BT_LE_ADV_OPT_CODED | BT_LE_ADV_OPT_EXT_ADV backwards compatible?
I would like our nrf52840 to use coded phy 8x to get longer range.
The counter part are Android smartphones, old ones with BLE 4 support only, new ones having coded phy and extended advertising support.
The question is, if I activate BT_LE_ADV_OPT_CODED | BT_LE_ADV_OPT_EXT_ADV do older smartphones work still fine - is this setting backward compatible?
Configuring BT_LE_ADV_OPT_CODED, do I need BT_LE_ADV_OPT_EXT_ADV as well to work or can I leave it away?
Is the advertising itself (before connecting) also 4 times the range?
thank you
Marcel
