sampling two analog
Hello
I want to sampling two analog.. with different configuration and handler.
so I set two channels like this.
    nrf_saadc_channel_config_t cds_channel_config =
    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
    err_code = nrf_drv_saadc_init(&cds_saadc_config, cds_saadc_callback);
    if(err_code != NRF_SUCCESS) return 1;
    err_code = nrf_drv_saadc_channel_init(0, &cds_channel_config);
    ///////////////////////////////// (different function)
    nrf_saadc_channel_config_t co_channel_config =
    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
    err_code = nrf_drv_saadc_init(&co_saadc_config, co_saadc_callback);
    err_code = nrf_drv_saadc_channel_init(1, &co_channel_config);
and then I call only one sample function like this.
void saadc_process()
    nrf_drv_saadc_sample();
Then error occurs. How can I change code?
and is there good example I can refer?
BR,
lyrics
    Maybe it would be better to just use 10 bits in both cases,
    First of all, I just added a channel and ran the program..
    But error occurs second channel init function.. (nrf_drv_saadc_channel_init)
     I hope there is reference code (example)!
        ret_code_t err_code;
        nrf_drv_saadc_config_t cds_saadc_config;
        cds_saadc_config.low_power_mode = false;                                  //Enable low power mode.
        cds_saadc_config.resolution = NRF_SAADC_RESOLUTION_8BIT;                  //Set SAADC resolution to 12-bit. This will make the SAADC output values from 0 (when input voltage is 0V) to 2^12=4096 (when input voltage is 3.6V for channel gain setting of 1/6).
        cds_saadc_config.oversample = NRF_SAADC_OVERSAMPLE_DISABLED;              //Set oversample to 4x. This will make the SAADC output a single averaged value when the SAMPLE task is triggered 4 times.
        cds_saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;               //Set SAADC interrupt to low priority.
        err_code = nrf_drv_saadc_buffer_convert(m_cds_buffer_pool[0], 1);
        err_code = nrf_drv_saadc_buffer_convert(m_cds_buffer_pool[1], 1);
        err_code = nrf_drv_saadc_channel_init(1, &co_channel_config );
        err_code = nrf_drv_saadc_buffer_convert(m_co_buffer_pool[0], 1);
        err_code = nrf_drv_saadc_buffer_convert(m_co_buffer_pool[1], 1);
        //CDS_F=1;
        return 0;
     OK, but this is a different function than earlier. What error code is returned?
    regards
    Jared
    In that case, the err_code is 0x11 (17).
    However, if I move on to the next function with the break point, the error below occurs.
  • Hi, I fixed the issue.. But another question.
    I reference this github code, and followed the code like this.
        cds_channel_config.gain = NRF_SAADC_GAIN1;
        co_channel_config.gain = NRF_SAADC_GAIN1;
        //if(err_code != NRF_SUCCESS) return 1;
    and then it works well, but the result of data are not what I expected.
    So, what is role of SAADC_CH_CONFIG_GAIN_Gain1_4 and  SAADC_CH_CONFIG_REFSEL_VDD1_4 ?
    They are the configured Gain and Reference that is used during the sampling. Please read the product specification regarding this topic, and consider making a new ticket for future problems as the original problem has been solved.
    regards
    Jared
