cloud_client uses nvs library to report an error: invalid address: 0x00100ff8:8
I want to use nvs in nrf cloud. A conflict is found between the nrf_cloud library and the nvs library. The nrf_cloud library will cause the nvs library to be unavailable, and an error will be reported: flash_nrf: invalid address: 0x00100ff8:8.
I added nvs library to cloud_client to reproduce this problem. This is my prj.conf:
Added
CONFIG_NVS=y
CONFIG_NVS_LOG_LEVEL_DBG=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# Copyright (c) 2020 Nordic Semiconductor ASA
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_NCS_SAMPLES_DEFAULTS=y
# Log level
# For more verbose and detailed log output, set the log level to
# CONFIG_CLOUD_CLIENT_LOG_LEVEL_DBG=y instead.
CONFIG_CLOUD_CLIENT_LOG_LEVEL_INF=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
#CONFIG_LTE_NETWORK_MODE_LTE_M=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y
CONFIG_LTE_LEGACY_PCO_MODE=y
# Modem library
CONFIG_NRF_MODEM_LIB=y
# DK
CONFIG_DK_LIBRARY=y
# AT commands interface
CONFIG_AT_HOST_LIBRARY=y
# Generic cloud API
CONFIG_CLOUD_API=y
# Selected cloud backend
CONFIG_CLOUD_BACKEND="NRF_CLOUD"
# nRF Cloud
CONFIG_NRF_CLOUD=y
CONFIG_NRF_CLOUD_CONNECTION_POLL_THREAD=y
# AWS IoT
# CONFIG_AWS_IOT=y
# CONFIG_AWS_IOT_CLIENT_ID_STATIC="my-thing"
# CONFIG_AWS_IOT_BROKER_HOST_NAME="example.endpoint.com"
# CONFIG_AWS_IOT_SEC_TAG=201
# CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
# Azure IoT Hub
# CONFIG_AZURE_IOT_HUB=y
# CONFIG_AZURE_IOT_HUB_DEVICE_ID="my-device"
# CONFIG_AZURE_IOT_HUB_HOSTNAME="example.endpoint.com"
# CONFIG_AZURE_IOT_HUB_SEC_TAG=10
# MQTT
CONFIG_MQTT_KEEPALIVE=1200
# Heap and stacks
# Extended memory heap size needed for encoding nRF Cloud messages to JSON
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MAIN_STACK_SIZE=4096
# Settings, used by nRF Cloud library.
CONFIG_SETTINGS=y
CONFIG_SETTINGS_FCB=y
CONFIG_FCB=y
# Flash storage, used by settings.
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
# NVS
CONFIG_NVS=y
main.c:
static struct nvs_fs fs;
struct flash_pages_info info;
#define GOKE_BINARY_ID 7
int nvs_read_binary_state(bool *flag){
        int rc;
	rc = nvs_read(&fs, GOKE_BINARY_ID, flag, 1);
	if (rc > 0) { /* item was found, show it */
		LOG_INF("Id: %d, binary_state: %d\n", GOKE_BINARY_ID, *flag);
	} else   {/* item was not found, add it */
		LOG_INF("No binary_state found");
                return -1;
        return 0;
int nvs_write_binary_state(bool *flag){
        int rc;
	rc = nvs_write(&fs, GOKE_BINARY_ID, flag, 1);
        if(rc < 0){
                LOG_ERR("NVS write binary_state error!");
                return rc;
        return 0;
int nvs_setup(void)
	int rc;
	fs.offset = FLASH_AREA_OFFSET(storage);;
	rc = flash_get_page_info_by_offs(
		device_get_binding(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL),
		fs.offset, &info);
	if (rc) {
		LOG_ERR("Unable to get page info");
                return rc;
	fs.sector_size = info.size;
	fs.sector_count = 3U;
	rc = nvs_init(&fs, DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL);
	if (rc) {
		LOG_ERR("Flash Init failed");
                return rc;
        return 0;
void main(void)
	int err;
        bool flag;
	LOG_INF("Cloud client has started");
        if(nvs_setup()){
                LOG_ERR("Init nvs error!");
        if(nvs_read_binary_state(&flag)){
                LOG_ERR("read nvs error!");
        if(nvs_write_binary_state(&flag)){
                LOG_ERR("write nvs error!");
	cloud_backend = cloud_get_binding(CONFIG_CLOUD_BACKEND);
	__ASSERT(cloud_backend != NULL, "%s backend not found",
	err = cloud_init(cloud_backend, cloud_event_handler);
	if (err) {
		LOG_ERR("Cloud backend could not be initialized, error: %d",
			err);
	work_init();
	modem_configure();
#if defined(CONFIG_CLOUD_PUBLICATION_BUTTON_PRESS)
	err = dk_buttons_init(button_handler);
	if (err) {
		LOG_ERR("dk_buttons_init, error: %d", err);
	LOG_INF("Connecting to LTE network, this may take several minutes...");
	k_sem_take(&lte_connected, K_FOREVER);
	LOG_INF("Connected to LTE network");
	LOG_INF("Connecting to cloud");
	k_delayed_work_submit(&connect_work, K_NO_WAIT);
log:
SPM: NS image at 0xc000
SPM: NS MSP at 0x2001d5a8
SPM: NS reset vector at 0x12e49
SPM: prepare to jump to Non-Secure image.
[15:44:22.555]收←◆*
[15:44:22.579]收←◆** Booting Zephyr OS build v2.4.99-ncs1  ***
I: Cloud client has started
E: invalid address: 0x00100ff8:8
I: 3 Sectors of 4096 bytes
I: alloc wra: 0, ff0
I: data wra: 0, 8
E: invalid address 0x00100ff8:8
I: No binary_state found
E: read nvs error!
E: NVS write binary_state error!
E: write nvs error!
I: Using legacy LTE PCO mode...
[15:44:22.653]收←◆I: Connecting to LTE network, this may take several minutes...
demo:
cloud_client_test.rar
  • The starting address of settings_storage is 0xfe000, which is the cause of the bug. But I still can't find out where the problem is. The starting address of settings_storage described in the compiled dts file is 0xfa000. Can you give some guidance?
  • The partitions you see when running ninja rom_report is automatically generated by the Partition Manager. It uses the files nrf/samples/spm/pm.yml, nrf/subsys/partition_manager/pm.yml.nvs and nrf/subsys/partition_manager/pm.yml.settings to decide the position and sizes of the partitions. The main application does not have a pm.yml file, but it's location will get decided relative to all the other.
    However, you can generate all the partitions yourself, check out:
    Configuring Static Partitions
    nrf/applications/asset_tracker/configuration/thingy91_nrf9160ns/pm_static.yml
    In addition to running ninja rom_report, you can look at the file nrf/samples/cloud_client_test/build/partitions.yml to see the generated partitions.
    The partition sizes and locations from the dts will be ignored when your applcation has child images (your case).
    Simon
  • Thank you! There is another question. Why does the nvs library report an error when starting from address 0xfe000?
  • I'm sorry for not addressing your initial issue earlier. I was a little too fast to reply, and oversaw the obvious cause. My apologies for that.
    Comments:
    I added some printk's to your code:
    int nvs_setup(void)
    	printk("Sector size: %d | Sector count: %d | Total size = %d\n",info.size, 3, 3*info.size);
    It gave the following: "Sector size: 4096 | Sector count: 3 | Total size = 12288"
    This will give you a size of 12288=0x3000, which will occupy the flash 0xfe000-0x101000 (0xfe000+0x3000=0x101000). This will overflow the total flash, 0x100000.
    Why are you not using the nvs_storage area? If you run ninja rom_report from cloud_client_test/build, you will see the following
    | 0x0: spm (0xc000 - 48kB)                 |
    | 0xc000: app (0xec000 - 944kB)            |
    | 0xf8000: nvs_storage (0x6000 - 24kB)     |
    | 0xfe000: settings_storage (0x2000 - 8kB) |
    Solution:
    Configure nvs accordingly instead:
    fs.offset = 0xf8000;
    fs.sector_size = 0x1000;
    fs.sector_count = 6U;
    This will make it use this partition:
    Since 0x1000*6=0x6000
    I tested this and did not get the "invalid address" errors anymore, but I got a read error however:
    E: read nvs error!
    I did not get time to look into these, but please tell me if you want me to
    Simon
