Transfer project nrf52810 on nrf52832
Hi, faced a problem while transferring a project nrf52810 on nrf52832. I changed project settings and file paths comparing projects. The connection with the phone became very bad on nrf52832. I changed BLE_GATT_ATT_MTU_DEFAULT on size NRF_SDH_BLE_GATT_MAX_MTU_SIZE, 43 on nrf52832. I changed NRF_SDH_BLE_GATT_MAX_MTU_SIZE on 43, but no changed BLE_GATT_ATT_MTU_DEFAULT on nrf52810. Only after that it became stable to connect to the phone. What is the cause of this problem?
  • Hi
    Just to make sure I understand correctly. You have an nRF52810 project that you are trying to transfer over to work on nRF52832 HW? It is usually the other way around, as most example projects have an nRF52832 variant, but not an nRF52810 one. Thus we have a guide to move projects from the nRF52832 to nRF52810. Please try doing the "Transferring the project to nRF52810 hardware" guide "backwards" so that you change the target device to nRF52832, add the preprocessor defines "NRF52" and "NRF52832_XXAA". Remove the "NRF52810_XXAA" preprocessor define. Adjust the linker script to match the maximum RAM and Flash memory of the nRF52832. Remove the nRF52810 startup and system files, and add the startup_nrf52.s and system_nrf52.c files.
    It shouldn't be necessary to edit the MTU size if the application code hasn't been modified at all either. Can you clarify what you mean by the connection being very bad? Do you get a specific disconnect reason or error code from the nRFConnect app or nRF52832?
    Simon
  • #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i> if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
  • hi,
    may i ask one question related to this post? i can see that NRF_SDH_CLOCK_LF_ACCURACY  is 1 and
    since 832 is 250ppm, so NRF_SDH_CLOCK_LF_ACCURACY should be 0?
  • These are the recommended settings for own board written on the forum.
