S130 seems to be stuck before even reaching main
I am trying to run a NRF51822 chip using Emblocks and OpenOCD, the debugger interface is a ST-Link from a Discovery board, which supports SWD.
When I program the Blank device everything works fine, the program flow reaches the main function. However, when I flash S130, the program flow never reaches my main function (I don't have any other application code).
I have checked the assembly code and S130 is stuck on a (arm asm incoming) WFE and b.n instruction, to my knowledge, it seems like it is waiting for an interrupt, event or for a wake up to happen before doing anything... is this the expected behaviour or I am doing something wrong?
The only pins I have connected are the SWD lines (2 pins) GND and VDD (3 volts).
EDIT1:
I have checked and yes, apparently S130 is not flashed correctly. Appraently, it only flashes S130 till position 0x7C0, then for some reason it doesn't flash anymore.
This is the memory view in Emblocks:
image description
This is the log from OpenOCD:
image description
Any ideas?
I will keep looking, thank you for your help.
EDIT2:
To flash S130, Emblocks converts the hexfile from Nordic to the following .c file:
image description
The linker script is the following:
/* Linker script to place sections and symbol values. Should be used together
 * with other linker script that defines memory regions FLASH and RAM.
 * It references following symbols, which must be defined in code:
 *   Reset_Handler : Entry of reset handler
 * It defines following symbols, which code can use without definition:
 *   __exidx_start
 *   __exidx_end
 *   __etext
 *   __data_start__
 *   __preinit_array_start
 *   __preinit_array_end
 *   __init_array_start
 *   __init_array_end
 *   __fini_array_start
 *   __fini_array_end
 *   __data_end__
 *   __bss_start__
 *   __bss_end__
 *   __end__
 *   end
 *   __HeapLimit
 *   __StackLimit
 *   __StackTop
 *   __stack
OUTPUT_FORMAT ("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
ENTRY(Reset_Handler)
MEMORY
  SOFTD (rx) : ORIGIN = 0x00000000, LENGTH = 0x20000
  FLASH (rx) : ORIGIN = 0x00020000, LENGTH = 0x20000
  RAM (rwx) :  ORIGIN = 0x20002800, LENGTH = 0x1800
SECTIONS
    /* You can place the softdevice in this sector so that
     * it is included in the final image.
    .softdevice :
        KEEP(*(.softdevice*))
    }> SOFTD
    /* The normal application area of the device with SoftDevice
	.text :
		KEEP(*(.Vectors))
		*(.text*)
		KEEP(*(.init))
		KEEP(*(.fini))
		/* .ctors */
		*crtbegin.o(.ctors)
		*crtbegin?.o(.ctors)
		*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
		*(SORT(.ctors.*))
		*(.ctors)
		/* .dtors */
 		*crtbegin.o(.dtors)
 		*crtbegin?.o(.dtors)
 		*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
 		*(SORT(.dtors.*))
 		*(.dtors)
		*(.rodata*)
		*(.eh_frame*)
	} > FLASH
	.ARM.extab :
		*(.ARM.extab* .gnu.linkonce.armextab.*)
	} > FLASH
	__exidx_start = .;
	.ARM.exidx :
		*(.ARM.exidx* .gnu.linkonce.armexidx.*)
	} > FLASH
	__exidx_end = .;
	__etext = .;
	.data : AT (__etext)
		__data_start__ = .;
		*(vtable)
		*(.data*)
		. = ALIGN(4);
		/* preinit data */
		PROVIDE_HIDDEN (__preinit_array_start = .);
		*(.preinit_array)
		PROVIDE_HIDDEN (__preinit_array_end = .);
		. = ALIGN(4);
		/* init data */
		PROVIDE_HIDDEN (__init_array_start = .);
		*(SORT(.init_array.*))
		*(.init_array)
		PROVIDE_HIDDEN (__init_array_end = .);
		. = ALIGN(4);
		/* finit data */
		PROVIDE_HIDDEN (__fini_array_start = .);
		*(SORT(.fini_array.*))
		*(.fini_array)
		PROVIDE_HIDDEN (__fini_array_end = .);
		*(.jcr)
		. = ALIGN(4);
		/* All data end */
		__data_end__ = .;
	} > RAM
	.bss :
		. = ALIGN(4);
		__bss_start__ = .;
		*(.bss*)
		*(COMMON)
		. = ALIGN(4);
		__bss_end__ = .;
	} > RAM
	.heap (COPY):
		__end__ = .;
		end = __end__;
		*(.heap*)
		__HeapLimit = .;
	} > RAM
	/* .stack_dummy section doesn't contains any symbols. It is only
	 * used for linker to calculate size of stack sections, and assign
	 * values to stack symbols later */
	.stack_dummy (COPY):
		*(.stack*)
	} > RAM
	/* Set stack top to end of RAM, and stack limit move down by
	 * size of stack_dummy section */
	__StackTop = ORIGIN(RAM) + LENGTH(RAM);
	__StackLimit = __StackTop - SIZEOF(.stack_dummy);
	PROVIDE(__stack = __StackTop);
	/* Check if data + heap + stack exceeds RAM limit */
	ASSERT(__StackLimit >= __HeapLimit, "region RAM overflowed with stack")
And by looking at the memory, this is what I've found regarding the .softdevice section.
From 0x00000000 to 0x000007C0: Code
From 0x000007C0 to 0x00001000: Nothing (0xFF)
From 0x00001000 to 0x0001B4D8: Code
From 0x0001B4D8 to 0x00020000: Nothing (0xFF)
I am using the S130 available (Production Ready) on Nordic website.
I will keep looking.
