TWI-NRF_ERR_BUSY, when I call nrf_drv_twi_tx. Yesterday I could saw the debug error info from uart, but now the logs don't print even a character .
yesterday, I met the same situation as here. But now, I can't even see one log, even after I annotated the code related twi and just remained some  “NRF_LOG_INFO()” in main function.
I was confused about that. I've tried  all the ways that I could, I think.  I use the "twi_sensor " example, in SDK 15.0  and no soft devcie.
please help
Code as below.
	//uint8_t id;
    NRF_LOG_INFO("\r\nTWI sensor example started.");
	  nrf_gpio_cfg_output(22);
	  nrf_gpio_pin_set(22);
//    twi_init();
//    ICM_init();
////    NRF_LOG_INFO("icm_init and id is%x\n",id);
////	  NRF_LOG_INFO("icm_init");
//	  data_conversion();
    while (true)
        nrf_delay_ms(50);
code related twi:
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                //data_handler(m_sample);
							 NRF_LOG_INFO("received complete");
            m_xfer_done = true;
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_icm_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_400K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_icm_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
code related sensor:(the sensor is  likely mpu's upgraded version )
#include "icm20600.h"
static uint8_t tx_buffer[6];
static uint8_t rx_buffer[6];
uint8_t       *m_tx_buf=tx_buffer;
uint8_t       *m_rx_buf=rx_buffer;
uint8_t H_rx_buf[1];
uint8_t L_rx_buf[1];
float icm_acc_x=1.0;
int16_t icm_acc_x_hex=1;
int16_t x_data=1;
void ICM_write(uint8_t *tx_data,uint8_t  tx_length)
	  m_xfer_done = false;
	  err_code = nrf_drv_twi_tx(&m_twi, i2c_address, tx_data,tx_length, 0);
	while (m_xfer_done == false);
    //while (m_xfer_done == false);
void ICM_read(uint8_t *rx_data,uint8_t  rx_length)
//	  err_code = nrf_drv_twi_tx(&m_twi, i2c_address,&addr,1, 1);
//    APP_ERROR_CHECK(err_code);
//	  while (m_xfer_done == false);
	  err_code = nrf_drv_twi_rx(&m_twi, i2c_address, rx_data,rx_length);
*   sample_rate  set
void ICM_Set_Rate(uint16_t rate)
	uint8_t div,DLPF_CFG;
	uint16_t filter=rate/2;
	if(rate>1000)
	{rate=1000;}
	 if (filter >= 176) {
        DLPF_CFG = 1;
    } else if (filter >= 92) {
        DLPF_CFG = 2;
    } else if (filter >= 41) {
        DLPF_CFG = 3;
    } else if (filter >= 20) {
        DLPF_CFG = 4;
    } else if (filter >= 10) {
        DLPF_CFG = 5;
    } else {
        DLPF_CFG = 6;
  m_tx_buf[0]=ICM20602_GYRO_CONFIG_REG;
	m_tx_buf[1]=DLPF_CFG;
  ICM_write(m_tx_buf,2);
  div=(1000/rate)-1;
	m_tx_buf[0]=ICM20602_SMPLRT_DIV;
	m_tx_buf[1]=div;
/*accelerometer_threshold*/
uint8_t set_accelerometer_threshold(uint8_t threshold)
	  uint8_t accl_val;
    if(threshold > 100){
        return 1;
    uint16_t val_1= threshold * 0xFF;
    accl_val = (uint8_t)(val_1 / 100);
	m_tx_buf[0]=ICM20602_LACCEL_WOM_X_THR;
	m_tx_buf[1]=accl_val;
	m_tx_buf[2]=ICM20602_LACCEL_WOM_Y_THR;
	m_tx_buf[3]=accl_val;
	m_tx_buf[4]=ICM20602_LACCEL_WOM_Z_THR;
	m_tx_buf[5]=accl_val;
  ICM_write(m_tx_buf,6);
    return 0;
/*****************************sensor_init****************************
void ICM_init()
	uint8_t ICM_ID,id;
	/*reset sensor*/
	m_tx_buf[0]=ICM20602_PWR_MGMT1_REG;
	m_tx_buf[1]=0x80;
	nrf_delay_ms(100);
	/*reset all registers*/
	m_tx_buf[0]=ICM20602_USER_CTRL;
	m_tx_buf[1]=0x01;
	nrf_delay_ms(100);
	m_tx_buf[1]=0x00;
	/*device id judgment */
	m_tx_buf[0]=ICM20602_WHO_AM_I;
	ICM_write(m_tx_buf,1);
	ICM_read(m_rx_buf,1);
	ICM_ID=*m_rx_buf;
	if(ICM_ID){NRF_LOG_INFO("ICM_ID is:%x\n",ICM_ID);}
	else {NRF_LOG_INFO("ICM_ID false");}
	//return ICM_ID;
	if(ICM_ID==0x12)
	m_tx_buf[1]=0x18;
	m_tx_buf[2]=ICM20602_ACCEL_CONFIG1_REG;
	m_tx_buf[3]=0;
	ICM_write(m_tx_buf,4);
	ICM_Set_Rate(50);
	m_tx_buf[0]=ICM20602_INT_ENABLE_REG;
	m_tx_buf[1]=0x00;
	m_tx_buf[2]=ICM20602_FIFO_EN;
	m_tx_buf[3]=0x00;
	m_tx_buf[4]=ICM20602_INT_PIN_CFG;
	m_tx_buf[5]=0x80;
	/*set clock source*/
	m_tx_buf[1]=0x01;                     //Auto selects the best available clock source � PLL if ready, else use the Internal oscillator
	while(set_accelerometer_threshold(0x50)==1);
	/*start accelerometer*/
	m_tx_buf[0]=ICM20602_PWR_MGMT2_REG ;
	m_tx_buf[1]=0x00;
	NRF_LOG_INFO("ICM initalize success");
		NRF_LOG_INFO("ICM initalize failed");
/**************************Accelerometer read *****************************/
int16_t ICM_Get_X_Accelerometer()
	uint8_t XOUT_H,XOUT_L;
  m_tx_buf[0]=ICM20602_ACCEL_XOUT_H ;
	ICM_read(H_rx_buf,1);
	m_tx_buf[0]=ICM20602_ACCEL_XOUT_L ;
	ICM_read(L_rx_buf,1);
	x_data=(int16_t)((uint16_t)((H_rx_buf[0])<<8)|(L_rx_buf[0]));
	return x_data;
void data_conversion()
	icm_acc_x_hex=ICM_Get_X_Accelerometer();
	icm_acc_x=(float)icm_acc_x_hex/16384;
	NRF_LOG_INFO("icm_acc_x:%x\n",icm_acc_x_hex);
icm20602.h
