GPIOTE pin change IRQ handler fired when UART data RX occurs
Hello, in my project i simultaneously use MPR121 touch sensor controller and GPS module connected to UART0 of nRF52840 (custom board). To handle touch events, i use MPR121 IRQ line which is hooked up to GPIOTE pin IRQ:
void touch_IRQ_init(void)
 ret_code_t err_code;
 nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
 in_config.pull = NRF_GPIO_PIN_NOPULL;
 err_code = nrf_drv_gpiote_in_init(TOUCH_IRQ_PIN, &in_config, MPR121_check_pad_status);
 nrf_drv_gpiote_in_event_enable(TOUCH_IRQ_PIN, true);
 SEGGER_RTT_printf(0, "Touch IRQ init complete.\n");
Then, UART0 along with UART IRQ handler is initialized (code is borrowed from Nordic UART example):
void UART_config( uint8_t rts_pin_number,
uint8_t txd_pin_number,
uint8_t cts_pin_number,
uint8_t rxd_pin_number,
uint32_t speed,
bool hwfc)
nrf_gpio_cfg_output(txd_pin_number);
nrf_gpio_cfg_input(rxd_pin_number, NRF_GPIO_PIN_PULLUP);
NRF_UART0->PSELTXD = txd_pin_number;
NRF_UART0->PSELRXD = rxd_pin_number;
if (hwfc)
nrf_gpio_cfg_output(rts_pin_number);
nrf_gpio_cfg_input(cts_pin_number, NRF_GPIO_PIN_NOPULL);
NRF_UART0->PSELCTS = cts_pin_number;
NRF_UART0->PSELRTS = rts_pin_number;
NRF_UART0->CONFIG = (UART_CONFIG_HWFC_Enabled << UART_CONFIG_HWFC_Pos);
NRF_UART0->BAUDRATE = (speed << UART_BAUDRATE_BAUDRATE_Pos);
NRF_UART0->CONFIG = (UART_CONFIG_PARITY_Excluded << UART_CONFIG_PARITY_Pos);
NRF_UART0->ENABLE = (UART_ENABLE_ENABLE_Enabled << UART_ENABLE_ENABLE_Pos);
NRF_UART0->TASKS_STARTTX = 1;
NRF_UART0->TASKS_STARTRX = 1;
NRF_UART0->EVENTS_RXDRDY = 0;
m_current_state = UART_READY;
NRF_UART0->INTENCLR = 0xffffffffUL;
NRF_UART0->INTENSET = (UART_INTENSET_RXDRDY_Set << UART_INTENSET_RXDRDY_Pos) |
(UART_INTENSET_TXDRDY_Set << UART_INTENSET_TXDRDY_Pos) |
(UART_INTENSET_ERROR_Set << UART_INTENSET_ERROR_Pos);
NVIC_ClearPendingIRQ(UART0_IRQn);
NVIC_SetPriority(UART0_IRQn, 1);
NVIC_EnableIRQ(UART0_IRQn);
Touch IRQ handler works well (reacts on pin changes where MPR121 IRQ pin is connected, correct IRQ handler is fired up), until i enable GPS module, which starts to send NMEA strings to UART. Then, only handler that is fired up on incoming UART data, is MPR121_check_pad_status() which was set explicity to fire only on specific pin change, not UART events. UART0_IRQHandler(), which is also defined, is never fired at all.
Same UART code alone seems to work ok in a separate program dedicated to testing GPS interaction. Touch events code alone also works well, when UART code is not compiled in.
    Which pins are you using for your GPIOTE detect, and your UART RX?
    Also, I notice that you have no pullup/pulldown on your GPIOTE pin, what is the reason for this? It likely has nothing to do with the issue here, but it could give you unexpected triggers.
    Could you elaborate on the differences between this UART testing program, and the program that you are seeing this issue in?
    Are all the configurations the same, etc?
    For future reference, please use the Insert -> Code option when sharing code here on DevZone in the future. It makes the code a lot easier to read.
    Looking forward to resolving this issue together!
    Karl
  • Hi Karl, i'm not using internal pull up, as there is external pull up resistor present on this line.
    As to pin assignments, this is MPR121 IRQ line:
    #define TOUCH_IRQ_PIN NRF_GPIO_PIN_MAP(0,20)
    Regarding UART, init routine is called like that:
    #define PIN_GPS_TXD NRF_GPIO_PIN_MAP(0,6)
    #define PIN_GPS_RXD NRF_GPIO_PIN_MAP(0,26)
    UART_config(0,PIN_GPS_TXD,0,PIN_GPS_RXD,UART_BAUDRATE_BAUDRATE_Baud38400,false);
    Regarding configurations - for my main progam i have used sdk_config.h from peripheral/template_project/pca10056/blank/config/sdk_config.h, and modified it as needed. One maybe important thing that is changed, is that i have set UART_LEGACY_SUPPORT to 0, as it was giving me "multiple definition of `UARTE0_UART0_IRQHandler'" error during compiling.
    And for a UART/GPS test program, i think i have used sdk_config.h from uart example. Is there any specific setting i should search for?
    Wojtek
  • I'm attaching UART/GPS test program here - hope this helps. It basically initializes UART, turns GPS module on, sends a configuration string to GPS, then only listens to NMEA strings from GPS, and prints them using Segger RTT printf().
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup blinky_example_main main.c
     * @ingroup blinky_example
     * @brief Blinky Example Application main file.
     * This file contains the source code for a sample application to blink LEDs.
    #include <stdbool.h>
    #include <stdint.h>
    #include <nrf_drv_pwm.h>
    #include "nrf_delay.h"
    #include "nrf_drv_pwm.h"
    #include "app_error.h"
    #include "boards.h"
    #include "bsp.h"
    #include "app_timer.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpiote.h"
    #include "nrf_drv_gpiote.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "SEGGER_RTT.h"
    #define GPS_POWER_PIN NRF_GPIO_PIN_MAP(0, 30)
    #define GPS_RESET_PIN NRF_GPIO_PIN_MAP(0, 5)
    #define GPS_RX NRF_GPIO_PIN_MAP(0,06)
    #define GPS_TX NRF_GPIO_PIN_MAP(0,26)
    #define UART_TX_BUF_SIZE 256
    #define UART_RX_BUF_SIZE 1024
    uint8_t G_UART_input_buffer[UART_RX_BUF_SIZE];
    char G_UART_new_data[256];  // single UART input command max length
    uint16_t G_UART_buffer_pos;
    uint8_t G_GPS_module_state;
    uint8_t G_UART_wiring;
    bool G_receiving_UBX;
    uint8_t G_received_UBX_packet_len;
    typedef enum
        UART_OFF,        /**< app_uart state OFF, indicating CTS is low. */
        UART_READY,      /**< app_uart state ON, indicating CTS is high. */
        UART_ON,         /**< app_uart state TX, indicating UART is ongoing transmitting data. */
        UART_WAIT_CLOSE, /**< app_uart state WAIT CLOSE, indicating that CTS is low, but a byte is currently being transmitted on the line. */
    } app_uart_states_t;
    /** @brief State transition events for the app_uart state machine. */
    typedef enum
        ON_CTS_HIGH,   /**< Event: CTS gone high. */
        ON_CTS_LOW,    /**< Event: CTS gone low. */
        ON_UART_PUT,   /**< Event: Application wants to transmit data. */
        ON_TX_READY,   /**< Event: Data has been transmitted on the uart and line is available. */
        ON_UART_CLOSE, /**< Event: The UART module are being stopped. */
    } app_uart_state_event_t;
    static uint8_t  m_tx_byte;                /**< TX Byte placeholder for next byte to transmit. */
    static volatile app_uart_states_t m_current_state = UART_OFF; /**< State of the state machine. */
    void parse_UART_input(char *line_data)
      if(line_data[0] != 0xB5)
        SEGGER_RTT_printf(0, "RTT DEBUG: UART input: %s\n",line_data);  // print it if we can assume that it's a text line
      //uint16_t i = 0;
      //while(line_data[i] != 0x00)
      // SEGGER_RTT_printf(0,"%0X ",line_data[i++]);
      //SEGGER_RTT_printf(0,"\n\n");
                               uint32_t speed,
                               bool hwfc)
       if (hwfc)
    static void action_tx_send()
        if (m_current_state != UART_ON)
            // Start the UART.
        //SEGGER_RTT_printf(0, "RTT DEBUG: serial out: %X.\n",m_tx_byte);
        NRF_UART0->TXD  = m_tx_byte;
        m_current_state = UART_ON;
    void action_tx_stop()
        //app_uart_evt_t app_uart_event;
        // No more bytes in FIFO, terminate transmission.
        NRF_UART0->TASKS_STOPTX = 1;
        // Last byte from FIFO transmitted, notify the application.
        // Notify that new data is available if this was first byte put in the buffer.
        //app_uart_event.evt_type = APP_UART_TX_EMPTY;
    static void action_tx_ready()
         action_tx_stop();
     static void on_uart_put(void)
         if (m_current_state == UART_READY)
             action_tx_send();
    static void on_tx_ready(void)
         switch (m_current_state)
             case UART_ON:
             case UART_READY:
                 action_tx_ready();
                 // Nothing to do.
    static void on_uart_event(app_uart_state_event_t event)
         switch (event)
             case ON_TX_READY:
                 on_tx_ready();
             case ON_UART_PUT:
                 on_uart_put();
                 // All valid events are handled above.
    uint32_t app_uart_put(uint8_t byte)
         uint32_t err_code = NRF_SUCCESS;
         uint16_t delay_counter = 0;
         while(m_current_state != UART_READY)
           nrf_delay_ms(1);
           delay_counter++;
           if(delay_counter > 300)
            return 4;
         m_tx_byte = byte;
         on_uart_event(ON_UART_PUT);
         //SEGGER_RTT_printf(0, "RTT DEBUG: app_uart_put: %X, err: err_code: %d\n", byte, err_code);
         return err_code;
     void UART0_IRQHandler(void)
         uint8_t rx_byte;
        // Handle reception
         if ((NRF_UART0->EVENTS_RXDRDY != 0) && (NRF_UART0->INTENSET & UART_INTENSET_RXDRDY_Msk))
           // Clear UART RX event flag
           rx_byte                 = (uint8_t)NRF_UART0->RXD;
           //app_uart_event.evt_type   = APP_UART_DATA;
           //app_uart_event.data.value = m_rx_byte;
           //m_event_handler(&app_uart_event);
           G_UART_input_buffer[G_UART_buffer_pos] = rx_byte;
           if((G_UART_buffer_pos == 0) && (rx_byte == 0xB5)) // receiving UBX packet
             G_receiving_UBX = true;
             G_received_UBX_packet_len = 0;
           else if((G_UART_buffer_pos == 0) && (rx_byte != 0xB5))
             G_receiving_UBX = false;
           if(G_receiving_UBX && (G_UART_buffer_pos == 4))
            G_received_UBX_packet_len = G_UART_input_buffer[G_UART_buffer_pos];
           if(G_receiving_UBX && (G_UART_buffer_pos == 5))
            G_received_UBX_packet_len |= G_UART_input_buffer[G_UART_buffer_pos] << 8;
           G_UART_buffer_pos++;
           if(G_UART_buffer_pos > (UART_RX_BUF_SIZE - 1))
             G_UART_buffer_pos = 0;  // overflow, wrap buffer
           if((G_UART_input_buffer[G_UART_buffer_pos - 1] == '\n') && (!G_receiving_UBX))  // new line of data from UART
              memcpy(&G_UART_new_data,&G_UART_input_buffer,G_UART_buffer_pos);
              G_UART_new_data[G_UART_buffer_pos - 1] = 0x0;
              parse_UART_input((char *)&G_UART_new_data);
           else if(G_receiving_UBX && (G_UART_buffer_pos == (G_received_UBX_packet_len + 8)))
         if ((NRF_UART0->EVENTS_ERROR != 0) && (NRF_UART0->INTENSET & UART_INTENSET_ERROR_Msk))
            uint32_t       error_source;
            // Clear UART ERROR event flag.
            NRF_UART0->EVENTS_ERROR = 0;
            // Clear error source.
            error_source        = NRF_UART0->ERRORSRC;
            NRF_UART0->ERRORSRC = error_source;
            SEGGER_RTT_printf(0, "RTT DEBUG: serial receive error from source : %d\n",error_source);
           //app_uart_event.evt_type                 = APP_UART_COMMUNICATION_ERROR;
           //app_uart_event.data.error_communication = error_source;
         // Handle transmission.
         if ((NRF_UART0->EVENTS_TXDRDY != 0) && (NRF_UART0->INTENSET & UART_INTENSET_TXDRDY_Msk))
             // Clear UART TX event flag.
             NRF_UART0->EVENTS_TXDRDY = 0;
             on_uart_event(ON_TX_READY);
    void GPS_send_stream(char *stream, uint16_t length)
       uint16_t i;
       for(i = 0; i < length; i++)
         app_uart_put(stream[i]);
    static void nosd_power_manage(void)
      __WFE();
      __SEV();
      __WFE();
     * @brief Function for application main entry.
     char gps_command[50];
     nrf_gpio_cfg_output(GPS_POWER_PIN);
     nrf_gpio_cfg_output(GPS_RESET_PIN);
     nrf_gpio_pin_set(GPS_POWER_PIN);
     nrf_gpio_pin_set(GPS_RESET_PIN);
     nrf_delay_ms(1000);
     nrf_gpio_pin_clear(GPS_RESET_PIN);
     nrf_delay_ms(1000);
      while(0 == NRF_CLOCK ->EVENTS_HFCLKSTARTED)
     NRF_CLOCK->TASKS_LFCLKSTOP = 1;
       while(NRF_CLOCK->LFCLKSTAT);
     NRF_CLOCK->LFCLKSRC = CLOCK_LFCLKSRC_SRC_RC;
     NRF_CLOCK->TASKS_LFCLKSTART = 1;
     UART_config(0,GPS_TX,0,GPS_RX,UART_BAUDRATE_BAUDRATE_Baud38400,false);
     nrf_delay_ms(10000);
     sprintf(gps_command,"$PMTK101*32\r\n");
     GPS_send_stream(gps_command,strlen(gps_command));
     SEGGER_RTT_printf(0, "RTT DEBUG: UART configured.\n");
     while(true)
        nosd_power_manage();
    My main program has several source files, so i won't attach it here. It is basically a firmware for a device i'm building (in early stages of development). Among other functionalities, it includes MPR121 code, and i have just started to add UART code to interact with onboard GPS module.
  • I have found one error in my code: RX and TX pins for UART were swapped in my main program. After correcting that, i see that UART handler is triggered as expected. I still have a problem with touch IRQ handler being triggered along with UART handler though. If there are no known bugs that can cause similar behavior, then i suspect that maybe there is some error on my custom board - maybe some short or crosstalk between these two pins - i will check this and i'll get back with the results.
  • Hello Wojtek,
    Thank you for clarifying, and for the detailed descriptions and code - this is very helpful!
    I am happy to hear that you were able to identify and resolve this particular issue! It still seems very strange to me that you are getting the UART RX event when the GPIOTE pin is triggered.
    There is no known issue of this, no. I have never heard of any similar behavior either. Could you possibly try to change the pin you are using for your GPIOTE event, to see if the same happens then? if the same does not happen with another pin it is very likely that it is a hardware issue.
    Karl
