NRF51822 programming with uVision and ST-link
I'm trying to connect to/program my nrf51822 module I just got. I've got it set up with my st-link but whenever I try to flash the device I keep getting: Error: Flash Download failed - "Cortex-M0"
In nRFgo studio the 'nrf51 programming' section in the device manager window is disabled, so I can't even try to wipe the device from there. (edit: I realise now I can't use this with the st-link)
Any idea how I can connect to this device?
EDIT: I can do a full chip erase in uVision before the programming. It seems to complete that successfully, but then says "Programming failed!", followed by the 'Flash download failed' error as before.
  • nRFGo only supports J-Link nothing else. Search for ST-Link on this forum there are a few threads about it. An other alternative is to use the IDAP-Link here.
  • I can do a full chip erase in uVision before the programming. It seems to complete that successfully, but then says "Programming failed!", followed by the 'Flash download failed' error as before.
    EDIT: Okay, got it working! For anyone else that experiences this problem... All it seems I had to do was update my programming algorithm in the debugger menu. Seemed to do the trick when I switched it to "nrf51xxx External Connectivity Board". I changed to that, set it up to do a full chip erase, managed to program it a few times.
    I then switched back to the original programming algorithm and put the other settings back the way I had them before too, seems to still be working.
