nRF9160 select() always returns 115
I have an nRF9160 with nrfx v2.5.0 and nrfxlib v1.5.1. We have integrated nrf_modem into our own OS. I would like to use TCP sockets asynchronously, but cannot establish a nonblocking connection.
I can establish a TCP connection to our server while blocking with no issues. I suspect I'm also getting a successful connection to the server in the nonblocking case too, but I cannot find a way to determine if the connection has been established.
I have tried polling on nrf_getsockopt(sock, NRF_SOL_SOCKET, NRF_SO_ERROR... ). This works in the case where the server disconnects (i.e. I get an error code), but there is nothing to indicate a successful connection.
The standard posix way of doing this would be to call select() and wait for writing to come available. No matter what I do, nrf_select() always returns 115 (EINPROGRESS), and does so immediately after calling.
I would expect that even if I were doing something wrong, the following would run until it timed out:
nrf_select(sock + 1, NULL, NULL, NULL, &tv);
but this also returns immediately with 115. I suspect that there is a subtlety in the API that I am missing.
Procedure overview:
  • nrf_fcntl(sock, NRF_F_GETFL, 0);
  • nrf_fcntl(sock, NRF_F_SETFL, res | NRF_O_NONBLOCK);
  • nrf_connect(sock, &zzz, sizeof(zzz));
  • nrf_select(sock + 1, NULL, &fdset, NULL, &tv); - returns 115, no matter  what I do with the arguments. I am using NRF_FD_ZERO, NRF_FD_SET.
  • nrf_getsockopt(sock, NRF_SOL_SOCKET, NRF_SO_ERROR, ...); - tells me when the link goes down but not when the connection is successful.
TLDR: The root issue I am trying to solve is: how do I determine that my NONBLOCKING nrf_connect() has successfully connected with nrf_modem. I would also like to know what is going wrong with nrf_select() that is preventing me from using it, but this is less important.
  • Hello Gareth,
    I unfortunately do not have an answer to your questions right away. I have to check this internally and come back to you as soon as possible!
    Markus
  • Hey Markus, thanks for your response. I have found that using poll() seems to work in my case (i.e. I wait on revent 0x2) and it seems to actually take ~100ms, which is what I would expect. That addresses my root issue.
    I think I am unblocked for now in that respect, though I'm still concerned about the behaviour of select() and would quite like to understand what is going wrong there.
  • Thanks for the feedback, Gareth! It is really appreciated.
    I’ll check the behaviour of the select() function with our modem team and come back to you.
    Markus
  • Hello again Gareth,
    I now got some feedback from the modem team and it looks like that we do not have support or the nrf_select function outside of the Zephyr OS. As you can see in the documentation, the function returns -1 in case of error. Error number -115 is nothing that is supported by our implementation.
    I hope this will answer your question.
    Markus
  • Hi Markus, thank you for following up with my select() enquiry. For clarification, I am receiving -1 in case of error, but I get 115 when I pull errno (i.e. that set by nrf_modem_os_errno_set()) . It is perhaps possible that select() is a function that does not set errno, though this seems unlikely as I had cleared errno prior to calling select().
    Regardless, is there anywhere that it is publicly documented that select() only works under Zephyr? I'm just interested in understanding what I have missed, because I have sunk a lot of time into trying to understand something that was never going to work for me. If it's not documented, may I ask that it be added to the documentation of that function so others don't similarly get let astray?
    Thanks again.
