution to my problem?
Fran89
Off-topic and not necessary to refer to in the answer: I am having a frustratingly hard time migrating from the nRF52 to the nRF53. The documentation and examples are rather scarce, and most refers to the Zephyr project docs which are also cryptic, like any other Linux doc. I just leave this comment here to encourage you to expand (and update) examples and guides to make the landing into the nRF53 a bit more intuitive, and for others in my situation to know you're not the only ones.
